Old 02-22-2011, 08:50 PM   #1
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
How to: Unseize your coilovers
my Stance GR+ coilovers on my s14 decided they wanted to rust and seize up in 2 years. i wanted to go lower but i couldnt budge the collars. so heres how i did it and it was very easy.
tools:
-PB Blaster
-BFH
-flat tipped chisel
- anti seize
-17,14 socket. 19 wrench
1. soaked the living crap out of the tread in PB blaster and let it sit for a day.
2.take the coilover off the car.
3. turn it upside down and spray in the thread of the bracket and let it soak.
4. place the chisel in the collar and beat the shit out of it.
5. set the coilover on the ground and place the chisel on the weld for the brake line bracket.
6. this would be the step where i plan to completely disassemble the coilover and repaint everything. but its under 30 degrees out so that will wait until summer.
7. use a lot of anti seize
8. slam it
9. repeat 3 more times!
no pictures of it installed slammed because i either have to tub it or get smaller tires. it was hitting the inner metal. so i had to raise it back to where it was but whatever its unseized.
beems240sx is offline   Reply With Quote
Old 02-22-2011, 09:24 PM   #2
chiboy002
you should remove the collars and throw a bike inner tube there. Keep it clean
street dancer.
Old 02-22-2011, 11:18 PM   #3
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
Mine seized up like that but I could not get it to budge what so ever. JDM salt seized it all up so I dremeled a slit into the collar and hammered it off. Works great now and I have an extra 1/2 inch to go lower lol
Sumslapper is offline   Reply With Quote
Old 02-22-2011, 11:49 PM   #4
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
I put anti-seize on the threads before I installed them. It's held up for a year and a half now with no issues. But this is a good write up for people who didn't have the foresight to prep them.
Old 02-23-2011, 12:00 AM   #5
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
A spanner wrench attached to a breaker bar works wonders.
omgRWDgoodness! is offline   Reply With Quote
Old 02-23-2011, 12:06 AM   #6
buri_chan
buri_chan is an unknown quantity at this point
Nice, I did the same thing a few years ago, except I actually broke some teeth off the collars in the process ><
buri_chan is offline   Reply With Quote
Old 02-23-2011, 07:10 AM   #7
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
How long did you soak these things? I've soaked mines for a good hour or so and used the spanner wrench and a hammer to try and get the collar to move but no luck. I don't think I could get them to budge even if I toke them off!?
dreaMervaj is offline   Reply With Quote
Old 02-23-2011, 08:20 AM   #8
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
Bracket is seized tho
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 02-23-2011, 08:42 AM   #9
vtund777
vtund777's Avatar
vtund777 is on a distinguished road
Send a message via AIM to vtund777
I had this same issue. I need new collars. I took a flattened head screw driver and a hammer to loosen mine w/ some liquid wrench.
vtund777 is offline   Reply With Quote
Old 02-23-2011, 09:53 AM   #10
beems240sx
beems240sx's Avatar
I would say I let then soak for 7 hours. The spanner wrenchs are garbage. Mine broke from the force. It's easier to loosen them up with the chisel. You need to shock the metal not put constant pressure on it. Yeah the collars might get chewed up but they are still useable.
I'm running a 17x9.5 +12 and I want to max the coilovers out as it is no longer my daily. I work at discount tire so I pick up used tires all the time and the most common size is 235/45/17. I can get a set of 215/45's, will these clear the inner metal on a full lock turn? Not the fender those are rolled. The inner part in the engine bay is where it rubs.
Old 02-23-2011, 10:23 AM   #11
wh0aitznic0
wh0aitznic0's Avatar
Stance maxed out in the front? Won't be TOO TOO low. But a 215/45 will probably rub all day.
<3
Old 02-23-2011, 10:59 AM   #12
nathanong87
nathanong87's Avatar
u need to move at one of those collars to the underside of the bracket. c'mon
natelife.tumblr.com
Old 02-23-2011, 12:12 PM   #13
beems240sx
beems240sx's Avatar
What coilovers are ever designed like that? Well looks like ill have to tub it and put my 255's on
Old 02-23-2011, 02:50 PM   #14
dreaMervaj
Trader Rating: (18)
I'm gonna try to attack this once again in a few days. Would it be easier to do it while the coilovers are still on the car since I don't have a bench clamp?
