Old 07-20-2004, 02:19 PM   #1
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
KA KA Power Steering Removal/Water Pump Belt Question?
I figured I would start another thread for this simply because there were the same people posting in my last thread about power steering removal. While it was very informative I couldn’t seems to get this last problem answered.
I know I can keep my Power Steering pump/pulley in place and use it as an idler pulley for the water pump but my goal is to remove the weight along with ditching the PS, so I see no purpose to keep it there.
Would there be ill effects if I ran a custom belt from the crank pulley to the water pump pulley? If that is safe is there any way I can get a custom belt made, and where might that be?
I know I could run a electric water pump... but I don’t think anyone has located one for the KA DOHC, if someone knows of one please let me know. This would be a last case scenario considering the cost of electric water pumps.
Any help, suggestion, ideas!? Thanks all!
Here is my last thread for reference.
http://www.zilvia.net/f/showthread.php?t=54728
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 07-20-2004, 03:21 PM   #2
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
i work at an auto store and the best way for a "custom" sized belt is it measure it. Use a pretty hufty piece of string and go from the crank to the waterpump. tie it together and bring it to an auto store. they should be able to measure it an all that good stuff. make sure to bring in the orginal so they can see how many ribs and crap.
just for FYI on good year belts the numbers mean the length. 4040640. the last 3 numbers is the length, ie 64" the very last # is the length in tenths. the first couple of numbers are the ribs. for our cars it should start with 4040, meaning 4 ribs, or 4030 = 3 ribs.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 07-20-2004, 08:07 PM   #3
1998cc
1998cc is an unknown quantity at this point
Napa V-Ribbed Belt (Its a gates belt)
25 030267
13/32" x 27 3/38" or 11mm x 695mm
That belt is a tight fit so here is the procedure for getting it on.
loosen all the bolts on the crank pulley and leave two on (the top ones), loosen the water pump bolts but leave two on (the bottom ones), then slide the belt on and press the belt on hard while turning the crank. Slowly after maybe 3-5 turns of the crank it will be completely on. then put on and tighten all the bolts. Do a simple test run, see if everything is ok.
Pop-ups Rock
1998cc is offline   Reply With Quote
Old 07-20-2004, 09:35 PM   #4
West
OMNOMNOMNOM
West's Avatar
WOOT! Thanks Barry! (If this is Barry)
Also, this is for KA and not the CA right?
Old 07-21-2004, 04:26 AM   #5
1998cc
I am not sure who barry is. But this definately for the ka.
Pop-ups Rock
Old 11-17-2004, 01:22 AM   #6
West
OMNOMNOMNOM
West's Avatar
Bump from the past!
Anyone have any other suggestions on where to get a belt for this. The one 1988cc mentioned is to tight and is about to snap. The best guess I can figure is a 705mm x 11mm 3 rib belt. Anywhere close in that range, given 5-10mm. 695mm is to small, closest I found was a 735mm, which was waaaay to big obviously. Gates Rubber has a 715mm that Im going to try, but im expecting it to be to big.
HELP ME OUT! Car hasn’t seen asphalt in over a year!
Old 11-17-2004, 11:23 AM   #7
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
just go to a parts store. They can get you the one you need. show them the stock one, measure the size you need, and take that in there.
andrave is offline   Reply With Quote
Old 11-17-2004, 12:17 PM   #8
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
after you get it done, let us know how you lik driving her without PS
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 11-17-2004, 12:48 PM   #9
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
i still dont like the idea of no belt tensioner...
just make sure you keep an eye on it
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 11-17-2004, 03:45 PM   #10
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Without power steering sucks for parking and slow driving. But the roadfeel is awesome, and outweights the difficult parking. Just try to get as close to factory specs as possible on the belt tension. There has got to be a belt on some car that works, hopefully. I've got the E so power steering removal is simple.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 11-17-2004, 04:12 PM   #11
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
i agree, i wouldnt bother on a KA24DE unless there was some sort of idler puller. thank god KA24E and SR20 dont have this issue.
