04-27-2013, 08:42 PM | #91 |
Haven't done much to the car besides get in some parts and working on the a/c bracket
Getting close to having the prototype complete Got my Wastegate dump tube in yesterday as well Test fitted facing upwards for those days I go hoodless for maximum screamage Other random pics Got some fittings in as we'll for fuel
05-16-2013, 08:35 AM | #92 |
BiG MiKE's Little Build!
Disassembled AC compressor for the bracket until I finish my bracket
Turbo feed and drain done Finally painted the water neck and installed it New coolant pipe sits right on the firewall with the engine sitting as far back as it'll go. This pipe will be cut, shortened by 1/2"-1" and rotated upwards as well as having that smaller nipple welded shut. Got some chase bays goodies in - clutch line and power steering line kit. Sent from my iPhone using Tapatalk 2
05-29-2013, 05:47 AM | #96 |
Found my chase bays in bay brake line kit waiting for me today on my door
Going to start installing some stuff this week
06-04-2013, 11:33 AM | #97 |
looks good mikey just be sure to include a fitting/source for crankcase evacuation under boost. Such as from the turbocharger inlet, or even an exhaust scavenging setup (on the downpipe). You need some form of PCV if you want the engine to live a long healthy life putting down any kind of power. I would just go with a fitting on the compressor inlet and have it directed toward a non-check valved valvecover source. That way it always functions, but under boost when the 1-way check on the intake manifold (or valvecover) closes up, it still functions off the pressure drop before the compressor.
06-04-2013, 01:12 PM | #98 |
Hey nice build but I have a question about the harness
I'm confused on why they made a sub harness for the speed calibration unit? The speed sensor runs through the lower harness into the fuse box, then into the cluster. It shouldn't have anything to do with the engine harness. For the tachometer calibration unit I could understand because that input is taken directly from the engine harness. |
06-04-2013, 09:05 PM | #99 | ||
06-04-2013, 09:16 PM | #100 |
I'm asking because I am in the process right now of making my harness and I actually had the same idea, except I'll be adding a connector in the middle. Though the way I understand is for our cars the vss is not part of the engine harness.
06-05-2013, 07:02 AM | #102 | |
www.sikcustompaint.com They have a good selection of sick pearls for dumb cheap! $14.99 for 25grams (we only used 1/2 a bag for the bay) I thought the same thing but I guess Yury has magically worked it in for user friendly installation of the Dakota Digital Boxes
06-05-2013, 07:47 PM | #103 |
Did Yury give you a lower harness as well?
I think I have a theory on the way he wired up the speed calibration wires with the engine harness hope you don't mind me posting, because I was thinking of doing this myself. VSS sensor output --> lower harness --> connector --> into 2jz engine harness and through the firewall into the cabin --> input to Dakota unit --> output back out into 2jz engine harness back out the firewall --> same connector --> lower harness --> to fuse box --> into cluster with recalibrate speed So essentially it has nothing to do with the 2jz engine harness itself, but it just runs along part of it as a way of CONVENIENCE. Smart stuff, defiantly makes things easier and more neat than having wires going through the shifter hole. |
06-08-2013, 08:51 AM | #104 | |
07-24-2013, 06:51 AM | #108 |
Trader Rating: (33)
Feedback Score: 33 reviews
hurry up and finish the build so I can live vicariously through you since mine got scraped Keep up the good work bud everything is coming out real nice. That log mani will be tits for your setup.
07-24-2013, 03:13 PM | #109 | |
Hopefully ill get motivated this weekend and get some updates goin Sent from my iPhone using Tapatalk 2
07-24-2013, 03:48 PM | #111 | |
08-08-2013, 09:25 AM | #112 |
Long time since I updated this but there hasnt been anything done since then... lol
I wasnt having any success with the Xcessive engine/trans brackets so I ordered Get Nuts Lab engine and trans brackets as well as the matching steel 1 piece drive shaft thru Ace Up Motorsports (Awesome to deal with - spoke to Vitaly). So the brackets came within 3 days and boy did they look and feel much better than the Xcessive pieces (no offense to Rich whom has been awesome in dealing with and will be refunding my $$$ for the stuffs). These are different for each side - pics for reference incase anyone else has em and question which side is which. Blasted and prepped for primer and paint! Hit em with some self-etching primer and high gloss engine enamel Turbo Blanket I bought from a Zilvia member Hoping to swap out brackets this weekend. Ill be using my old SR nismo mounts and an MK3 trans mount with these brackets. FYI problems I had with the Xcessive mounts, engine brackets, trans bracket. -Hood wouldnt close -Engine mounts didnt sit flat on brackets -Trans bracket didnt line up well with trans mount (~1" off front front to back)
08-11-2013, 08:07 AM | #116 |
Time to lift the motor... again...
Swapped out all of the Xcessive parts for Get Nuts Lab brackets and Nismo Engine mounts... fit like a dream FYI anyone getting these brackets you will need hardware 8 - 10mm x 1.25 x 20-25mm hex bolts (engine brackets to block) 4 - 10mm x 1.25 x 20-30mm hex bolts (trans mount to body) 12 - 10mm Lock washers (I threw these in just incase) 12 - 10mm Flat washers (I threw these in just incase) Driver Side Passenger Side Transmission bracket (super Beefy) How the engine sits... pretty far back and nice and level Ill snap some pics of the oil pan height or w.e. anyone else wants to see next time im down there
08-16-2013, 06:57 AM | #120 | |
Installed Sikky Sway Bar and SPL Tension Rods Cut the GE coolant pipe and removed about 1/4" off so it wouldnt hit the firewall and ill be rotating the pipe upwards towards the head. Driveshaft should be here today as well
