Old 04-26-2005, 12:48 AM   #1
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
KA KA24DE valve seals
can these be replaced with the head on the block? Ive never taken apart any valvetrane components before so I dont know if there's any pro-tips i should know.
neilsan is offline   Reply With Quote
Old 04-26-2005, 08:31 AM   #2
usctom
usctom is an unknown quantity at this point
They could be done with the head one just have to make sure the valve doesnt drop. Then you will have to take it off anyways.
Tom
usctom is offline   Reply With Quote
Old 04-26-2005, 11:37 AM   #3
AzNCmB
AzNCmB's Avatar
AzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond repute
Send a message via AIM to AzNCmB
yea, you can do change these out with the head still on the block, from what i was told by a mechanic, you would have to use an air compressor and have a fitting inside the spark plug holes and keep air in each cylinder so that the valves wont drop while ur taking retainers and stuff off to get to the valve seals....
if i'm incorrect, someone please correct me...thanks
AzNCmB is offline   Reply With Quote
Old 04-26-2005, 12:13 PM   #4
usctom
yeah u would need to use a compressor.
Old 04-26-2005, 04:31 PM   #5
orion::S14
orion::S14's Avatar
orion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to behold
Another trick I've seen for us shade-tree mechanics is to fill the cylinder with string when it not at TDC...then turn the motor over to TDC on that cylinder, and the pisont will go up, stuff the string against the head, and hold the valves in place.
As for pulling the valve springs...it'll be quite hard to compress the springs without the Nissan tool for it, so I reccomend AT LEAST that tool. Doing it by hand is damn near impossible, and unsafe.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 04-26-2005, 06:34 PM   #6
neilsan
Haha, the string idea is awesome. its probably what i'll end up doing cuz the only fitting I know of threaded for spark plugs is my compression guage and Im not so sure i can adapt it to my hose.
Thanks. I'll look into that valve spring tool if my dad doesnt have something adequate.