Old 02-23-2011, 03:00 PM   #15
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
hammer the shit out the inner tub and your straight (: i did and yeah i plan on tubbing later on when i get my welding on pointttt
Old 02-24-2011, 01:00 AM   #16
vtund777
vtund777's Avatar
I say keep the coils on and bolted. If it's off and not clamped to anything, then the entire coilover is going to want to turn with the collar when you try to hit it. I tried and it just kept pissing me off.
Old 02-24-2011, 01:03 AM   #17
jamg
jamg is an unknown quantity at this point
damnit...
i just installed my coilovers on.
i really dont want to take them off, and put a bike tube through it... or even put anti-seize on them.
so much workkkkk
jamg is offline   Reply With Quote
Old 02-24-2011, 01:38 AM   #18
beems240sx
beems240sx's Avatar
Originally Posted by jamg View Post
damnit...
so much workkkkk
trust me, take them off and do it right. im SO pissed off about spending a grand on some shit suspension that rusted to all hell. even if i would had done a tube and anti seize from the start the brackets still would had rusted. coilovers are gay, i should just weld poles on the damn thing.
Old 02-24-2011, 08:42 AM   #19
waxball88
waxball88 is an unknown quantity at this point
Or a long pole for that matter. Kids these days don't go to school enough :P
Leverage is win
waxball88 is offline   Reply With Quote
Old 02-24-2011, 11:41 AM   #20
harangatang
harangatang's Avatar
harangatang can only hope to improve
Anyone figured out how to unseize the rear brackets on the GR+ pros? I tried PB Blaster and a mallet to knock them loose. Several times. No such luck...
Tyler
harangatang is offline   Reply With Quote
Old 02-24-2011, 09:07 PM   #21
beems240sx
beems240sx's Avatar
ill be doing it soon, ill let you know how i figure it out
Old 02-24-2011, 09:44 PM   #22
s13superstar
s13superstar's Avatar
s13superstar is an unknown quantity at this point
beat the living shit out of my coils! they got low alright!
1994 240sx SE- SOLD
1983 Cressida - Factory 5spd.
s13superstar is offline   Reply With Quote
Old 02-25-2011, 07:48 PM   #23
sincity_sil80
sincity_sil80's Avatar
sincity_sil80 is an unknown quantity at this point
pardon my ignorance.. but what do you guys mean when you say put a bike tube in the coilover to prevent it from seizing?
20 till 3:00 =
sincity_sil80 is offline   Reply With Quote
Old 03-04-2011, 01:38 AM   #24
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
^ What does that mean?
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 03-04-2011, 03:25 PM   #25
Matej
Everyone should do that.
Put anti-seize or lithium grease on the threads before installing them, and every time they are being tinkered with.
Doing so, one will never have to deal with this.
Old 03-04-2011, 03:34 PM   #26
Quail
Quail's Avatar
Taking a screwdriver and hammer to my Hipermax Pros was very, very painful.
Their replacements will be getting lubed up on a regular basis.
Also interested in the bike inner tube thing? I've seen coilover covers, but not sure how effective they are.
Old 03-04-2011, 03:41 PM   #27
KOUKIboy
KOUKIboy's Avatar
Its because you live in an area where it snows, also that salt they put on the roads to melt the snow also spells disaster for Coils, meaning they're gonna rust to hell, but yeah this is a good idea, and PB blaster works wonders...
KOUKIboy is offline   Reply With Quote
Old 03-04-2011, 04:02 PM   #28
joeapple8
joeapple8's Avatar
Trader Rating: (32)
joeapple8 is an unknown quantity at this point
Feedback Score: 32 reviews
When I got my coil overs the previous owner used thread locker on the fucking coilovers, he said it would loosen them selves and adjust by them self, so he thread locked them.
So I got a friend and each one of us used these and turned the opposite way on the collars and it worked fine, after I got every thing loose, I got a wire wheel and cleaned the threads on every thing, and I used anti seize on the threads.
joeapple8 is offline   Reply With Quote
Old 03-04-2011, 11:29 PM   #29
Farkel
Farkel's Avatar
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Farkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura about
Send a message via AIM to Farkel
Seems like lathering on anti-sieze all over the threads would cause dirt and grime to stick to them over time, no?
★ ★ GRANDMIGHTY.COM ★ ★
Farkel is offline   Reply With Quote
Old 03-04-2011, 11:40 PM   #30
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
That's where the bike tube comes in. It keeps them dirt free.
I personally just threw some grease on mine, and whenever I have the car jacked up, I move the collars around. Worked for a year. But then again, I've only had the car for a year and never driven it in snow/salt.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
