Old 11-07-2008, 03:13 PM   #1
S14TEENZ
S14TEENZ's Avatar
S14TEENZ is an unknown quantity at this point
s14 In need of fenders rolled!!
I need to get my fenders rolled... my wheels rub when i hit little bumps in the road and it driving me crazy...also before i destroy tires...i live in maryland so if anybody local willing to point me in the right direction..
also help from anybody for pricing to get ur fenders rolled would help before i get my eyes poked out with a price but yea i have a S14 LMK....
THANKS
S14TEENZ is offline   Reply With Quote
Old 11-07-2008, 06:28 PM   #2
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
y not try to goto local tire shops they may have Fender Roller usually costs about 50-100 bucks for all 4
gijoe69 is offline   Reply With Quote
Old 11-07-2008, 07:01 PM   #3
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
why dont you do it yourself? its easy peasy.
PEGASUS
nismo racer is offline   Reply With Quote
Old 11-08-2008, 10:37 PM   #4
iloveturbos
iloveturbos's Avatar
iloveturbos is an unknown quantity at this point
fender rolloin
u need a small or large wood baseball bat ...then wedge that moterfucker in the wells and roll that shit ..dont be scared and dont flex the front too much ..take ur time it dont take 2 long
iloveturbos is offline   Reply With Quote
Old 11-09-2008, 06:33 PM   #5
dbenavides
dbenavides is an unknown quantity at this point
I live in northern va and I have an Eastwood Fender Roller. I can do all for corners for $75.00 if you help me. I did my S14 and they turned out perfect. Let me know if you're intrested. [email protected]
dbenavides is offline   Reply With Quote
Old 11-11-2008, 10:13 PM   #6
ZipTied
ZipTied's Avatar
ZipTied is an unknown quantity at this point
Why not use newspaper?? That's what I did and to me it makes the best possible fitment possible IMO. Take the hub off the strut and move the strut aside. Lay down an inch or so of newspaper over the tire and drop the car down. Do this until the desired roll is acuired. Using a baseball bat or fender roller is a good route too. But watch that you don't get to close to the gas tank. Only do whats needed otherwise you risk denting the quarter were it is not as scructurly supported.
ZipTied is offline   Reply With Quote
Old 11-11-2008, 10:35 PM   #7
!Zar!
!Zar!'s Avatar
You don't roll tires with newspaper...
From one of my threads...
Originally Posted by !Zar!
Figured out I'll hook you all up with some tips/tricks on how to make your car less retarded in the wheel fitment category.
The PROPER way to do it is:
All work is done with a Eastwood fender roller.
1. Clean out the fender and lip that will be rolled.
2. Make sure you don't need to extend the coilover/disconnect it from the shock if your car is too low.
3*. Place blue painters tape around the area that will be rolled.
4. Heat the area that will be rolled to 120f~
5. With a Decent amount of angle in the roller head start slowly applying pressure to the lip so it can start to be pushed it.
6. Once the lip is up, straighten out the head.
7. Slowly start rolling from left to right, and adjust the roller in 1/4 increments. If you roll too fast, you might buckle the area around your roll.
8. Once finished, find a way to measure the angle of the roller.
9. Repeat on other side to the same angle of the other side and remove the painters tape.
10. Fuck bitches.
*Though I say to use painters tape while heating it to 120, I haven't tried burning the tape on the paint, "duh". But it will work and help control damage to the paint as long as you do as I say. The tape can also indicate if you are heating any particular area up too much by the tape starting to distort.
BONUS!!!
Since everyone is in SO much need to use the newspaper shit, what you are supposed to do is already have your fenders rolled.
1. With the rear off the ground, disconnect the rear shock.
2. Place 1/4in of a playboy mag, tranny's weekly, newspaper, whatever you have, all around the top of the tire.
3. Jack the wheel up/lower the car with the shock disconnected.
4. Lower jack and check for clearance.
5. Add more newspaper if fit isn't satisfactory.
6. Do same on other side.
7. Proceed to fuck more bitches.
Old 11-11-2008, 10:45 PM   #8
ZipTied
ZipTied's Avatar
Good tips. I used news paper and it worked out fine. The fender roller works great too though.
wheels fender roller tuck
