Old 04-14-2014, 04:40 PM   #1
quickdiversion
quickdiversion is an unknown quantity at this point
NJ 13.5 build, long over due.
I have been on this site for some time now and have not put up a build thread. Figured I would give it to you guys now. This was over 4 years and counting.
I am pretty sure this is the most up to date mod list:
Rear suspension;
lower tie brace, gtspec
lower A-arms, godspeed
lower toe arms, godspeed
upper camber arms, godspeed
upper traction arms, godspeed
sway bar, godspeed 28mm
sway bar linkage, megan racing
soild rear subframe bushings, DIF
rear axle housing bushings, nismo
adjustable coilovers, godspeed
Front suspension;
Lower Control Arm, godspeed
Lower pillow arm, godspeed
sway bay, godspeed 30mm
Steering;
330MM steering wheel, Sparco
KA24DE power steering lines and reservoir swap
Inner tie rods, tein
Soild outter tie rods, tein
tie rod boots, nismo
Brakes;
rear R32 5-lug swap
front S14 5-lug swap
R32 GTS-T calipers front and rear
300zx 2+2 e-brake cables
Cross drilled and slotted rotors
Ceramic brake pads
Z32 to S13 conversion steel braided lines for brakes
300zx master cylinder
Body;
S13 to S15 conversion fenders +30mm over, Charge Speed
rear over fender FRP composit +50 over, Duraflex
rear bumper, Uras Type S
S15 front bumper, Charge Speed
Vented skirts, cut, shaved, and fitted for flush mount, FRPkits
S15 headlights, OEM
Wheels;
Rota P45R 18 18x9.5 +12 all around
Tires;
275/35ZR18 99W, Nitto NT05 all around
Engine; Top end;
chemically cleaned
Full port and polish
gasket matched intake and exhaust
rocker arm stoppers, Greddy
solid lifters, tomei
cams 270 in 270 out 12.5 high lift, tomei
adjustable cam gears, tomei
type A single springs 12.5 high lift, tomei
3 angle valve job, and ressed valves
Valves were unshrouded for better breathing and combustion
decked flush
new timing chain tensioner, oem
polished intake plenuim gasket matched, greddy knock off
321 steel mandral bend exhaust manifold.
cold spark plugs, NGK 8
1.2mm metal headgasket, Cometic
Turbo setup;
HX35 7 blade turbo from 2002 dodge cummins diesel
CRX forward mounted top mount manifold
-6 AN oil inlet feed
-10 AN oil outlet
Flap welded shut for external wastegate
Tial external watsegate 18PSI spring weight
Exhaust;
3in downpipe
3in tespipe
3 1/2in exhaust, HKS HiPower
Computer/Electronics;
NIsmotronic (To Be)
LS2 Truck coil packs w/ individual ignitors
Cooling;
3 core racing radiator, Megan
low temp thermostat, Nismo
Raditor hoses, Samco
s14 raditor neck with turbo line inlet, oem
2 core intercooler and kit, Greddy
coolant lines redirected cut and fit for left hand drive
Drivetrain;
1 pc short shifter, Megan
1 pc steel driveshaft, Driveshaft Shop
180sx rear pumpkin 5 bolt axles, oem
2-way diff, Kaaz
Fuel Delivery;
280L/pr hour fuel pump, Sard
Fuel pressure regulator, Sard regular type
Fuel Pressure Setting Meter, Sard
1000cc top feed injectors, Injector dynamics
Upgraded fuel line sizes from 1/4 in to 5/16 in inner diameter
Fuel pump independently rewired for 14.7 volts
Currently running 55psi fuel pressure
quickdiversion is offline   Reply With Quote
Old 04-14-2014, 05:45 PM   #2
quickdiversion
That is pretty much the condition it arrived in and I started with. There are a few pictures of the Rear over fenders being installed and the blending started.
Next update of pictures is rust removal and clean up..
After all the rust was removed and metal replaced (sorry I thought I had more pictures of all of that) Pictures of the car and body work all coming together.
Sorry the pictures are a bit out of order. These are older from my photo bucket.
Old 04-14-2014, 05:54 PM   #3
quickdiversion
Here is time for one of the most fun updates. The engine!
It is a stock bore and stroke S13 SR20DET. The crank has has 2 pounds shaved off the crank and the pistons, rods, flywheel, clutch, pulley; basically the bottom end rotating assembly has been fully balanced to itself, no need for a balancer...
Old 04-14-2014, 06:01 PM   #4
quickdiversion
Top end is a little more exciting.
