Old 03-29-2011, 07:52 AM   #1
SGTRanger175
SGTRanger175 is an unknown quantity at this point
s14 No ECU power, No Spark, No fuel.
NOTE: This is a Blacktop S14 SR20DET w/VVT into a USDM 1997 S14.
I have everything installed. All the necessary plugs are plugged in (those required to at least get the car running, ECU, ignition, F4, etc.)
The car is a USDM 97 S14, Blacktop S14 SR, NB ECU and from what wiring specialties said the harness is the late model harness. It has the smaller plug with smaller ABS plug near the ECU.
I am not using the ABS plug as you would imagine. I repinned the F4 exactly as the KA plug was wired. Repinned it with what was available from the harness we are using.
I did leave out the following from the F4 plug. Each left out wire was heat-shrinked individually, bundled and heat-shrinked again.:
Fan relay wires (orange/blue),
Knock Sensor Ground (gray),
IACV (black/yellow),
Check Connector (Green/Red)
Also I noticed on the this diagram (http://img241.imageshack.us/img241/8...1052006wu0.png) that the KA plug has a ground wire at #39 so I added a black ground wire and attached to to where the ECU grounds at.
Here are some photos to put these words into context.
Hope you all can help me out. Been trying to wire this thing for over a week. The car will crank, but I have no power to the ECU. The dash lights up, but no CEL to show power to the ECU either. (No spark, fuel, etc.)
Thanks in advance!
The black/yellow wire, I verified goes to the IACV. Verified the continuity between the the F4 pin and IACV plug. .0003 Ohm.
Pictures of the ECU, can you help me decode exactly which ECU this is and is it compatible with what I am using?
SGTRanger175 is offline   Reply With Quote
Old 03-29-2011, 10:51 AM   #2
SGTRanger175
Update:!!!!!
Now have power to the ECU. There was a bad blue relay. Luckily we had another one. Replaced the relay, "LET THERE BE LIGHT"!
Also this gave us spark as well. However it appears we have no fuel, pump is running, we are about to check fuel pressure and whether the injectors are firing or not. Pulled a plug and didn't see/smell fuel.
Will update again a little later with results.
Old 03-29-2011, 10:54 AM   #3
bb4_96
bb4_96 is an unknown quantity at this point
Best troubleshoot post ever.
bb4_96 is offline   Reply With Quote
Old 03-29-2011, 11:30 AM   #4
SGTRanger175
Well we def have fuel pressure. At first I thought the fuel lines were reversed but they aren't.
Incoming fuel is going to the top left metal line, return is coming off the bottom right line that runs from the bottom of the fuel pressure regulator. The motor bumped for a fraction of a second making my heart about skip a beat or increase in rate. But still no running motor.
The battery is pretty weak so we are fast charging it to get some juice.
Old 03-29-2011, 12:05 PM   #5
Sileighty_85
Sileighty_85's Avatar
Just a FYI That ECU is from a 96 Auto, If that helps at all
Id check plugs and make sure they are gaped correctly at .028
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-29-2011, 01:25 PM   #6
SGTRanger175
The car will run off of starter fluid (spray). Has to be an issue with the injectors. I will finish diagnosing it when I get back to the shop in about 20 minutes.
Old 03-29-2011, 03:12 PM   #7
SGTRanger175
Ok I am getting the 5v to the injectors, we have ~40psi of fuel, we have spark.
Whats the chance that we have 4 bad injectors? Ugh.
Old 03-29-2011, 04:39 PM   #8
SGTRanger175
Ok so Im thinking this through:
We have spark, we have 40+psi of fuel, we have voltage to the injectors and we got air.
I crank it over a few times, pull the plugs to verify fuel again and it doesn't smell of fuel at all. The odds of having four bad injectors is pretty slim.
Now when I spray starter fluid into the intake the car will start and run.
