Old 11-01-2008, 10:28 AM   #1
jt1583
jt1583 is making a name for him/her selfjt1583 is making a name for him/her self
lapping block in car w/ steel block? HG install
engine : ca18det
Ok I'm reinstalling a headgasket (new one of course) since after the last one (done 3 weeks ago) I am leaking from the hg. I have had the head resurfaced and read on a website about taking a flat, steel block to lap the block. it said something like...
get a flat steel block (grinding at machine shop)
put 400 grit sandpaper around it securely
go in a back and forth motion across the block
It didn't say anything about when to stop, I'm assuming to use a straight edge and feeler gauges. I don't think its warped/out of spec so much since it's an iron block, but mainly to clean it up and remove any scratches.
What do you all think?
jt1583 is offline   Reply With Quote
Old 11-01-2008, 10:40 AM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
I've never had to re-surface a cast iron block to do a headgasket. I wouldn't do it. Did the gasket blow REALLY bad or something? Or are you just upgrading the gasket? If the headgasket blew up hardcore I would check the block with a straight edge, if it didn't I would just clean it and put it back together.
racepar1 is offline   Reply With Quote
Old 11-01-2008, 10:42 AM   #3
Sileighty_85
Sileighty_85's Avatar
What Brand H/G Blew? And what brand are you putting on?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-01-2008, 02:34 PM   #4
jt1583
it didn't blow its leaking oil from the back of the engine, exhaust side. Ride where the oil is fed to the head.
I think its either the gaskets fault, or a non resurfaced head.
I'm not sure, the gasket looked fine upon removal.
Torque was done correctly then redone after 1 heat cycle
Old 11-01-2008, 03:54 PM   #5
jt1583
I believe this is the cause of my oil leak. Background, oil was leaking between the head and block, exhaust side, very back. Slow leak, but it was there.
Here is the oil passage way.
I can get my fingernail caught in the scratch if I rub over it, so I do not think it's trivial. I may end up doing this ghetto lapping of the block to avoid engine removal and disassembly required to get the block machined by professionals.
Opinions?
Old 11-04-2008, 03:55 PM   #6
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
i thing you should get your block resurfaced and port out the oil passages if you can, deep scratcheds and stuff like that cause heat stress areas that can cause problems in the future. after hg install check oil pressure.
redline racer510 is offline   Reply With Quote
