06-30-2012, 04:55 AM | #1 |
Supercharged to superchanged s14
Here is a little compilation of my build thread and what my car has seen over its time with me, im 20 and have self taught everything i know about cars, hours of reading forums and all kinds of diy's. When i first bought the car it was a built supercharged ka and was a great reliable car, needed some wiring and few things fixed here and there, i was laid off at the time and didnt have very much money to work on it so it stayed this way for quite some time, as work picked up my build began.
quick shot of how the car looked im not into the whole murderd out look so i had to break up the black alittle bit, bought a steamer and took off the window tint. still not good enough, new wheels, z32 brakes?? yes! 18x9.5 +15 all around for those questioning all stainless/braided lines for brakes, clutch, catch can, and power steering now after this i was pretty satisfied with how the build was going but really wasnt getting enough out of the supercharger kit so i wanted to turbo the car, shortly after the clutch goes out and im forced to drop 700 in a new clutch and flywheel, nismo motor and tranny mounts and a few other things so at this point i figured i had this much into it i might as well go ka-t. tore out ac! cut off the resonator on my hks hi power and bashed out my catco hi flow cat so it was straight through sold my navan front to my buddy jb so i could have alittle more cash to work with on my build after many different calculations and talking to james evans at je performance and jeff rica at cip i decided my best bet would be to go with an sr swap, for what it would cost me to build a turbo kit and the headaches it would bring i could just buy a swap and instal. so tear down began! went to harbor freight and bought a engine hoist! im sure by this time many of you are thinking it couldnt possibly be cheaper buying a whole new motor and swapping everything, but after parting out my entire built ka setup i made all but 3500 so that gave me a big head start on building the sr setup. i looked around at a couple different import companys and prices were alright, planned on a redtop but looked around on craigslist and found this clean s13 sr20 blacktop that was still on the crate from when he ordered it from tigerjapan with reciepts, so i drove out to maryland to pick it up. got an amazing deal and ended up getting a complete gasket/seal kit for the motor for free. as time went on i hated my monster truck stance and even though i was planning on doing motor only, i tore off my d spec/spring setup and opted for these oh and tanabe front and rear swaybars i was still paying off school debts at the time so i gave a big chunk of my ka money to catch up on payments so i was broke for awhile again. by next week i orderd some money small things i had money for that i knew id be needing aem wideband, circuit sports drift knob, circuit sports solid shifter bushing, had the momo wheel from before as money started rolling in again i started ordering more parts oem sr water pump, oem cam angle sensor, circuit sports aluminum cas cover, isis pulley kit, isis o2 housing, isis downpipe, isis fmic kit Then once again i was broke....=[ .....paycheck next week, more parts!=] hallman pro mbc synapse bov nissan quest alt z32 fuel filter gates belts after that i waited alittle and paid off some more schooling and then more parts arrived in the mail once again isis fpr came in today mishimoto cooling package ( sr radiator, hoses, thermostat, fan shroud, duals fans, s14 cooling panel) then i started thinking what else id need to finish the build and i am fairly good with wiring but i figured it would be much easier and cleaner if i bought the wiring specialties engine and trans harness rather than splicing everything . worth every single penny without any doubt! those guys at WS are awesome! wanted to clean up the tranny alittle bit so i sat it up on the tire and wanted to rtv my shifter plate then came reassembly! had some issues with the front mount being so big that i didnt think i could get my crash beam back on, i cut and cut and cut and by the time i was done it barely even had anything worth keep on it structurally so i went to the home depot and bought some 1" box tubing, refitting everything and began to weld in place. heres a quit test fit of everything after i repainted it, this front mount is huge it sticks out below my bumper 2 inches almost, kinda scares me so i may be making a custom aluminum skid plate to protect the bottom of fmic on bumpy roads. also welded the little piece that holds grill and everything onto my crash beam so its all one solid piece, takes 5 mins to take off the front end of car so i can access whatever i need i had a couple pieces of intake pipe laying around but my main goal was to run a recirc bov and being that i wanted to build a solid legit car i opted for apexi intake. 300 is quite a stab in the side for 1' of aluminum piping haha. jeff rica from cip got back to me that non were available anywhere and it would be forever till i got it from japan but later that day he found me one in some warehouse and got it shipped to me. this and many other parts jeff pulled through to get me, this build wouldnt be possible without them guys over at CIP(240sxmotoring) i also had a really hard time finding the z32 n62 maf but a month later picked one off of here and have it now! while all this parts buying was going on i gave the motor to our race mechanic to instal the gasket/seal kit, arp head studs and a few other pieces. Last but not least on my list was finding an ecu since the motor didnt come with one, so i searched EVERYWHERE and finally found one from a guy local believe it or not and i had originally planned on sending it to nistune to get their chip and the local guy not only had a stock oem e5 but he had a nistune chipped e5 for an amazing price so i picked that up in a heart beat! Before all this i had been using all my dads tools and was tired of hearing him complain about it so got a great deal on blackfriday still have a few parts rolling in before i can get the motor back, waiting for timing chain kit and i should be ready to go, but heres some parts that just showed up today fidanza flywheel spec stage 3+ finally got the motor back! now i can start to put everything back in the car!=] got the coilpacks back in, isis o2 housing on, fidanza flywheel, and got the clutch plate in place spec stage 3+ on tranny bolted back up and new cas installed with circuit sports cover ready to go back in the car well its been awhile since i got any time to work on my car with it being the holidays, my girlfriend and santa brought me some goodys |
07-06-2012, 02:14 PM | #2 |
nice engine stand tire=p best low profile jack you can find. period.
