Old 10-20-2008, 04:55 PM   #1
newagedrift
newagedrift's Avatar
newagedrift is an unknown quantity at this point
Will this work as an oil cooler?
I was just wondering about something. Ive got an automatic radiator in my car so its got the cooler lines for the auto tranny. Is it possible to run the oil through the tranny cooler lines in the radiator to act as an oil cooler?
Only issues I can think of off hand is maybe viscosity would be different. I dont really want to try to hook it up and fuck my motor. Its more of a hypothetical question I guess, Ill have a new radiator before too long anyway.
newagedrift is offline   Reply With Quote
Old 10-20-2008, 08:09 PM   #2
Nismo240SX
Nismo240SX's Avatar
Nismo240SX is on a distinguished road
Send a message via AIM to Nismo240SX
wouldn't suggest it.
1990 Nissan 240sx:s13 blacktop, s13.5 front
Nismo240SX is offline   Reply With Quote
Old 10-20-2008, 08:12 PM   #3
projectRDM
projectRDM's Avatar
No. The cooler in the radiator is very shallow and thin, it doesn't leave a lot of room for proper flow since oil at any grade is a higher viscosity than ATF. Secondly the inlet/outlet aren't big enough, you'd need to put larger hose barbs on and run bigger hoses to them. Lastly the oil is under more pressure than the transmission fluid, regular hose clamps would leak like hell.
FORMERLY R240NA
Old 10-20-2008, 08:13 PM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
It works great as a power steering cooler, but NOT an oil cooler.
racepar1 is offline   Reply With Quote
Old 10-20-2008, 08:16 PM   #5
projectRDM
projectRDM's Avatar
Agreed. It's running ATF anyway, ditch the cooling loop and run it straight in from the reservoir and rack.
FORMERLY R240NA
Old 10-20-2008, 08:19 PM   #6
racepar1
racepar1's Avatar
I kept the loop in mine as well, just too lazy to remove it and I really didn't see a point to removing it.
