Alright, after a few months i finish the Stage 2 - Engine Swap
so here are the pictures from the whole journey If you didnt saw previous stage..check link below Link: * [S13 240sx Convertible - Stage 1: Restoration] (body/suspension/engine) Link: * [S13 240sx Convertible - Stage 2: More Power] (engine swap) Link: * [S13 240sx Convertible - Stage 3: New Look] This is the transformation you gonna see in this thread - UPDATED SPECS - 1JZ VVTi (stock harness) R154 Transmission Kakimoto Racing Hyper Full Mega N1 Odyssey Fab Turbo elbow/downpipe D-MAX D1 Spec Coilovers 350z Seats Ichiba 5-lug conversion (front/rear) Q45 Brakes (Drilled, Slotted and Vented Rotors) DMAX smoked Tail Lights OEM 180sx Sideskirts Sneakers: front Sumitomo 245/40/R18 rear Bridgestone 255/40/R18 .... And more Alright, this is my 1992 Nissan 240sx Convertible (some of you may know this car from prev owner) i bought it on February 2016 and start to get her beauty back This is my first time working on a car, (i was focusing on restoring old school BMX bikes) so everything here was new to learn. Believe it or not all this is on a budget, from tools to engine parts trying to spent LESS possible without compromising quality DO IT YOURSELF...to save money and LEARN in the process (and that's priceless) Google and YouTube will be your best friends from now on if you notice i post too many part prices is because i want you to see that you dont have to be rich to do all this. This is not about being cheap... is about to being Smart STAY UPDATE !! like and subscribe :P Youtube channel: https://www.YouTube.com/FollowJulian Instagram: iFollowJulian . Last edited by MEFISTO; 05-01-2017 at 01:48 PM.. |
Just bought some more horses!
Picking up! New Engine.. 1JZ VVTi (JZX100) 2.5L Turbo 280hp stock some parts of the Puzzle here forget about horse power.... Cat Power FTW New Fuel pump, Deatsch Werks DW200 R154 transmission (Toyota Supra) needs JZ bellhousing and shifter extension for S13 already have my Christmas R154 Snowman! checking gears R154 are really heavy duty transmissions Yep, im a sick motherfuc*er Aluminum parts on car are intended to be light and cooler if you paint them u are taking that property off. But.. i paint this anyway Removing all the things i wont be using it im a newbie on this so i better LABEL EVERYTHING !! i have to remove the A/C ![]() i will put it back in some near future downpipe Out! Valve covers out! it came with an US waterpump from Japan, but unbranded, so i better change the front/back complete for an OEM Here is when the Freak starts making beautiful parts again. If you do a really really good masking..you dont have to take all apart (see the tape inside housing?) Another part that must NOT be painted..oh well Removing tape ![]() Intake manifold is out! This small oil filter sometimes gets dirty, better take a look while u can The injectors had the seals/insulators worn and they have an specific shape that fits, luckily i found new seals and o-rings (Viton made) u can get them here: http://www.ebay.com/itm/282325188402 Aluminum gets dirty very easy..the only best way to get the original look is sandblasting it...so lets go After sandblasting! |
Here is a good example of why u should sandblast aluminum parts.