Its has been fully cleaned and port and polished out of eddie's in sayerville NJ. The squelch pads have been removed and the valves unshoruded for better breathing. The intake track and exhaust have been gasket matched. 3 angle valve job, new valve guides, which have been trimmed flush with the intake tracks. 260 in and out cams 12.5 high lift. Adjustable cam gears. Solid lifters, and yes they have been fully shimmed.
Old 04-14-2014, 06:13 PM   #5
quickdiversion
Here are some finished up pictures of the car. Don't be afraid to ask questions!
Oil filter has been relocated to under the water inlet plumbing for easy access and the oil cooler is mounted in front of the radiator and behind the intercooler.
Here are a few more pictures of the car being finished up and cleaned up.
Old 04-14-2014, 06:19 PM   #6
quickdiversion
So fast forward 2 years and some months and I traded in a few of the older parts for some newer bigger better parts
I have moved up from 260 to 270 cams
and sold off the 740cc nsimo injectors and went with 1000cc ID's
The GT2871r is gone and I am now running an HX35 7 blade, external wastegate
The power FC and datao logit are not gone, and I am moving onto Nismotronic.
Gonna love me some anti-lag and launch control
Oh I have also junked the stock coil packs which were giving me spark blow out at 13 psi and around 38lbs of air per minutes, which is not gonna cut it for 18 psi spring weight and 30 psi electronic controlled boost SO I went with and built my own LS2 truck coils setup.
Look at that!
I didn't forget to dial the cams
Old 04-14-2014, 06:37 PM   #7
quickdiversion
I forgot to mention that I repainted it. It is pretty amusing, I did this in one day, and evening. In the summer, before East Coast Bash. Had to have a friend come help me reassemble the damn thing before it got to black out.
Old 04-14-2014, 06:38 PM   #8
quickdiversion
This was all put together in one night to show you guys everything.
This project took me over 3 years, I am on year 4 now. I loved talking about my build and answering questions about why I did what I did with them. I will be doing an update soon on my new exhaust evac setup soon. So watch out for that!
Old 04-15-2014, 03:54 AM   #9
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
Cool Build! I like the Ls2 coils.
JohnnyDrfiter22 is offline   Reply With Quote
Old 04-15-2014, 06:52 AM   #10
JN1AS4
JN1AS4's Avatar
JN1AS4 is an unknown quantity at this point
How much hp/tq did you make with the hx35?
JN1AS4 is offline   Reply With Quote
Old 04-15-2014, 07:56 AM   #11
mikey976
mikey976's Avatar
mikey976 is an unknown quantity at this point
Send a message via AIM to mikey976
wow the current bumper is soooooo much better then the original one.
KAe-T goal 400whp with A/C - Hatch VH45 track duty - Titan VK56 tow rig
mikey976 is offline   Reply With Quote
Old 04-17-2014, 08:04 AM   #12
kat7
kat7 is an unknown quantity at this point
Cool build I see most people doing body work in there garage I mught have to start doing that.
kat7 is offline   Reply With Quote
Old 04-17-2014, 06:42 PM   #13
quickdiversion
Hey thanks.
They were actually super easy to wire up, they each have 4 wires, 2 grounds, 12+ and signal. One ground is an ecu ground, the ground is a chassis ground. Than the signal wires go to the harness part back to the ecu, and the 12+ are on a wired relay. I just went over board with delphi connectors and made it all nice nice.
Old 04-17-2014, 06:44 PM   #14
quickdiversion
I do not know yet as it has not been dyno'ed.
I also am in the process from switching to nismotronic from a power fc. I can tell you that before I switched to the 1000cc injectors, when I ran the 740 nismo side feeds, When I hit about 2 pounds at half 3/4 throttle in second gear I spun tires like nothing. I spun 275 35 18's with a 2-way diff like it was nothing.
Old 04-17-2014, 06:48 PM   #15
quickdiversion
Really? You like the new one? I liked the older one better cause it was a charge speed, and the scopes on the sides. I found a new bumper that I am getting soon as the motor is squared away that is sweet Not gonna tell anyone the name yet, but keep an eye out for it!
HAHA I didn't even realize that wa you until I read the car info under.
What's up bro
Old 04-17-2014, 06:52 PM   #16
quickdiversion
Hey thanks, yeah I do all my work myself, except for the all my welding, I don;t have money put away for one yet. I also have never welded, soooo.
