Old 06-25-2011, 08:56 PM   #1
Touge180
Touge180's Avatar
Touge180 can only hope to improve
Idle problems
Need help with my car having trouble with idle issues which just started if Im rolling and come to a stop the idle will drop to 0 then go back up to 750rpm and if I beat on it which doesn't happen much it will misfire then clear up after a bit changed the plugs was wondering what else to do car is a 1991 dohc ka.
Touge180 is offline   Reply With Quote
Old 06-25-2011, 11:23 PM   #2
818 ZENKI
818 ZENKI's Avatar
818 ZENKI is an unknown quantity at this point
Hmmm have you cleaned your iacv?
WTB: S14 Wiper motor and S15 HLSD w/ Shafts
It's always broken!
818 ZENKI is offline   Reply With Quote
Old 06-26-2011, 03:41 AM   #3
TypeXFan
TypeXFan is an unknown quantity at this point
im having idle problems too, at start up the idle struggles, and when im rolling the idle sometimes drops down to 0 and even stalls the car, sometimes the idle will shoot up to 1500-1800 and come back down. After a bit of driving it stabilizes. Gonna have a look at the iacv hopefully wont be too hot to work on it. Give you a update when I can.
TypeXFan is offline   Reply With Quote
Old 06-26-2011, 12:44 PM   #4
nissan4ever
nissan4ever is an unknown quantity at this point
Check the IACV. It might also be an electrical issue. Jiggle the wires around the engine bay and see if the idle changes.
nissan4ever is offline   Reply With Quote
Old 06-26-2011, 08:50 PM   #5
Touge180
Touge180's Avatar
Thanks guys i jiggled the wire a little tonight for the Mass air flow and the idle changed gonna mess with it some more tomorrow i also might spray the iacv with carb cleaner.
Old 06-27-2011, 01:36 AM   #6
s73
s73 is an unknown quantity at this point
I learned of a quicker way to clean the iacv without taking the whole thing off (of course....this is after i took the whole thing apart)
You can try just by taking out the idle screw, and shoot some cleaner in there...then re install screw...reset idle....done
s73 is offline   Reply With Quote
Old 06-27-2011, 05:04 AM   #7
Touge180
Touge180's Avatar
Im not gonna take it apart as this is my only car right no im just gonna shoot cleaner down the hose to the iacv.
Old 06-28-2011, 04:27 AM   #8
t3chnikqality02
t3chnikqality02 is an unknown quantity at this point
you should really spend 30 minutes taking out the iacv, spraying it with brakleen, using a toothbrush or something to scrub off the carbon build-up and then allow sufficient time for it to completely dry before reinstalling it. it may also be the MAF
t3chnikqality02 is offline   Reply With Quote
