Old 02-06-2011, 11:06 AM   #1
scote2583
scote2583 is an unknown quantity at this point
redtop studdering under boost once warm
car is a 93 240sx with a redtop sr 20 in it, before i parked it for the winter it was showing the problem..... when i first start and drive the car for the first 5 mins its fine, runs like a champ but it seems that once it gets warmed up it falls flat on its face when i get on it, it studders and backfires, i dont really wanna replace stuff that i dont have to so looking for ideas here first. my original thought is a bad o2 sensor, please help
scote2583 is offline   Reply With Quote
Old 02-06-2011, 11:09 AM   #2
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Im pretty sure its your timing. Warm up the car and then set your timing with the proper procedures
jacobs13 is offline   Reply With Quote
Old 02-06-2011, 11:11 AM   #3
scote2583
the car is running on stock ecu with no extra tuning , was running about 13lbs of boost, bought car in august ran great up until October, the reason I'm thinking o2 is that the o2 wire looks a little melted from contacting the manifold, it doesn't look melted all the way through though so not really sure
Old 02-06-2011, 11:12 AM   #4
scote2583
what would have caused the timing to go off? and where do I find the proper procedures
Old 02-06-2011, 11:55 AM   #5
Sileighty_85
Sileighty_85's Avatar
check ECU for Codes almost sounds like the Coolant Temp Sensor
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-07-2011, 07:30 PM   #6
JayZeeSILVIA
JayZeeSILVIA's Avatar
JayZeeSILVIA is an unknown quantity at this point
could be coolant temp or o2 sensor. the ecu ignores the o2 sensor until it warms up. replace the wire on the o2 sensor and see if that helps. also if i remember correctly you should have between 0-5v on the coolant sensor depending on measured temp.
SKUNKWORKZ BUILT
JayZeeSILVIA is offline   Reply With Quote
Old 02-20-2011, 01:09 PM   #7
scote2583
weather got nice out and roads were clear so I took the car out an re-evaluated my problem and figured out that it does it right away sometimes when I go WO throttle, my friend who was in the car with me said it sounds exactly like his did when the plugs were toast, so ordered some new plugs and hoping that it is just a simple stupid problem
Old 02-20-2011, 04:25 PM   #8
spartanmisfit
spartanmisfit's Avatar
Trader Rating: (18)
spartanmisfit is an unknown quantity at this point
Feedback Score: 18 reviews
have you checked for boost leaks? Have you checked for vacuum leaks?
spartanmisfit is offline   Reply With Quote
Old 02-20-2011, 06:13 PM   #9
scote2583
yeah, when problem first started that was first check, waiting for my NGK's to get here hoping thats the problem