got a rain day from work so i figured id put it to good use instead of playing cod all day=p got my all my fittings on my fpr and thread tape on them ready to instal fpr installed test fitting my intake and ic piping....... of course, no it doesnt fit right. err i left my starter off the tranny when i put the motor in because i wanted to have it tested first and of course that was junk like my oem alternator.. so ordered a new one. i went to put my exhaust back on and the downpipe is hitting on my floor board the entire way, emailed isis and they said they have had a few customers have problems with the same thing but their product is identically to any other name brand part. so im gunna have to get a piece welded in to extend it down further. isis dp also doesnt come with a bung so i got a stainless bung welded in as weld for my wideband. before i had a fuse block between my battery and starter and i didnt like that it was this way because if i was out somewhere and the fuse blew im pretty much a sitting duck so i found a breaker at the auto parts store and got that wired in. after fitting up my isis ic piping it doesnt fit, i got the s14 kit and the bends are alittle off so i had to order some silicone couplers to finish that up, got couplers and it still wasnt even close so i had to order a new cold pipe from enjuku and luckily enough they had isis cold pipes for 25 bucks haha my lucky day!! since i have a synapse bov i had to get the flange welded into the pipe and took it to a local fab shop to have it tig welded heres it installed on car, i also had them fab a custom bov recirc pipe that i will show later on here by this time i was thinking my build was almost done, as i started ordering all my amsoil oil i thought about the rear seal in the tranny that was leaking when i got it so i tore the driveshaft off again and got everything ready for the new seal. after i did that i remembered the previous owner saying about the subframe bushings being bad so i took a quick glance and noticed that he had put subframe spacers over the oem rubber bushing to keep them from blowing out and it wasnt working anymore and pushed past the aluminum spacer, i found a subframe on craigslist with solid sikky bushing so i went and picked that up, had some surface rust and since the car doesnt have a bit of rust i wanted to keep it that way so i threw it into the sand blaster and got it all off and ready for paint decided i might as well do diff bushings at the same time so i burnt them out quick haha, ordered spl solid diff bushings primered and ready for paint after two coats, still needs cleared i wanted to go with all new suspension when i put it back in so ordered some circuit sports sway bar ends links for front and rear then wanted to get my rear out to swap everything over onto the new subframe heres everything waiting to go on, i ordered a circuit sports suspension arm package too but the toe rods are on back order till mid april got a strut bar as well, and cleaning up little last minute pieces that need done with the engine bay after the paint on the subframe was a fail i took it for powder coat and got the diff back together with all new amsoil fluids in diff and tranny meanwhile i was messing around with my daily, previous owner had alot of stainless parts on it but chrome really isnt my taste, so plasti dipped the wheels and all of the hood acc. while i was still waiting on suspension arms i needed to replace the front up by the fuse box because previous owner had a big ugly hole there that had some rust on it so i cut out all the rust and replaced with sheet metal. hole for ic piping is traced out seam sealer since my other fuse box wasnt working out i decided to make one with my new mig welder i picked up off craigslist toe arms and rlca's finally came in and put everything together, while everything was apart i put new megan bushings in the knuckles since my oem ones were worn out another pic of the rear end after it was up on the car ive been waiting almost a year now since i got the car to get a se lip and now i finally broke down and bought one, got a hell of a deal bnib from nissan! just need to get my front bump and lip painted and should be awesome... ive spent almost a month trouble shooting my timing, had 3 or 4 people stumped but finally with some zilvia help, she smoothed out idle and set base timing. my awesome gf washed the car for me today so its looking