![]() Join Date: Sep 2012
FS S13 Sr20det blktop drivetrain partout,gt2871r,tomei header,750ccinjectors,more....
I had this motor rebuilt very recently and got rod knock after a couple hundred miles of driving. I'm parting out the entire drivetrain and some other stuff for sale. Located in San Diego. 860-605-zero288if its not listed, its probably sold..... but feel free to ask anyway .... i got lots of random stuff .... will post as i find Hooker trans mount bracket for t56 in s13 $70 s13 blktop sr20det head $400 recently had valve job and shaved/resurfaced shimmed ready to go bc 0.5mm oversized valves, bc valve springs, oem spring retainers, oem cams, new lifters, new rocker arms, new supertech valve stem seals and valve guides s13 sr20det block $150 crank is no good s13 sr20det head $200 no cams, no rockers, caps included, has bent valves, needs rebuild arp main bolts $80 used only a couple hundred miles wiring specialties harness for s13 sr20det redtop $300 for aem ecu, aem map sensor, gm iat sensor, gm coils (oem ignitor removed) injector connectors missing (sold with id2000s) s13 sr intake manifold $50 s13 sr throttle body $30 sr ignitor chip $20 gt28 turbo outlet elbow $40 gt28 turbo downpipe $50 s13 fan shroud $20 sr motor mount brackets $50 sr coil packs (2 sets) $40 each Last edited by AcceleratedMinds; 02-18-2015 at 09:47 PM.. |
dluevanos01
pmd u genecan the turbo will be out this week pics up soon angel mkiv im not sure supertrogdor its a real greddy edmsil80 not sure san diego |