Yeah, the only thing that sucks about working out of your own garage is making all the space for it. haha
Old 04-17-2014, 07:55 PM   #17
acslater9
acslater9's Avatar
acslater9 is an unknown quantity at this point
Nice build man! Hopefully you will give us constant updates
Also can give me a brief summary about how you did the S15 front end conversion. Was it hard or easy to convert? I heard the wiring was the worst part of the conversion, is there any truth to that? Any other info you would like to share please do! As I am considering doing the conversion myself. Thanks!
acslater9 is offline   Reply With Quote
Old 04-17-2014, 08:01 PM   #18
quickdiversion
There is nothing to wire but the head lights, and I just googled that and was done in 10 minutes. SO they lied to you haha.
The conversion is simple to be honest with you, if you have the correct parts. You need fenders, I used s13-s15 conversion over fenders +30mm so not only are they fiberglass there is plenty of room to relocate all the wiring up into the fenders to keep away from the wheels.
You also need both parts of the s15 bumper, the actual support thing, like what everyone with an s13 throws away "to save eight" haha. Because on that mounts the headlight bracket. Than the bumper slips right.
I have to take the bumper off in a day or 2 I'll take some pictures for ya and post them here.
Old 04-17-2014, 08:09 PM   #19
acslater9
acslater9's Avatar
Well I feel stupid, lol. Thanks for the info, also I know you said you used s13-s15 over fenders fiberglass but wouldn't oem fenders coming off an actual s15 be better? Or would that be expensive as shit? haha
Old 04-17-2014, 08:19 PM   #20
quickdiversion
The doors are not shaped the same and the lengths are different you would be cutting an s15 fender and and s13 fender and welding them together. Why waste the time when you can buy ones that line up and are made for the conversion?
Old 04-17-2014, 08:28 PM   #21
acslater9
acslater9's Avatar
Never thought of that.
One more question, how much did you spend on the conversion itself?
Old 04-17-2014, 08:30 PM   #22
quickdiversion
I paid 350 for the fenders and bumper, 60 for the bumper support 85 for the headlight bracket and 600 for lights and 250 for the hood.
Old 04-19-2014, 01:15 PM   #23
quickdiversion
So I have been working through a few versions of an exhaust e-vac setup, similar to what the 2JZ and alot of V8's use. This was a little tricky because I combined a few different setups that I had found on here and in another thread I am part of.
The first set up was to eliminate the "T" on the exhaust side and weld a -10AN bung to it, which connected to the tube on the block to pull crank case pressure. Than a second bung was welded on the top back of the exhaust side and that line was put on a -10AN line that went to an exhaust e-vac insert 7 to 8 inches behind the turbo. Under the valve cover below the rear welded on bung, there were 1/8 inch holes drilled into the baffling to allow air and "hopefully" not oil.
The first half of this setup works great. The second half not so much. The steel braided line has rubber in it which obviously melted and oil got everywhere because only the steel braiding was left. I was mad at myself for not foreseeing this.
Setup #2
First half stays the same. Second half completely rethought. I used -10AN ss hard line from nitrous express which is almost impossible to flare. Also ss flare nuts and items are special order... So after completing this small piece there are 2 90* fittings and a 1-way check valve it only allow flow into the exhaust when the pressure in the exhaust cause suction on the ball valve to pull the crankcase pressure out through the head.
The reason I used -10AN ss hard line and not aluminum was simply cause it was attached to the exhaust. I didn't want anything warping, plus the hard line is short and allows for cooling before the aluminum parts.
Old 04-22-2014, 04:14 PM   #24
quickdiversion
Figured I would show ya guys what 275's look like up front. haha
Old 04-22-2014, 05:39 PM   #25
LuckyRPS13
LuckyRPS13 is an unknown quantity at this point
Looks like this has came a long way like my build. I like it.
Do you need;
Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill
S13 Silvia J's, Q's, K's, A's Bumper grill inserts.
Male Plugs for S15 headlights
PM me if you need them.
LuckyRPS13 is offline   Reply With Quote
Old 04-22-2014, 05:41 PM   #26
quickdiversion
Thanks man.
Yeah it took some time.
Soon as I get the nismotronic in it and get it tuned up.
I will jump on the body work to clean it up and get a real paint job, even get side skirts on it
Old 11-10-2014, 10:54 PM   #27
quickdiversion
Well I just got it tuned a few weeks ago.
I had it tuned for drivability and on 91 octane cause it is my dd.
However it was tuned on a mustang dunno 411/344
Old 11-12-2014, 12:35 PM   #28
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
Great Build!!
I look forward to more updates!!
Two-Tone owner#011509-Lightly Modded
Big Zee is offline   Reply With Quote
Old 11-12-2014, 02:40 PM   #29
quickdiversion
Hey thanks,
here is the update most people will enjoy.
on the dyno.
https://www.youtube.com/watch?v=htZV...x163B0llWV3m9Q
