Old 08-19-2007, 02:29 AM   #1
Skinny
Skinny is on a distinguished road
Making SR20 Reliable
Hey guys,
i did a search, and couldn't find anything on this topic
But I wondering what are some of the weak points on a SR20?
I know the Oil pan, and pick up is one part of the motor
what about head stuff(studs, valve springs, valve rockers, etc)
I was going to start drifting this JDM Silvia i just got. I want to make the motor reliable for minimal down time. I am trying to keep the power down
to learn on at first. but once i get better i will start adding power.
So if anyone can point me in the right direction, that would be awesome!
Skinny is offline   Reply With Quote
Old 08-19-2007, 03:38 AM   #2
SpdElemts
SpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of light
An sr20 is pretty much reliable in stock form...well mine was when stock. But if you want to make an sr20 reliable i would probably work on keeping the oil as cool as possible with a oil cooler and getting a bigger oil pan. sr20's are so oil dependent that keeping the oil cool will save you a lot of trouble. Also sr's tend to run hot so the next best thing to do is to get a bigger radiator like a koyo and a lower temp thermostat. Hope i helped good luck learning how to drift your JDM Silvia.
-Jeff Wolfson
SpdElemts is offline   Reply With Quote
Old 08-19-2007, 04:20 AM   #3
yokotas13
yokotas13's Avatar
didnt know an SR20 was unreliable?
yokotas13 is offline   Reply With Quote
Old 08-19-2007, 05:08 AM   #4
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
yeah, this isn't like a rotary*, where they're unreliable by their very nature.
Regular oil changes, clean air & oil filters, change fuel filter and plugs every so often and you should be fine.
*I'm not bagging on rotaries here. I'm just saying, stick your head under the hood of an FC or FD at operating temperature and tell me that that's a conducive environment for reliability.
Originally Posted by PHLIP
Old 08-19-2007, 05:33 AM   #5
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
lol. weld the oil pickup, oil cooler, rocker arm stoppers, thermostat, rad. done.
If you are upgrading the turbo and plan to beat on the car.
Head studs. hg, and a right foot that knows every motor cant be run 100% all the time.
blu808 is offline   Reply With Quote
Old 08-19-2007, 08:48 AM   #6
Skinny
I wont be upgradeing the turbo until i am deece at drifting, and i know i can handle the power. Plus i was just going to put on a T28 turbo.
Awesome guys, i was basically correct with what i needed to do!
well kinda.
Old 08-19-2007, 10:49 AM   #7
!Zar!
!Zar!'s Avatar
A motor is only reliable as the tune that's on it. Rotaries included. =)
Old 08-19-2007, 11:08 AM   #8
StaticX27
StaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond repute
^ +1, except add owner's negligence as a determining factor in motor reliability.
StaticX27 is offline   Reply With Quote
Old 08-19-2007, 05:02 PM   #9
Skinny
I was going to go Rom tuning, and get a wide band to help with that.
EDIT:
do you guys suggest any places to get Rockerarm stoppers, and a Oil pan/pick up?
I was going to get the Greedy oil pan, but didnt quite know what brand of Pick up, and rockerarm stoppers i should get!
Old 08-19-2007, 10:57 PM   #10
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Sr20's are plenty reliable, as much as any motor is, if you take care of it.
Oil, coolant, airflow, the basics.
I've been daily driving my Sr20 at 17psi for almost 3 years now. 14 drift days, 35+ passes at the drag strip, and weekly street racing and drifting sessions. Not 1 single problem with the motor or anything ever. The turbo is just finalyl now on its way out. and it has almost 90k on it
-Kyle
BlackZenkiS14 is online now   Reply With Quote
Old 08-19-2007, 11:03 PM   #11
yokotas13
yokotas13's Avatar
fuck man
i ran diesel into my shit
drove for liek a mile
shit cut off
i drained the fuel
added some 103
started right up
no damage liek 6 months later
Old 08-19-2007, 11:26 PM   #12
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
Originally Posted by yokotas13 View Post
fuck man
shit cut off
i drained the fuel
added some 103
started right up
lol how that happen??? my sister did the same in her civic. dealership had to replace the injectors, fuel pump, fuel filter, spark plugs, and a whole other wad of shit.
back on topic, SR20 is relieable if maintained correctly and regularly. so is the RB and any other motor. yes even the VG
Review Thread
bardabe is offline   Reply With Quote
Old 08-19-2007, 11:52 PM   #13
yokotas13
yokotas13's Avatar
i didnt replace shit
same filters and plugs
ran like a champ
still does lol
Apparently the green handle is Diesel in japan guys
Old 08-20-2007, 02:27 AM   #14
!Zar!
!Zar!'s Avatar
The green handle is diesel in america.
Old 08-20-2007, 07:41 AM   #15
jobestudios
jobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the rough
Yeah, thats pretty much universal, you're just a dumbass...
