Old 08-07-2017, 06:54 PM   #31
feito
feito's Avatar
Originally Posted by 72nismo View Post
I forgot to post this pic but this is what I've seen last couple oil changes. And at the moment car is not even driven much. Mostly just test driving it.
https://imgur.com/a/OFL8r?s=sms
oh boy, you would think posting such important info from the start would have really helped, ha?
it dead, jim, dead...
Tuners are big bullies
Old 08-07-2017, 06:55 PM   #32
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
If thats the case Im really screwed because bearing were replaced not to long ago. And I mean like in the last 4 months.
This is not a stock SR but a built SR if that makes any difference.
Who built it?
[email protected]
hanzbrady is offline   Reply With Quote
Old 08-07-2017, 06:56 PM   #33
72nismo
72nismo's Avatar
72nismo has a spectacular aura about72nismo has a spectacular aura about72nismo has a spectacular aura about72nismo has a spectacular aura about72nismo has a spectacular aura about72nismo has a spectacular aura about
I just did oil change yesterday. And last time I did an oil change I noticed some too. But when I clean it off its very thin metal shavings.
72nismo is offline   Reply With Quote
Old 08-07-2017, 06:57 PM   #34
72nismo
72nismo's Avatar
SR
Originally Posted by hanzbrady View Post
Who built it?
Friend of mine.
Old 08-07-2017, 07:00 PM   #35
hanzbrady
hanzbrady's Avatar
Friend of mine.
Well the only reason it'd be spitting out bearing material and having oil pressure issues would be improper assembly. Either clearances weren't set correctly or the engine had debris in it on start up from assembly.
[email protected]
Old 08-07-2017, 07:02 PM   #36
72nismo
72nismo's Avatar
I will have to look into that again and see what we figure out.
Thanks
Old 08-10-2017, 03:46 PM   #37
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
$0.02 bearing material isn't magnetic
Holy shit I just looked at that picture. my jeez..
Somethings fucked my new rebuild didn't even have anywhere near that much on my plug. all the material I wiped off mine each oil change during break in wouldn't even begin to compare to that mountain of metal on yours
The Game
you lose haha
kyral is offline   Reply With Quote
Old 08-10-2017, 03:47 PM   #38
hanzbrady
hanzbrady's Avatar
OEM isn't aftermarket is.
EDIT: Also on the chance that he running OEM bearings, any kind of metal in an engine is 100% worthy of a tear down.
[email protected]
Old 08-10-2017, 04:43 PM   #39
[email protected]
Juan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura about
RIP Bearings, Crank & lubricating system.
Competition Engines & Dyno Tuning.
(951)708-1648 | [email protected]
Juan@Fontananissan is offline   Reply With Quote
Old 08-10-2017, 05:33 PM   #40
taeisbeast
taeisbeast's Avatar
taeisbeast is an unknown quantity at this point
This should of been the first thing posted along with the OP.
Holy crap though, lots of shavings
taeisbeast is offline   Reply With Quote
Old 08-10-2017, 09:28 PM   #41
72nismo
72nismo's Avatar
SR
Will keep y'all posted when I have it checked out.
Old 08-12-2017, 07:06 AM   #42
Kingtal0n
Kingtal0n's Avatar
Sorry to say it but you are not the first to have a rebuilt SR fall apart.
It is very difficult to build one of these engines because very few people have the right tools or experience to do it proper.
A common theme is rebuild to sell. "Car for sale with rebuilt engine, only 200 miles" Yeah, avoid those.
https://tinyurl.com/turbo240
Old 08-12-2017, 11:47 AM   #43
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
0w20? youre crazy man. are you running super tight bearings?
and 2 bar at idle would be like 30 psi and 6 bar would be like 90psi one of which are very unlikely
Nope I had a micro polish done on the crank and got +.001 bearings. I do however have an n1 pump and blocked an oil port on the block. I didn't change out the oil port orifice and that's the reason for such high pressures. I use 0w20 to compensate.
I broke the engine in on 15w40 and would see close to 8bar at Wot. With 0w20 I see 6ish at wot.
smoked240 is offline   Reply With Quote
Old 08-12-2017, 02:39 PM   #44
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
Originally Posted by taeisbeast View Post
wow, thats extremely low.
I've seen numerous numbers in the range of 35-40 psi
Actually 35-40 is too high for idle it should be 10psi-12 at 800 rpm at idle . His is obviously low having 8 psi at 1000 rpm
jdm213 is offline   Reply With Quote
Old 08-12-2017, 03:03 PM   #45
taeisbeast
taeisbeast's Avatar
Most definitely high for idle at 800rpm, Im aware - but I was referring to what he originally put before he edited.
Old 08-12-2017, 03:50 PM   #46
the shocker
the shocker is an unknown quantity at this point
It's really not that difficult to rebuild them. You cant be an absolute idiot like any other engine. Measure, measure and measure again. Make sure all your clearances are good and proper torque specs/procedures are done.
the shocker is offline   Reply With Quote
