07-09-2009, 04:39 AM | #1 |
What is the break-in procedure for a fresh swap
The motor is a prep'd S14 SR20 with front, rear main seals replaced, new gaskets and new RTVs everything except headgaskets and other internal stuff.
I understand that it is necessary to cut the fuel and prime the motor, turbo and starter a few cranks before actually fire up the engine. There is also a number of ways and different motor oils that people suggested to use in a sequence of oil change in 20 miles then 100 miles then 1000 miles. I'm ordering Amsoil 10w-40 Synthetic Motor Oil (for older engines), Amsoil EAO oil filter and Amsoil 75W-90 Gear Oil MTG Is it better to break-in with cheaper oils and filters like non-synthetic oils and OEM filters? Some people use non-synthetic oil for break-in but I know my motor previously used Redline synthetic before the swap. What procedures and motor oils do you sugguest to use after a swap? Also, should anything neccesary be done to the tranny? |
07-09-2009, 06:10 AM | #2 | ||||
From what you did, it doesn't sound like you need to prime the oil pump, although it doesn't hurt to turn the oil pump a few times before firing it up. Quote:
Assuming it's manual, just change the fluid. |
07-09-2009, 06:36 AM | #3 |
^I agree^ You didn't do anything that needs "breaking in". When I did my motor swap all I did was change the oil about 3 times in 2 weeks to get it all flushed out. Of course you'll want to take it easy for a period of time just to make sure the motor is mechanically sound.
07-09-2009, 06:40 AM | #4 |
sounds reasonably correct! thanks!
as for the tranny, it is manual (bought from bicanek). I was told that the tranny was bought with ~27k miles on it and sat in the garage for 1-2 years. Any precaution I should beware of? |
07-09-2009, 09:57 AM | #5 | |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
make sure theres oil in it...if there is, drain it...put fresh in and enjoy...
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
07-09-2009, 10:38 AM | #6 | |
YouTube - Check Gear Selects on Tranny www.240SXTECHDVDS.org
"I'm a rage-aholic, I just can't live with rage-ahol!!!" |
07-09-2009, 11:30 PM | #7 | |
I have done checking the gears and they seem fine. I heard somewhere that there is button you should press on the tranny to make it in neutral. Can anybody confirm this? Since the tranny has been sitting in the garage for a period of time, should I change the front and rear seals? |
07-13-2009, 12:55 AM | #10 |
they already gave you all your info
fresh swap? shits used son. its a used engine rebuilt it completely and then ask about break in process. as for the tranny goes its used to put oil in and drive changing seals sure why not. its a easy job. i put a used trans in my car and changed the seals and bellhousing. then i drove on the track all day about hour later. break in? break it in with boost. like a man. |
07-13-2009, 01:12 AM | #11 |
Man w/ CTSV & a Car Seat
Yup, you change the oil a couple of times to get as much of the crap out of the engine. You gotta realize that these engines have been sitting in junkyards or what not for years. You got all kinds of crap in there, oil that hardened, crap that fell in there, etc...only way to get it out is flushing it out with oil. Use cheap oil, change it at atleast 2x then go use what ever oil you prefer. I usually do 3 at 20 miles, 50 miles, 500 miles, then do regular intervals. Tranny, I'd change that atleast once.