untrue, i can drive around town with one hand, if you drain and empty the rack the car will move VERY easily.
i've noticed different tires make a huge difference in terms of rolling resistance.
old_s13 is offline   Reply With Quote
Old 11-17-2004, 08:01 PM   #12
Tygma
Tygma's Avatar
Tygma is making a name for him/her selfTygma is making a name for him/her self
i've had it off for about 5 months now; drained the rack, pluged the holes and removed everything. it's very good for grip and whatnot and its easy as hell when your moving. parking, whatever get used to it, its seriously not that hard.
Tygma is offline   Reply With Quote
Old 11-18-2004, 11:33 PM   #13
SilviaSativa
SilviaSativa's Avatar
SilviaSativa is an unknown quantity at this point
I used the same belt 1998cc mentioned. It's definitely a tight fit but it stretched a little after running it. 650 miles later no problems. Glad my temp guage is working now so I know if it breaks!
Shouldn't have to remove all those bolts to get it on either.
SilviaSativa is offline   Reply With Quote
Old 12-06-2004, 03:22 AM   #14
entix
entix is an unknown quantity at this point
i ran into this problem when getting my ka powered 510 running, because i obviously wasnt using power steering.
i have a bracket and idler built that weighs about 5 lbs if anyone wants to buy it it.
otherwise i might start selling the belts that i used for the straight crank-water pump. theres a trick to it
how many people would be interested in buying the belt? its about as tense as the stock belt, no need to loosen the crank to get it on.
entix is offline   Reply With Quote
Old 12-06-2004, 12:26 PM   #15
nismo2491
nismo2491's Avatar
nismo2491 is making a name for him/her selfnismo2491 is making a name for him/her self
west - you can't just leave the power steering pump on there as an idler, you'd have to desing some type of bracket and just get an idler pulley for like a cavalier or something and put it in its place. problem is that the power steering pump needs the power steering fluid as a lube for the bearings, otherwise after a few weeks it will lock up if its just used as an idler pulley.
KEvin
To quote the great Ron White: if life gives you lemons, make lemonade. and try to find somebody who's life gave them vodka, and have a party
nismo2491 is offline   Reply With Quote
Old 12-19-2004, 04:40 PM   #16
kadett
kadett is an unknown quantity at this point
couldn't you just let it circulate oil (or ps) through itself by looping the lines around?
then again, the low pressure lines probably couldn't take the pressure.
kadett is offline   Reply With Quote
Old 12-19-2004, 05:57 PM   #17
old_s13
old_s13's Avatar
isnt the belt adjustment for the DE on the air conditioner? This means, ditch the PS, get a shorter belt.. and yer good to go, no?
Old 12-21-2004, 07:14 AM   #18
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
Maybe you can use the idler pulley for the AC belt by just spacing it out with washers. Not sure about the ribs on it though.
-Juan
240Stilo is offline   Reply With Quote
Old 12-21-2004, 07:49 AM   #19
weirdstyles.net
This guy...
weirdstyles.net's Avatar
weirdstyles.net is an unknown quantity at this point
Send a message via AIM to weirdstyles.net
West, stoping being a bitch and break out the welding helmet and some balls. A custom tensioner is cake to make, just mimic the design used for the SOHC alternator. Homie with the 510 somewhere up in this thread did it...
My project car...
From dust you were born,
And to the ashes you return ~ Kill Switch Engage
Family Guy
Quagmire: Hey, how old are you sweet thang?
Connie: 16.
Quagmire: 18? Alllll-right!
Connie: Mommmm!
Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy!
weirdstyles.net is offline   Reply With Quote
Old 04-20-2005, 09:26 PM   #20
neverdone
neverdone is an unknown quantity at this point
has anyone tried putting in a t fitting and running a line to an empty resvior? Also is there any reason you cant loop around a line and have the ps pump just pump fluid through itself?
neverdone is offline   Reply With Quote
