Old 11-26-2016, 12:38 PM   #1
kaytlin.240.love
kaytlin.240.love is an unknown quantity at this point
KA HELP!!! Fresh build knocking. Ka
Hey I have a fresh build ka-t right now I have it n/a to break motor in. It ran great it idle for about 10 mins then started knocking, sounded like bottom end, I shut motor off immediately.. more about build below
Je pistons 9:1 ratio, Manley rods, clevite bearings, new crank, arp studs and bolts, balanced rods and crank by machine shop. Head got cleaned and polished and valve spring retainers replaced, everything is cleaned really good, block bored 20 thousandths over(pistons match new size to bores) however I did not replace oil pump or water pump (looked fine, now thinking I should anyway). I am getting an adapter so I can fit the oil pressure gauge and see what it reads. I was told it may either be oil pump or clearances in the motor of like bearings maybe. Just need help, opinions and such thank you.
kaytlin.240.love is offline   Reply With Quote
Old 11-26-2016, 01:11 PM   #2
lunchmeat
lunchmeat's Avatar
I'd start draining oil, pulling the pan, and checking the filter for metal bits.
lunchmeat is offline   Reply With Quote
Old 11-26-2016, 10:29 PM   #3
jedi03
have seen ignition sound like knock too...
Old 11-27-2016, 02:28 AM   #4
Kingtal0n
Kingtal0n's Avatar
its hard to build an engine. I pray you got it right but the fact is, many fail after 15 or 150 miles. You might be joining the club.
Some random low mileage failures,
#/f/showthread.php?t=535520
#/f/showthread.php?t=569861
#/f/showthread.php?p=5765974
#/f/showthread.php?t=579996
#/f/showthread.php?t=586960
I stopped keeping count
https://tinyurl.com/turbo240
Old 11-28-2016, 08:50 AM   #5
KAT-PWR
KAT-PWR's Avatar
My first bet would be oil pump
2nd bet is incorrect bearing clearance
MRP Manufacturing
Old 11-28-2016, 09:19 AM   #6
thegr8one013
thegr8one013 is an unknown quantity at this point
i see you wrote new crank? where did you buy this new crank? was it a cut crank? and did you check bearing clearances before it was put together?
thegr8one013 is offline   Reply With Quote
Old 11-29-2016, 06:26 AM   #7
kaytlin.240.love
I am hoping it is oil pump, is there a way to tell it's bad by taking it off and looking? Also I bought the crank from a machine shop and it was "stock specs" I took a micrometer to the journals to see if sizing was right and the same all across and it was but I didn't plastigauge bearings or anything. Now that I know a bit more than I did back then I should have plasti gauged it
Old 11-29-2016, 07:06 AM   #8
TheRealSy90
TheRealSy90's Avatar
You would have had to plastigage it to order the correct bearing sizes no?
Such a good signature.
Old 11-29-2016, 07:51 AM   #9
jedi03
not necessarily...properly measuring beforehand and ordering correct size bearings can work too...plastiguage is a new way to measure for people who don't know how to properly use a micrometer
Old 11-29-2016, 08:03 AM   #10
lunchmeat
lunchmeat's Avatar
Bore gauge, micrometer, and math.
Old 11-29-2016, 08:35 AM   #11
KAT-PWR
KAT-PWR's Avatar
No. plastigauge is useful for a quick double check after the parts have been purchased. There are stampings to specify bearings (roughly measures journal to bearing clearance). Usually you would measure the journals of the crank, then use a bore gauge on the block/girdle and rods to determine bearing size for desired clearance (correct way)
Subtract journal size from rod bore, then subtract desired clearance and that will give you the remaining bearing width/clearance necessary for your selected tolerance.
MRP Manufacturing