-Jackson.Vaughn.Photography-
jobestudios is offline   Reply With Quote
Old 08-20-2007, 07:45 AM   #16
mrmephistopheles
Inactive Admin
Stupidity, like diesel handles, is universal.
Old 08-20-2007, 08:21 AM   #17
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
EDIT:
you should be able to find a few different RAS below, also i believe you can either cut a larger hole in your current oil pickup, or get yourself an OEM s14/s15 oil pickup. if you dropped your SR in DEF check the oil pan for dents, i was very close to neglecting hammering out mine because it apepared ok, but when i removed the lower oil pan, i noticed the oil pickup was making direct contact with the pan , yikes! just hamemred it out all is well.
your new best friends:
my personal favorite: frsport.com
phase2motorsports.stores.yahoo.net
enjukuracing.com
and if desperate
heavythrottle.com (prices are a tad high for me)
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 08-20-2007, 08:41 AM   #18
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
alot of people believe that the RAS kit alone will help you safely rev an ungodly amount, but in actuality the entire valvetrain should be upgraded just like with any motor in stock trim. Upgrade to a solid lifter design and you automatically get rid of the mushy hydraulic ones. Retainers and springs help make sure you dont get valve float during high rpms.
As far as the bottom end goes, I think these motors are essentially tanks. Their crank walk keepers are sturdy, the oil lubricating systems (aside from the pick up and the pan) are great with the exception of the casting of the pump internally. In order to keep anything from frothing at super high rpms you might want to make an upgrade to the oil pump by either shaving some material off of the casting, or upgrading to the GTIR pump which require a little modification for the new timing cover to fit. Other than that, the motor kicks arse. Keep in mind you dont have to start thinking of this stuff until you are really making the motor scream, for midrange RPMS you dont have to worry as much. The SR is a warm running motor from the get go, so make sure you keep your baby cool with the proper fan and rad set up. I personally am going with an electric water pump myself.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 08-20-2007, 08:52 AM   #19
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
Proper range plugs help alot, I've pulled alot of bkr4's and 5's out of peoples cars as of late.
AT LEAST bkr6e for stock, and 7 if you can get it!
OIL COOLER. If you are going to last a long long time, and have a heavy foot in so-cal, you need an oil cooler.
Like this ice!
[email protected]
johngriff is offline   Reply With Quote
Old 08-20-2007, 02:41 PM   #20
Skinny
Thanks a lot for the very thought out reply's guys.
Zilvia.net is one of the best forums i have visited!
I will for sure be coming back more and more!
All my questions were answered! I should be good!
Old 08-20-2007, 02:45 PM   #21
Skinny
What turbo are you running? and what other mods are you running?
Like fuel, and tuning?
Old 08-20-2007, 03:10 PM   #22
yokotas13
yokotas13's Avatar
ive never used deisel
shit happens
Old 08-20-2007, 03:29 PM   #23
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
on a side note with RAS 99 percent of the time they work, now i have seen a few times as where they break and cause super head damage. worst then a floating valve would. and they were greddy's ras.. nothing is safe just remember that
Grenade180sx is offline   Reply With Quote
Old 08-20-2007, 03:45 PM   #24
BlackZenkiS14
T25, 255 walbro is the only fuel mod, stock ecu, stock maf.
I know people are going to say i am stupid and thats retarded...etc...but the fact is, i've more reliability out of my motor than anyone else on here almost, and i run the shit out of my car. I may run her hard but i never "put her away wet." She's been the daily for over 2.5 years. I just got a Daily civic a week or so ago to save on MPG and for more comfort.
-Kyle
Old 08-21-2007, 01:23 AM   #25
Skinny
Do you have a Wide band to tell you if you are lean or anything?
Old 08-21-2007, 09:59 AM   #26
BlackZenkiS14
Yes, I do. and it does run a lil lean, but so far i have not had a single issue with it. cause even when i set the boost down to 7psi the ECU tried to make it run lean. I am installing my Nismo AFPR and Emanage within the next few weeks to fatten it up a bit. The car runs great and has for the past 3 years though
-Kyle
Old 08-21-2007, 10:02 AM   #27
Wahl 136
Wahl 136's Avatar
Wahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to all
The SR is reliable stock without using upgrades or after market items. First have it properly installed, properly wired and don't beat on it. Then maintain it the same way you would any other car.
Wahl 136 is offline   Reply With Quote
Old 08-21-2007, 10:55 AM   #28
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
I know that in US the diesel nozzle is bigger than regular gas one and it won't fit into the little hole in the gas tank - they do that to make it easy for people NOT to fill it up with diesel - I don't know how you guys managed to do so.
+1 on oil cooler
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 08-21-2007, 11:05 AM   #29
Skinny
I will be drifting it, so of course i will be beating on it.
Old 08-23-2007, 02:38 PM   #30
Skinny
Does anyone know a good Oil pick-up?
an aftermarket one? i have been searching, can't find one
thanks guys
