Old 06-09-2012, 09:23 PM   #1
Milly
Milly is an unknown quantity at this point
battery relocate?
Okay so i've searched and all of the guides don't have pictures anymore because they've expired or something....
I just had one question, I cut this positive wire going to terminal, all i need to do is hook my new cable that runs to the trunk to it right? So basically sodder the 3 wires together and it'll be good? (plus ground it etc..)
Thanks a ton!
Milly is offline   Reply With Quote
Old 06-09-2012, 09:26 PM   #2
mantas
mantas's Avatar
mantas is an unknown quantity at this point
Solder then crimp is what i did. But since i used thick solder i had to bust out the torch. Make sure you use a 0 gauge wire, i thought id get away with something smaller and my car would not crank sometimes. Switched to a zero and was good to go. As long as the wires you have indicated in your pic gp to the positive terminal - solder/crimp and you should be fine.
mantas is offline   Reply With Quote
Old 06-09-2012, 09:27 PM   #3
chuki.s13.coupe.
chuki.s13.coupe.'s Avatar
chuki.s13.coupe. is an unknown quantity at this point
Pretty much. Just be sure to run a fuse or circuit breaker.
chuki.s13.coupe. is offline   Reply With Quote
Old 06-09-2012, 10:01 PM   #4
Milly
How would I crimp 3 wires together at one spot?
And cool thanks yeah I was just wanting to make sure that was right... I'll be running a 100A fuse a couple feet from the battery.
Old 06-09-2012, 10:57 PM   #5
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I think your concept is good, however are you also going to be running a kill switch with this setup or no? May be worthwhile to google a diagram to compare to make sure you kill alternator and battery power.
Old 06-10-2012, 08:07 AM   #6
Milly
I didn't plan on running a kill switch as I thought that was only worth wile for track inspections, etc...
You think I should?
Old 06-10-2012, 09:03 AM   #7
chuki.s13.coupe.
You think I should?
Not unless you need it.
Old 06-10-2012, 10:56 PM   #8
Milly
I realized its pretty hard twisting 3 4 gauge wires together and soldering it... I got it thought I think
Old 06-10-2012, 11:35 PM   #9
mantas
mantas's Avatar
To be honest i would just do what i did, crimp each one to its own connector and slap them all on the fuse box positive terminal. I tried crimping all and it was sketchy.
Old 06-10-2012, 11:55 PM   #10
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
Get a power distribution block. I got mine from a e30 BMW from the junk yard, and they have a long battery cable about 13 feet that I used its 00 gauge so it's more than enough as it cost less than 10 bucks
NEED Bolt kits for your car?
Old 06-22-2012, 08:50 AM   #11
Andres_G
Andres_G's Avatar
Andres_G is an unknown quantity at this point
Get your self something like this,
Distribution block
100A circuit breaker
Andres_G is offline   Reply With Quote
Old 06-22-2012, 01:58 PM   #12
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
so you used a 0 for the positive and 0 for the negative? I was about to just use 2 for positive and 0 for negative.
zneubauer is offline   Reply With Quote
Old 06-22-2012, 02:32 PM   #13
mantas
mantas's Avatar
It might work. My engine would crank but not fire with 2 on the positive side, and fired right up with 0. My friend suggested it was because of the distance from the battery to the fuse box .
