Old 12-07-2006, 10:07 AM   #1
stillmatic
stillmatic's Avatar
stillmatic is on a distinguished road
KA power steering delete belt info
Just did a research on this and thought I'd post all the info I gathered for future reference.
This is good for those who have a KA swap in an older car (510, Corolla, etc) with no P/S or anyone looking to bypass the power steering pulley.
4 rib belt (requires cutting)
Length: 27 3/4" (705mm)
Width: 9/16" (14mm)
Part #s:
Ac Delco/Mighty: 4K270
Atlas: 4K0270
Bravo: K2704
Carquest/Gates: K040270
Dayco/Drive Rite/Durkee-Atwood/Goodyear: 270K4
Dayco: 5040270
Goodyear (Gatorback): 4040270
Insure/Kelly Springfield/Lazorlite: L36-4068
Metric: 4PK0685
Motorcraft: JK4-276
Napa: 25-040270
Ultralast: K2704
Unocal: K2704
Vera: 55-40675, 55-40685
Western Auto: 77-9398-7
3 rib belt (tight fit)
Length: 27 3/8" (695mm)
Width: 13/32" (11mm)
Part #s:
Ac Delco: 3K267
Carquest/Gates: K030267
Dayco: 268K3, 5030268
Goodyear (Gatorback): 4030267
Metric: 3PK0648, 3PK675, 3PK680
Motorcraft: JK3-274
Napa: 25-030267
stillmatic is offline   Reply With Quote
Old 12-07-2006, 02:13 PM   #2
thejapino
thejapino's Avatar
thejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfection
for a PERFECT fit, this is what you do:
if you have a DOHC KA, you need the waterpump pulley from a SOHC KA. Use that pulley and there is a belt available that fits PERFECTLY. I've tried those other choices and it always seemed like it was a little loose or a little tight. Plus the size is available without cutting an extra rib off a belt. Peace
thejapino is offline   Reply With Quote
Old 12-07-2006, 05:21 PM   #3
stillmatic
stillmatic's Avatar
According to NAPA's belt guide, there's is no belt available between 695mm and 705mm (width) for any rib. What is the part # of the belt you're talking about? It might serve more help.
Old 12-07-2006, 06:39 PM   #4
luisgonz
luisgonz's Avatar
luisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfection
Send a message via AIM to luisgonz
I want to see some pics because i need to do this.Pics would help me alot.Thanks
luisgonz is offline   Reply With Quote
Old 03-24-2014, 06:34 PM   #5
zil180sx
zil180sx is an unknown quantity at this point
Dudee i know is olddd butt thankss
zil180sx is offline   Reply With Quote
