![]() Join Date: Jan 2005
Tire PSI for Drifting
Just wondering what psi everyone runs for drifting at the track. Figured this might help get newbies started on some sort of car set up and possible have some other intermediate drivers try something new and learn something from it.
Please post up tire size, PSI used, and around how much wheel HP you're running. If you're on a stock motor, just say that. I'll start off Front: 255/35-18 32 psi cold Rear: 245/40-17 45 psi cold Around 195 whp. Might play with the psi a bit more though. |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
i like this idea.
when i was running my SOHC i was running: front: Falken ziex ze 195/50/15 PSI=32 Rear: Falken ziex ze 205/50/15 PSI=55-60 DOHC: front: Falken ziex ze 195/50/15 PSI=28-32 Rear: Falken ziex ze 205/50/15 PSI=40
![]() Join Date: May 2002
i run 40 to 60 psi
ive run 90 psi front are usually around 30some no more then 36 hot on AD07 feddies are same because they suck dick maxxis z1 drift can handle a 50-60psi no problem at all federal rsr did 90 all day and died of natural causes re01r run a 40 range ad07 rear run a 40 range all tires in rear are in a 245-275/18 sizes. |
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
PSI is very hard to dtermine. Many factors are involved. Track surface, temperature, Car setup, Tire Model, and the level of traction that a particular tire gives throughout the life of the tire.
Always good to start off about 5 psi that what is recommended for the tire, and then play with it throughout the track day. Mostly its less pressure if you are not gripping well. More pressure if its gripping too much. |
stock KA
front 215/40-17 usually around 35psi rear 214/45-17 usually around 40psi. I usually don't check the pressures...I only have a tiny little gauge that sucks and is hard to maneuver between the spokes.
![]() Join Date: Feb 2006
Trader Rating: (47)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 47 reviews
I always carry a tire pressure gauge with relieve valve in the car.
235/40R17 AD07 35-40 psi 235/40R18 595, RSR 30 psi Stock SR w/ S15 turbo stock boost and FMIC Will be trying out the Maxxis Victras soon. |
-stock sr20det redtop-
front- 215/45/17 @ 28-30 PSI rear-225/45/17 @ 38-42 PSI (9" wide rims)FEDERAL 595's but it DEFINETLY depends on the track, surface (smooth, rough or dirty), track temps and the track speed as well! I have a mini air compressor that I bring with so I can adjust through the day if needed. (One one the best parts I ever bought for my car!)
Tsuiso.Style @ Instagram Last edited by dino6192; 01-30-2009 at 03:17 PM.. |
![]() Join Date: Jan 2004
back when i was using an s13 w/ falken ziex 912s,
Stock SOHC F/R 205/50/15 40 PSI cold Currently on my s14 w/ Federal 595s, Redtop SR w/ boltons F/R 215/40/17 35 PSI cold. I usually try to aim for 40-45 hot.
![]() D-Street.net | bcuison.wordpress.com |
![]() Join Date: Jan 2008
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
STOCK SR
fronts-2055016 Dunlop Z1 star specs at 35pis cold and the take down no lower than 28psi, depends how car feels. rears- 2055016 GoodYear Eagle F1 at 40psi cold and no lower than 32psi But it depends on tire I use, when I run Nexen on rear I put at 32psi cold so I still have grip.
"ARE YOU ONE'EM SKID RACERS?"
I drove JXN's car last event and he has a stock black-top sr
don't know front but they were federal ss-595 rear nexen n3000 235-40-17 with 40 lbs of air cold and they spun great. All day I used like half the tyre and they spun awesomely
www.SonicMotor.com
![]() Join Date: Aug 2005
Trader Rating: (113)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 113 reviews
JXN's car aka devil's silvia(666):
stock sr Federal 595 F: 235/40/17 30-32psi R: 235/40/17 40-42psi <-- good smoke Or Nexens - cuz its free(wow-thats-a-cool-car) R: 235/40/17 40psi Nexens last forever, but dont grip for a dam. Good for beginners(like devin/wow-thats-a-cool-car) I suppose.
