Old 06-07-2008, 02:20 PM   #1
clips
clips has made poor choicesclips has made poor choicesclips has made poor choicesclips has made poor choicesclips has made poor choicesclips has made poor choices
Injen intake on sohc ka24
I am having some fitment issues on the install
First off are you supposed to cross these two hoses which are located on the left side near the intake manifold? It seems like the notches are flipped around
Second is the mounting for the fan shroud. It is off by a half inch or so
Third is the hose from the engine located on the right side of the intake near the manifold
Sorry for the shitty pics
And finally the PAIR valve hose is way off
clips is offline   Reply With Quote
Old 06-07-2008, 02:23 PM   #2
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
cross the hoses and flip the hose inlet around if you can next to the filter. It should be held together by 4 nuts. Drill another hole in the fan shrowd.
Your going to have to fab it together.
Marc240 is offline   Reply With Quote
Old 06-07-2008, 02:25 PM   #3
clips
I assume I'm gonna have to go to autozone and pick up some hoses to reach the PAIR valve as well
Old 06-07-2008, 04:16 PM   #4
clips
Ok well I figured everything out but now i hear what seems to be grinding in the intake manifold when i rev the engine past 3000 and it happens when I let off. I didnt notice it before and it doesnt seem like the intake would create that problem.
Would pinching off the PAIR valve cause this?
Old 06-09-2008, 06:41 PM   #5
projectRDM
projectRDM's Avatar
Rotate the MAF adapter to reach the PAIR hose, but having it off will cause a vacuum leak. You can just plug the pipe and remove the AIV system entirely.
FORMERLY R240NA
Old 06-09-2008, 07:31 PM   #6
jrbump
jrbump's Avatar
jrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond repute
Not worth the trouble.
jrbump is offline   Reply With Quote