50/50 Before After After having the aluminum clean, is better to tape so dust/dirty hands doesn't fuck your work had valve check and groomet missing 1JZ VVTi ISC Valve Check Part# 25748-88400 Grummet Part# 90210-25001 Done And taped New Viton seals for the Injectors! And all together finally! Stock R154 housing needs to be extended to fit 240sx shifter hole in place. So i found this place in Florida who does that and better pricing than here in CA Here is what they did... very nice and i order the Downpipe for the turbo also from them Fully open, not restricted = More power Another part to get sandblasted tape ALL so u have to work less to clean later and.. here is it Everywhere i look i found new pieces to clean... i found that gasket where pretty good..for now i will use them, i will get new ones in the future Valve covers back together and more taking apart Before After All back together Needed some studs for the O2 sensor.. i went ACE Hardware and found some (short) Because i wanted a clean engine bay look, i cut the water neck so i can use a straight hose to Radiator Because my harbor freight welder is not THAT PRO (maybe my pocket is not that pro) to weld Aluminum, i have to get someone to weld this like that Found someone...and done! and then of course.. Sandblasting ! lmao |
Started needed some refresh Turbo heat cover needed some love also All parts needed for this Swap, mostly i got from eBay ... yes i bought all at eBay and save, all OEM Toyota/Lexus sealed boxes and HALF price (if you are ignorant don't read that) (missing Driveshaft and Rad fans in photo) 1JZ VVTi Turbo elbow (OdysseyFab) Pilot bearing, throwout bearing and clutch aligment tool Aisin Toyota OEM Pressure plate Sometimes is better to keep it OEM (when money is short) Toyota Oem Clutch Toyota Oem Flywheel Trans didn't came with Shifter, i found OEM one on eBay. Shifter housing extension and shift linkage made and Marlin Crawler Urethane Shifter Bushing + Nylon Shifter Marlin Crawler Socket R154 to 1JZ Bellhousing NTN Timing Belt tensioner ARP Flywheel bolts 1JZ/2JZ vvti US Water Pump US Pulley Part# 16371-46020 Aisin Clutch Slave cylinder Toyota Oil Filter Mishimoto thermostat 68c Timken R154 Transmission Intput Shaft Seal R154 Transmission Output Shaft Seal HKS (really?) Air Filter 1JZ VVTi Timing Belt tensioner idler Toyota Part# 13505-46070 Timing + Serpentine Belts Stinger Distributor Block (Battery Relocation) Fuse Holder + 250Amp Fuse Facebook used Intercooler ![]() eBay Special, Universal 2.5'' inch intercooler piping 12pcs Made in California and found a Dual Flex-a-Lite Fans Putting pressure plate and bearing together Old vs New All Done! i got these mounts included with engine deal He told me they are from Suspicious Garage they look soooo clumsy that i go ahead and did a lot of welding on them (Update: to fit engine in the right place i had to make new holes/sliders on these mounts) Block needed some refresh! [IMG]https://lh3.googleusercontent.com/biENyXw77bor3HAjdwKQMxoCleCRDbyShZN42l1S-vOjlEHe0vJu-vVAGvLOXUOlrnYUcRHQEEqFykRLTlLvbMbNqS6PsjYSSUwnDVe EVnNbP8ATsZN-tHhb-W0AqvonJsVSM3zT6UT18Z5nbj3ITRX3H4vdkf_MrfEJkBAlIBz XB70qMwXS7NMW1Kkx5QRK_QGrx-g4AaxLM3tGy95l_Fv9Fc7LTZxSm2PXMXipxiNMlB7JdziXutaX Q_dsnwX4PC_bBV8PShjSrG1PSiwh-Hg74RxTK8QNDTXkMdogCeqDUTgvaTyk1IR7gVBmm4CFsBJOeif gT7aJGIX6d7_NX7Du9nHUmGxqhpEGBQtZv9Pua1KVB8Rs1Te1c oNPMy5eUMw83yXRiQ-lsmU_Bcd6tkTH9O0dzDmM7NE_oMLmhOXOu8DeYZL1GDhzQhQj6 k3nf8-CAn1nWnAc7Osl_OQ7pgJJUS5met-s-ph-yI31Al5CM7QmUIattBlOD158FCWjr9OtHQ4OFMcOQ7EtQmYbOH nSw1Jb5CFAMv5Kp1hn-kW7X3hOyjsJi9viB_l-ER7QJfLVoPKU8EUKXX8xpYpSXQN6_iA7XsipB8ldi4oiigHVl1 BknMrK=w1212-h909-no |
Now the fun starts!