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK ) |
![]() Join Date: Dec 2006
Stock Single Cam KA24
WSIR Balcony Fronts: -Dunlop Direzza Star Spec Z1's -195/55/R15 -35 PSI Rear: -Nitto NT450's -195/50/R15 -45 PSI
![]() Join Date: Apr 2005
stock KA
front falken rt615 235/40/17 35-37psi cold rear federal ss595 205/50/16 whatever the guy at city tire put in it i think around 38-40psi cold I had trouble initiating on balcony using a 3rd gear clutch kick ... At the beginning of the day I was using some 205/55/16 BST radial tires at like 25-28psi (forgot to put air in after they sat in my garage) and I had no problems initiating but once I switched to my new pair of ss595s, I started having trouble and understeering. I should've tried upping the tire pressure in the rear to 45+ ![]()
#19 |
![]() Join Date: Nov 2007
Trader Rating: (18)
kat. est 200whp
Front yoko s.drive 225/35-17 30psi cold rear yoko s.drive 235/40-18 40psi cold. im no experienced driver, but from what little experience i do have, thats what worked. |
#20 |
Stock KADE
Kumho Ecsta SPT 225/45/17 Front 35 psi cold Rear 70 psi cold ---------------------- KA-T 249 wrhp Federal 595 225/45/17 Front 35 psi cold rear 45 psi cold |
#21 |
wow, after reading this thread I guess I'm going to have to step my game up this drift season. I neglect to adjust my tire pressures. Normally I just throw on the tire on the tire machine, and after sealing the bead I put them at 32ish lbs and throw them in the car. Good info
#23 |
stock ka24de (125 hp)
When I had dunlops: Fronts: 235/40/17 fm901 - 32 psi 235/40/17 direzza z1 - 36 psi (super grippy) Rears: 205/50/16 direzza dz101 - 50-70 psi (only at balcony just to make smoke and make it seem like I have an SR) - 35 - 40 psi (on rough surface like el toro, Camarillo airport) 225/45/17 - sp sport maxx- 35 psi (horse thief mile)
http://www.thenismoshop.com |
#24 |
![]() Join Date: Oct 2005
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
Stock SR20DET
Front: Dunlop Direzza DZ101 215/40R17 35psi HOT Rear: Nexen N3000 215/40R17 35-40psi HOT
www.realize-jp.net |
#25 |
![]() Join Date: Sep 2006
Stock SOHC
fronts are whatever tire, at stock pressure, 15-50-205 rears. Used tires, stock pressure, 15-50-195 on steelies. with Used tires, they are slick enough. Running fed 535's, 205 -15 -50, I ran 40lbs |
#28 |
![]() Join Date: Oct 2003
SR about 350whp
front 225/45-17 bridgestone re050a pole position 35 psi rear 235/40-18 feddies 40 psi some times run various bridgestone tires in the 225-255 range in a 17 also about 40 psi i generally run about 35-40psi hot in the rear no matter the tire being used seems to work the best for me |
#29 |
Stock KA24DE. I usually run a 215/40/17 usually R compound for control. about 30 psi.
Rear, 215/50/16 federal 595ss, nexen 2000/3000 series, nankang (gay tires), and now some falkens. In the rear it is always about 40 psi. federals at 50 cause they grip new. Run federals backwards for KA, they last all day, and don't grip as much. Tire pressure and grip is the most important in my book! Every time I test a car, that's the first thing I ask. |
#30 |
When I drove jxn's car (S13 SR), it was 55 psi in the rear...i was able to keep that car sliding no matter what, but it was harder to control.
FC'S (chows 250whp) usually have to have bigger tires less psi to grip...they just dont grip very well. for the front...really didn't matter.. about 35 psi so the car doesn't grip more in the front. |
