Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 08-20-2013, 03:21 PM   #1
iVanRoz
iVanRoz's Avatar
iVanRoz is an unknown quantity at this point
Shifter issues??
Ok after searching for about an hour I gave up and decided to make a thread.
Anyways here's my situation. I was happily driving my Z down to the beach when suddenly my shifter started feeling weird when switching gears. The shifter "bounced" around and made a ratting noise it also had a sluggish feel to it. I parked the car and checked the clutch hydraulics to see if they were good. The master clutch was not leaking and as far as I could tell neither was the slave. (I replaced both of these a few months ago). The clutch itself seems to be good I didn't notice any slippage. The car still goes into every gear and theres no sigh and I can't hear any noise coming from the transmission itself.
I'd love to get your guys input on this. Could it be a bad shifter bushing? Low transmission fluid? Maybe a transmission mount?
Now that I think of it the issue started just as I was going down a really steep incline down to the beach strand. Don't know if has something to do with it or it was just coincidence.
WTB: zenki hood, passenger headlight!!
iVanRoz is offline   Reply With Quote
Old 12-01-2013, 10:12 PM   #2
FUUARK
FUUARK is an unknown quantity at this point
Shifter support bracket - Try pulling off the interior plastics surrounding the shifter, then remove the 4 bolts holding down the rubber shifter boot.
It seems that it is a common issue for the shifter support bracket to drop or become loose.
FUUARK is offline   Reply With Quote
Old 12-04-2013, 06:49 AM   #3
Mikester
Mikester's Avatar
Mikester is a well-known jackass
It's either the bushings or it simply came too loose in the bracketing that connects it to the striker rod... or both.
My shifter rattles at 3,000rpm & above, but only because I was dumb enough to put SPL solid shifter bushings in (hate them but love the feel lol). It still shifts very precisely and is nice & tight tho.
Mikester is offline   Reply With Quote