Maybe the injectors are just really dirty and clogged up or something really abnormal like black magic. Perhaps we are just having a lean misfire...??? O_o The turbo is pretty small and putting air into the motor, maybe its just too much. its a T25 so it doesn't have a port on the housing for the wastegate. But even at idle and startup it should matter anyways. Anywho, I take off the charge elbow and prep it for a new port and take off the intercooler piping at the throttle body. MAF is still on the turbo so at least there is some kind of reading for the ECU to see.
(BTW isnt the VTC SR20DET supposed to have a T28, i thought all the Nissan T28's had a port on the compressor housing for the wastegate line..???)
So I decide to start it up again and I spray a lot or stating fluid into the intake to get it running for a little while. She starts running as expected. Well after I stop spraying she continues to run even after all the fluid should have been consumed.
So it appears that since this motor hasn't been run in god knows how long that it was having a lean misfire. Without the turbo hooked up the car will run.
So tomorrow I will get it all back together with the new port for the wastegate and get her started again.
I will update this tomorrow with results.
Old 03-29-2011, 06:28 PM   #9
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Ohm test your injectors just to make sure. And check all harness grounds.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 03-29-2011, 07:11 PM   #10
Sileighty_85
you should have 12V at the injectors
後輪駆動車1番
1986 SR86 - 200ish
Old 03-29-2011, 07:20 PM   #11
a7olyte
a7olyte is an unknown quantity at this point
You need 12v at the injectors. I can't tell whether or not you bypassed the injector 12v wire or not, but from the pictures supplied it seems to be missing.
From the diagrams you have supplied, Pin 48 is Power to Injectors, which is missing in your dash harness. I don't know how accurate the diagram is, but assuming it's correct, you are missing that wire (unless you bypassed it). I've attached a picture that may be a fix to your problem.
a7olyte is offline   Reply With Quote
Old 03-29-2011, 09:53 PM   #12
SGTRanger175
The battery has been really undercharged all day. So that could be the case as well. I put it on a slow charge over night.
I actually fell asleep in my recliner about 4 hours ago. I just woke up, but Im going to take advantage of it and head back to bed.
When i got into the shop in the morning I will recheck everything when the battery is fully charged.
Old 03-30-2011, 11:02 AM   #13
SGTRanger175
So can I just run a 12v power source from the ignition to this plug then? Can I just splice the it off the fuel pump power source? There was no Red/Yellow wire in this location for either the SR harness I have or in the KA original F3 plug.
Old 03-30-2011, 11:37 AM   #14
SGTRanger175
From the FSM I see that the injectors have a continuous power source (battery voltage, should be 12.6v). This is a BLACK/YELLOW wire which is in pin
The ECU provides the grounding for the injectors. The BLACK/RED is in the same location on both the KA and SR harnesses so I did not repin it. (Bottom right corner as you can see in the above photo.
The Red/Yellow wire that was mentioned earlier is on the KA harness and runs from the F3 plug to the ECU pin #60. I found a pinout of the ECU however it does not indicate what it is a power source for. Also its to the left of the (BLACK/PINK: KA F3), (Black/Yellow on the F4 SR) wire that is the fuel pump relay power source.
Old 03-30-2011, 01:24 PM   #15
SGTRanger175
Double checked the power wire from the F4 to the injector harness junction plug and its good.
The car will run after getting it started with starting fluid but it runs really rough. You have to adjust the throttle to keep the car running. it will smooth out at higher rpm but idle its barely alive or dies.
Old 03-30-2011, 07:00 PM   #16
SGTRanger175
Got the start-up issue somewhat resolved. Found out that one of the ORANGE/BLUE wires is the Start signal and only one is for the Fan Relay. The Orange wire on the SR F4 is the Malfunction indicator.
Now I have a loose BLACK/WHITE wire that I cant seem to track down as to what its for and where it goes.
Old 04-01-2011, 06:21 AM   #17
SGTRanger175
I appears we have most of the core issues resolved now. However the idle still sucks and startup isnt perfect.
The car is also operating under a revlimit so we beleive its either an issue with the MAFS or ECU. Seeking a good known unit to test.