must put this puzzle all back together! Looking good.. LOOKING REALLY GOODDDDDD! and now the day has come.. KA24DE will be OUT! without this guy none of this would have been possible that fast. THANKS Steven! extracting her soul i was waiting this momment to tuck this wire harness the only problem is that Verts came with these Arms right in the place u have to cut i manage to cut and make it work, hoping wheel not rub later Done About engine bay.. Take all what dont need OUT Cleaning remove all Masking R154 need some clearance in trans tunnel u need some help to make it Starter side + upper side hammering Cover holes that you dont use to make bay cleaner i used JB Weld Metal putty, and then sand it i used JB metal putty i tape (actually hold with finger) and apply putty After dry masking hood to paint! Base color Ready to paint base color White as a base color.. which color will be ? ![]() R154 + 1JZ VVTi about to get married R154 + 1JZ VVTi finally together #r154 #1jzvvti #1jz Yup, engine bay is going PINK....because California bro! |
Best way to 'tape' is with metalic foil, it shapes perfect and easy to remove Ready to go IN !! Fuc*ing engine mounts...not only were welded as shit, also out of square, i had to make new slots and work on fitment engine is IN now..for 1 day Transmission wont shift so i had to took it out and fix that, it was out of sync and then i manage to lock it on reverse, damn After found i made the mistake removing bearing before taking housing off...i fix it moved shaft back again to neutral and locking with ball. Inspection covers for R154 are expensive AS... so i made my own and they came out pretty cool fitment is great and painted looks better look oem (from 5mts far) Alright, all fixed and getting ready to put engine back again Making wiring slim to fit behind block Removing paper tape cover Kakimoto 1JZ pipe for S13 i have to work on making an extension now Fuel lines are not Heat friendly |
because fuel line are not heat friendly..i took the cat heat shield from stock KA ..cut and make some shield for the other side
way better Battery Relocation... beta test Fuse box + 250A fuse Battery Relocation... Final Gauges are here! Cheap and Good !! 8awg from fuse box to power block 4awg black wire from Starter to power block stock KA24 fuel lines can be bent by hand Making Fuel lines routing Done, way better than having rubber hoses lines around the block making a heat shield for the fuel lines next to the downpipe My Harbor Freight welder melt that plate, so i had to make that patch and weld it like that Painted High heat paint Testing Fitment.... Good! Next: Themal tape EVERYTHING Finally draining the oil There is no enough room to place my dual fans without cutting everything... i added the rubber to make it seal better as a pusher on front so i went Pusher side (i ordered pusher blades) The air flow power on these is impressssssive now i have plenty of room More seal and less vibration Mounting the Intercooler Testing.. Piping Hole from intercooler (ex battery place) now intercooler fitment and this is how shifter sits i need 3 new gauges so i have to make my own plate measurements |
testing
done So..because i have to solder many wires at the harness, i wanted to make it better so i went to the Junkyard and got many wires in different colors AND.. a lot of factory Plugs so i can make it easier to remove ECU/Harness in the future my Work station Lunch at work station lol My wire harness came pretty hack i will use this plug (one of them) to join harness with ECU something like that starting looking gooood and voila! Finished Super finished! Last step... get downpipe with exhaust together and... F I N I S H E D |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Polished intake pipes, radiator, and pink bay aside, I'm actually impressed at how factory this looks in your car.
![]() Join Date: Jan 2007
I miss my 2j/Vert now ::sad panda face::
**Just move your fuel hard line to the driver side
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
Super clean, nicely done.
On that last pic, why does the engine look like it's in crooked? The rear of the engine looks centered on the firewall, but the front of the engine appears to be pointed towards to passenger side. Or maybe it's a weird optical illusion from the camera angle.
#15 | |
![]() Join Date: Sep 2012
#17 | ||
VIDEO IS UP !!
more videos comminggggggggggg Thank you all for the comments Quote:
45 days i did the swap with my friend, full detail I did not feel like doing it so i made the shield plates 300z came from factory with lines next to the exhaust manifold, covered by just with a shield Maybe in the future i will..is way better i know, but too much work as i dont like using just rubber lines Quote:
then i found out they were weld out of square.. and it was worst, just i made new slots so i can get engine sitting properly |
Some mechanical update !!