clean again haha. after taking it for the first test drive i made a big list of everything i wanted to change suspension wise and what not. pic of my car and her coupe just wanted to double check everything was running smoothly so i bought an aem oil pressure gauge and greddy sandwich. made a little heater vent gauge pod thing after the first test drive my exhaust drug ass really bad, so i put my coils up half an inch and then chopped the cat on both sides and mitred the flanges so that it would raise the whole exhaust up into the tunnel. after 9 months i cleaned up the garage today haha i ordered some paint and took off the bumper and se lip for some paint 4 days later had it all back on and ready to roll again ever since i bought the car like a year ago the front wheel bearings have been shot and wheel wobbled so i figured i better get some new ones. oem nissan hub assembly is expensive but well worth it, had them on in like 15 mins haha after the first 2 fuse boxes i attempted to make work i trashed both ideas, aluminum overflow can was too small and not functional, steel one i fab'd up was just too easy to rust and rattle even with coats of paint, so after looking everywhere online and in stores i found the solution, etrailer had brake controller boxes for trailers for 7 bucks so i picked one up and it fit perfect, no rattles, no rust, clean engine bay, done! well thats about it for now, stay tuned for more progress later on, i plan on a cage, new seats, and 2871r in the future, but for now, its summer and im hitting the corners! thanks for viewing zilvia! |
07-06-2012, 08:28 PM | #4 |
what s/c kit was on the car and how much power was it making?
http://www.youtube.com/canaanmanley |
07-07-2012, 06:03 AM | #6 | |
heres a pic of the kit all in pieces before i sold it the belts also didnt line up the greatest and i had problems with that, a serp belt snapped/jumped off on me twice and when i put the new one on its so hard to get it on you have to use a screw driver to pry it on, the next size bigger belt slips, belt has to be crazy tight so the s/c doesnt spin on it. you need a q45 maf and tb as well thanks man! |
07-08-2012, 05:45 PM | #11 | |
haha i dont plan on it, but i have said that before with other cars haha |
10-27-2012, 07:18 PM | #16 |
It's been awhile since I've updated, been working alot and figuring out what all I need to change this winter.
Picked up some tein inner and outer tie rods and oem dust boots. Started on the interior today and got it all gutted and ready for cage, welded my hydro ebrake in. Went with the Isis ebrake with wilwood cylinder and stainless lines, maverick dual caliper bracket, mustang rotors and some new pads. |
11-06-2012, 07:44 PM | #22 |
Been working hard lately haven't had much time to post. Bought a new daily like a month ago, had some rust so did some body work, pulled out the rear end, new rear end, rallitek swaybars, borla style headers and Stromung catback for some boxer rumble, Wrx wheels. Clean simple rally DD beater haha snow monster awesome gas mileage 5spd. Fucking deer runs in front of me 3 weeks after I finish it smh... So that's being worked on. Jeeps being worked on stupid carbs haha. It's never ending.
Anyways onto the stuff that matter haha. Maverick motorsports bracket all mounted up. Everything mocked up and on the car, still need to run brake line Car leaves in two weeks for cage, and welding the rear end. Can't wait to get it back! |
11-18-2012, 02:44 PM | #25 |
thanks man! hoping its not too raspy, if so ill get a stainless resonator and weld it in but we'll see.
got the rest of the car prepped for the cage today, still have to get sound deadening off where plates go but thats an easy fix tore trunk all apart and put sound deadening in here to try to keep straight pipe noise down some in the cab, i get head aches easy also the battery box was off on the side of the trunk before, not sure if it makes a bit of differnce but i centered my weight, and no that strap isnt holding the box on there lol, just the lid hydro is finished completely and brakes bled, waiting on fortune auto to get me new bottoms and off to fab shop it goes |
11-24-2012, 06:55 AM | #28 |
11-29-2012, 07:32 PM | #30 |
Got the new Evo tonight, really kinda disappointed in the new design I loved the old look better so I'm searching for the old style seat cover and then I'm going to reappolster it to match the old Evo, or so I hope to..
