Old 07-10-2008, 08:13 PM   #1
lazymbf
lazymbf is an unknown quantity at this point
Thumbs up S13 Origial Rear Caliper Replacement
Hi, currently I found out one of my 92 240sx Driver Rear caliper stuck retract after brake pedal release sometime. i don't have $$$ for upgrade now, just wondering what other cars' Driver Rear caliper is interchangeable with the it because junk yard has a few 240sx, just in case those are bad too. Thank you so much for help.
lazymbf is offline   Reply With Quote
Old 07-10-2008, 08:20 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Post a WTB ad here on zilvia, you'll find one that somebody wants to get rid of for cheap.
racepar1 is offline   Reply With Quote
Old 07-11-2008, 12:54 PM   #3
lazymbf
thanks for the input raceprt1. If i want get them from junk yard, do you know what car i can get it from?
Old 07-11-2008, 01:38 PM   #4
apex
apex's Avatar
Trader Rating: (44)
apex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond reputeapex has a reputation beyond repute
Feedback Score: 44 reviews
hey i got 180sx calipers and rotors for sale lmk if u want them
they are bigger then 240sx calipers
Red Rocket
apex is offline   Reply With Quote
Old 07-11-2008, 01:47 PM   #5
projectRDM
projectRDM's Avatar
No they are not. He is asking about rear, not front.
To the OP - any 89-94 240SX rear caliper is a direct replacement.
FORMERLY R240NA
Old 07-11-2008, 02:14 PM   #6
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
ive had 2 s13 and both one side of the rears never work with ebrake.
was it like that? or my shit gay!
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 07-11-2008, 09:09 PM   #7
lazymbf
my ebrake is working, sometimes it stuck after i release the brake pedal. I will check out the junk yard for 89-94 240SX. thanks guys
Old 07-11-2008, 09:16 PM   #8
95Kouki
95Kouki's Avatar
95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough
be care fully....the ebrake cable ends to vary from chassis to chassis...verify before purchase
People will always be haters...can't change that...just out drive them
95Kouki is offline   Reply With Quote
Old 07-11-2008, 09:17 PM   #9
iluvpandas4
iluvpandas4's Avatar
iluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfection
Send a message via AIM to iluvpandas4
..Are you saying your calipers are frozen? If so why not rebuild (thats if you have some sort of access to an air compressor), way more inexpensive than replacing them.
'92 240sx Coupe
iluvpandas4 is offline   Reply With Quote
Old 07-11-2008, 10:31 PM   #10
lazymbf
thanks for the input 95kouki, and iluvpadas4. thanks for reminding me to rebuild it, i check the price is aound $25, but not including the piston, i remember the piston is rust. can i just sand it with sand paper? thanks guys
Old 07-11-2008, 11:01 PM   #11
iluvpandas4
Are you checking the rebuild kit prices at the dealership? You should be able to get one with everything you need for one caliper for between 5-7 dollars at Advanced Autoparts or NAPA. I don't recommend sanding the piston though cuz that can really ruin it although I know people who've done it successfully. I'd just replace the piston if it's really rusted bad. But if you have just a few rusty bulges here and there then soak it with brake cleaner and pick it off carefully with a dental pick, making sure not to scratch the piston too much. I did a write up specifically for rebuilding OEM S13 calipers. PM me and I can send it to you.
'92 240sx Coupe
Old 07-11-2008, 11:26 PM   #12
lazymbf
i check the advance autoparts website, there are 2 of them, one is for $5, Part Number: D352027, and that comes with seal. Another one is $25, Part Number: 0717835, and it comes with more stuffs inside. You think i can just get the $5 one is fine? Thanks iluvpandas4.
Old 07-11-2008, 11:31 PM   #13
iluvpandas4
Yea you only need the dust boot and bore seal which come in the $5 kit. The other stuff are the caliper bolt and pins, bushings, etc. $5 one is the same exact one I used to rebuild my calipers and works like I got new calipers. Let me know if you need get stuck.
'92 240sx Coupe
Old 07-11-2008, 11:32 PM   #14
projectRDM
projectRDM's Avatar
Hence the notation to use 89-94s only. Same chassis.
FORMERLY R240NA
Old 07-11-2008, 11:37 PM   #15
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
PM sent I want it too.
+1 thanks for that
hotlavaflow is offline   Reply With Quote
Old 07-12-2008, 12:03 AM   #16
lazymbf
thanks for the input, i will order it tomorrow. i will post the results. thanks again
Old 07-23-2008, 08:24 PM   #17
lazymbf
so, i did the rebuild on both side, the Left side piston is stuck, i can't turn the wheel after i rebuild, right side is good, so i think i need to go to the junkyard and grab another driver rear caliper and rebuild it.
Old 07-23-2008, 08:27 PM   #18
LongGrain
LongGrain's Avatar
i would go to autozone and get some remanufactured calipers. after you turn in your cores they arent that expensive, then you have practically brand new rear brakes.
thats what i did anyway.
LongGrain is offline   Reply With Quote
Old 07-23-2008, 08:34 PM   #19
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
If your cheap just get a shit ton of grease and grease all the moving parts, that what i did and it worked great after that IMO
WangonwWarrior is offline   Reply With Quote
Old 07-23-2008, 10:15 PM   #20
lazymbf
thanks for the inputs
Old 07-23-2008, 10:22 PM   #21
silviaguy240
silviaguy240's Avatar
yea just auto zone it and core exchange, ends up being like $60 and its a brand new caliper.
Old 07-23-2008, 11:01 PM   #22
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Thats what I did. Works great =]
DataXUnknown is offline   Reply With Quote
