Old 11-16-2012, 12:19 PM   #1
hatch guy18
hatch guy18 is an unknown quantity at this point
KA ka24de swapped bmw, no power to coil. help!
Hey guys iv done a swap in my e30, its got a ka24de swap, 5 speed. I've got power to my ecu using pins 46, 47, and 38 constant power. And ecu is grounded through pins 48, 39 direct bolted to frame rail.
I can't seem to get power to the coil now, I tried just arching the coil lead wire to the distributer on a peice of raw frame rail, no arch at all.
The whole setup will be on push button start, and toggle switches.
Is thier something in missing to get power to the coil? Please help if possible.
hatch guy18 is offline   Reply With Quote
Old 11-17-2012, 08:25 PM   #2
hatch guy18
All these views, and not one reply..... Come on guys.
Old 11-18-2012, 10:05 PM   #3
onevia drift
onevia drift's Avatar
Trader Rating: (18)
onevia drift is an unknown quantity at this point
Feedback Score: 18 reviews
Have you thought about running a 12v through a switched relay.?
Run a 12v power to relay, switched signal to relay to feed 12v to coil.. Could work
onevia drift is offline   Reply With Quote
