Old 08-07-2009, 08:09 PM   #1
bigjacsoc
bigjacsoc is an unknown quantity at this point
Exclamation Major steering wheel wobble after aluminum steering bushing install
Video:
http://s266.photobucket.com/albums/i...t=100_1376.flv
I installed an aluminum steering bushing (the one that goes in the firewall) along with Energy Suspension rack bushings. The rack bushings went in smooth because I had the engine out and replaced the rack with one that isn't cracked. I got it all bolted up and checked that the knuckle where the column meets the rack had the bolts perfectly centered where they would pass in between the 2 sets of splines smooth.
I turned the passenger side wheel to make sure it was all good, and first I notice that the steering wheel is wobbling like crazy up and down, and after that I noticed that the part that sticks off the rack and has the splines was moving back and forth and is causing the whole rack to rotate inside the bushings.
After this I took the upper bolt that holds the column splines in place and turned the wheel and saw that the splines were sliding in and out of the knuckle and also that it looked as though the column wasn't going in a straight line from the steering wheel and is slightly crooked.
Anyway, has anyone done this aluminum bushing install and had this problem? If you have and this didn't happen please let me know. My motor is going in on Monday and pretty much NEED to get this resolved before then because of the lack of space to operate with the motor in. If you have not experienced this problem I will have to take the column out and see if I put one of the 4 little metal bushings crooked when putting them into the bushings.
Also I can get a video if you cannot understand the situation.
All help is appreciated, thank you.
bigjacsoc is offline   Reply With Quote
Old 08-07-2009, 08:16 PM   #2
bigjacsoc
Cliff Notes:
I installed an aluminum steering bushing and now my steering wheel wobbles horrible and the splines move in and out of the knuckle on my rack. Is the column crooked, or does it just do that?
Old 08-08-2009, 12:04 AM   #3
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
You used the aluminum rings that were originally on the rubber spacer?
Did you make sure to tighten down the bolt that clamps the splines to the rack?
I had a little wobble on mine for some reason. I wish I could be of more help, but I got rid of my car a while ago.
Old 08-27-2009, 03:31 AM   #4
kalypso123
(ノಠ益ಠ)ノ彡
Originally Posted by bigjacsoc View Post
Cliff Notes:
love the cliff notes... perfect
Old 09-11-2009, 10:08 AM   #5
khoadogg
khoadogg's Avatar
khoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of light
Send a message via AIM to khoadogg
solved? I forgot to put in the metal "batman" things on the spacer but it's hard to remove it and reinstall it
AIM SoarinStrong[B]STRONG 6iX[B]
RB single turbo ///Work AMKREAD 180sx
khoadogg is offline   Reply With Quote
aluminum, bushing, column, problem, steering