Starter doesn't start when i want, so i take it apart and see whats wrong with it.. found a lot of Carbon so i clean it (it wasn't carbon issue, added more grounds..still having the issue, it may be the key ign cylinder) After some love.. all clean (starter works on floor every time, but sometimes fail into car, still looking for answers Installing the sensor for the gauges (Oil pressure) Remove the OEM sensor (next pic) and u need to put this adapter: 1/8-27 NPT Female to 1/8 28 BSP Male (silver one) and then u can screw the AutoMeter one the one to remove: Water temp gauge... this is the water neck with both OEM sensors, i remove the small one which is the gauge sensor and need to put the AutoMeter one in same place Oem sensor is metric, so u need to tap the hole to get the new one (Thank you Steven's dad!) And this is how it looks after All 3 mechanical gauges hoses in the same hole (Boost - Water temp - Oil pressure) new Upgrade! J30 VLSD Differential for S13 u need 95/96 Infiniti J30 differential they come 6 bolts (use your stock axles), u need to swap the stock S13 diff cover, get solid bushings (front mount only) and longer bolts (M12 x 1.25, 85mm long) and 2 washers (info from www.ka24development.com) Removing old bushings Taking stock diff out removing cover so i can use with J30 diff Left side J30 VLSD - Right side S13 stock open diff Getting the S13 cover into J30 diff Adding juice! This is the stock S13 bolt, after placing the solid mounts bolts get short, u need longer This is the new bolt, M12 x 1.25, 85mm long, and get 2 washers for it All done and ready to install Going in ! |
#20 |
#21 |
Alright... i was having Temp issues so i did A LOT of mods to fix it !!
SOLVED: Issue was.. i was using Mechanical Temp gauge and wire was kinda close to the turbo so every time i hit the gas hard, turbo got hot and wire shows high temp reading to the gauge inside. i changed Water temp gauge for a Electronic and done (ay ay ay Julian...) ![]() so all these mods next were intended to fix the FAKE temp issues bought a new Radiator cap! higher pressure, nothing changed but i improved quality Went to the junkyard and got temp sensors and Volvo relays because they are the besttt got many sensors so i can chose which one has best low/high temp switch Setting Volvo relays + BMW coolant sensor (P/N 1378073) with 420 Flex a lite fans Sensor kicks FAN1 when hit 91c(195f) and kick FAN2 when hit 99c(210c) Champion radiator, i paid $110 eBay, is working awesome and has Lifetime warranty Bought some Water hose adapter (36mm) on eBay for $5, did a bigger hole and for M14x1.5 thread (bmw sensor) Part # 1 378 073 BMW Dual Temp 91c / 99c Volvo relays installed did a bigger Air Filter lower hole to get more fresh air (yes, thats a home A/C pipe but fuc* it) Wrapped Mechanical water temp gauge wire in heat shield tape because it was too close to the Turbo and Downpipe so i was getting wrong numbers Now modding Rad support to move radiators from Pushers to Pullers Welding piece of metal underneath to keep strength as u can see here Bending lip Finished Found these Radiator brackets at Junkyard from a Volvo 240 and i really like them to use i just need some mod to make them fit cut some rubber parts Volvo rad brackets are too long so i need to cut and make them short ok... lets cut these testing them short welding.. Done! both finished now i need them to look better primer, sand and paint next ![]() Now lets bring the beauty back to the radiator support Bondo ALL After sanding a lot to get same surface level Painting.... Done Ready to clear coat This clear is awesome, wish i had found this before you can be generous and it won't run ! Testing fitment Testing the volvo brackets Making moves, i mean holes.. and done! |
#22 |
All finished! Since i got the engine i was looking for these part, you from Ichiban JDM... Thank you a lot again !! ![]() Now it breathes more air and it looks way better Now is finished and working PERFECT finally actually..it worked perfect always, it was that Fake issue |
