Closed Thread
Old 07-22-2013, 04:42 PM   #1
Lilredsx
Lilredsx is an unknown quantity at this point
What type of LSD is this
I recently purchased this LSD and I used my diff cover since it was previously in an S13, so I'm trying to figure out what type it is and what oil is best to use in it. I don't want this one to end up like my last diff.
[IMG][/IMG]
[IMG][/IMG]
Lilredsx is offline
Old 07-22-2013, 04:52 PM   #2
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
If its a clutch type, use kaaz.
brndck is offline
Old 07-22-2013, 05:15 PM   #3
Lilredsx
I'm not sure what type it is. And it makes quite a racket on left turns also. Lots of thumping.
Lilredsx is offline
Old 07-22-2013, 05:18 PM   #4
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Looks like a factory VLSD. You should put the factory recommended 75w-90 in it. You cannot replace the viscous fluid and hopefully, you didn't pay a fortune for a possibly worn out diff.
My SR20VET
jr_ss is offline
Old 07-22-2013, 06:05 PM   #5
Lilredsx
Yeah, I used the proper weight fluid, I think it was Mobile brand, I'd have to check when I get home.
I paid $150 for it.
Lilredsx is offline
Old 07-22-2013, 09:57 PM   #6
cotbu
cotbu's Avatar
VLSD, I've been cataloging mystery lsd's and I come up with an I dentification system that seems to work.
The holes sizes(big) and spacing and the beveled edge opposite of the ring gear are a clear indication of a VLSD.
Most clutch type lsd's I've cataloged are more square or flat opposite the ring gear.
This was sold to me as a vsld! Not the actual shit but the same you know what i mean.
cotbu is offline
Old 07-23-2013, 07:50 AM   #7
Lilredsx
So if it's VLSD, is there special fluid that i need to have in it?
This is what I put in. 1 and a half jugs of it.
[IMG][/IMG]
Lilredsx is offline
Old 07-23-2013, 09:08 AM   #8
jr_ss
Trader Rating: (34)
Nope, no special fluids required. The VLSD unit is a seal piece inside the piece with large round holes.
My SR20VET
jr_ss is offline
Old 07-23-2013, 09:48 AM   #9
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
These are the only two posts that you need to really take into consideration. Seeing as though you paid $150, try to see if it locks properly. If not, don't feel too bad about your purchase, you may need to shim your VLSD because the sealed unit within is worn and will act more like an open than what an LSD unit is supposed to act like.
zooopreme is offline
Old 07-23-2013, 01:40 PM   #10
Lilredsx
Not sure how to test the lock, but the night I put it in, I went to do a u-Turn and ended up doing a 270, It was more than willing to rotate, and if I do a little power braking, both tires will spin. I'll pull it back down in a couple days to see if there are any obvious issues or metal and then try to do a shim later on when I have access to some power tools.
Thanks to all for the responses so far.
Lilredsx is offline
Old 07-23-2013, 02:44 PM   #11
enkei2k
#/f/chat/174916-identify-thread.html
Ask enkei2k
xquizitditz
enkei2k is offline
Closed Thread
