07-11-2008, 11:59 PM | #1 |
Should I replace my chain?
i just replace my valve cover gasket and this is what i find out.
well, i didn't install the chain guide as people mention in this forum, i just concern about the chain condition. Do i need to replace it? Thanks for the input. |
07-12-2008, 12:23 AM | #3 |
as a rule of thumb change your chain every 80,000 miles. slop in your chain will change your timing and affect your performance. i'm not sure if the KADE is an interference engine or not but if that chain goes so does your entire head assembly.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
07-12-2008, 12:31 AM | #5 |
My chain looked like that. Your tensioners are most likely just gunked up with old oil deposits. I just sprayed some WD40 on mine, and pushed them in by hand until they moved freely. |
07-12-2008, 02:24 AM | #7 |
^Yes. Pull the upper front cover to pull the other guide out and make sure the upper tensioner isn't stuck.
Theres a lower tensioner as well, but its alot more work to get to that one, so try your luck with the upper ones first. lol |
07-12-2008, 01:14 PM | #9 |
i used to build racing fourwheelers and i would seem to go through atleast one chain with every bike. they were prone to stretching out over time , jumping timing and putting valves into the the piston.
if you really want to have peace of mind i would just change it. then again these arent race bikes and sr timing chains are bulkier so i doubt theres any problems... |
