Old 07-25-2007, 05:14 PM   #1
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
1piece drive shaft problems
Hey guys... Installed a 1piece aluminum drive shaft today. It wouldn't fit with the dust collar on, so I removed that.. Still wouldn't go on, so I took off the tranny mount and let the trans drop in order to put the shaft on. Even then, I had to pop it in place.. It just barely cleared. Bolted everything back up. Shaft seemed to turn normal.
Heres the problem..
I drove the car around, heard a few funky noises I can't really put my hands on. Several times, but not all the time, when I was coming to a stop.. From about 10mph to a complete stop the car vibrated and shook like crazy. Not a little, a lot.. to the point where the car felt like a giant fucken vibrator.
Any ides what could be causing this?? Could the drive shaft be too long?
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 07-25-2007, 05:23 PM   #2
ReLevent1
ReLevent1's Avatar
ReLevent1 will become famous soon enoughReLevent1 will become famous soon enoughReLevent1 will become famous soon enoughReLevent1 will become famous soon enough
Send a message via AIM to ReLevent1
my guess is the shaft isn't balanced very well
Don't be such a Mc
I BE HERRA JERIFTINZ
ReLevent1 is offline   Reply With Quote
Old 07-25-2007, 05:36 PM   #3
Turbogeek
Turbogeek's Avatar
Turbogeek is an unknown quantity at this point
you'll always get more vibration with a one piece, but shouldn't be extreme. Have it checked out at a driveline shop and contact the vendor you got it from
Turbogeek is offline   Reply With Quote
Old 07-25-2007, 05:48 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
NemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfection
Send a message via AIM to NemeGuero
or replace your tranny/engine mounts.
NemeGuero is offline   Reply With Quote
Old 07-25-2007, 05:53 PM   #5
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
Did you get it from Driveshaft shop? I had to cut off my dust cover as well. You will get some clunking, similar sound if you're running a tranny with no oil. As far as vibration, I'm not get much, if any. Double check what these guys have said above.
mmdb is offline   Reply With Quote
Old 07-25-2007, 10:27 PM   #6
!Zar!
!Zar!'s Avatar
First do as stated and check your engine/tranny mounts.
I'd suggest you rotate your driveshaft and see if that remedies your problem.
Old 07-26-2007, 08:51 AM   #7
DJ_Sunrise
Nothing should have to be rotated, its a 1 piece shaft... I found the problem. The shaft was made so fucking long that the shaft and transmission are rubbing on each other. Fucking assholes cut that shit way too long. Now I have to take the whole fucking thing off and try to sand the flange down. It rubs like a bitch where the trans and shaft connect. Tranny and engine mounts are new Nismos. Tranny brace is at 60ft. lbs. tq. FUCCCKK. Saturday I was supposed to go get my shit tuned.
-Bart
EDIT: Do you guys think I should take a grinder to the yoke and transmission and add a bit of clearance???
Old 07-26-2007, 08:58 AM   #8
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
i think you should return it.... A driveshaft breaks/comes apart is VERY dangerous. Sounds like it's too long, or you ordered it for the wrong diff(ie:vlsd or non)
gotta240 is offline   Reply With Quote
Old 07-26-2007, 10:08 AM   #9
aznpoopy
aznpoopy's Avatar
aznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond repute
Send a message via AIM to aznpoopy
-Bart
make sure you ordered / received the right one
there is a long one for 240sx's without ABS and a short one for 240sx's with ABS. the abs diff is longer than the non abs
aznpoopy is offline   Reply With Quote
Old 07-26-2007, 10:18 AM   #10
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Yeah you shouldn't be grinding on the driveshaft or tranny. You'll alter the characteristics of the driveshaft by taking metal away from it.
You got the wrong one or the guys you got it from don't know how to use a measuring tape.
Take it back and get them to make you the correct size one. Hell I would if I paid that much for a part. Was the shop local? Where'd you get it from?
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 07-26-2007, 10:36 AM   #11
NemeGuero
No more nissan.
NemeGuero's Avatar
Yah, where DID you get it from, so we know not to get it.
Old 07-26-2007, 11:12 AM   #12
DJ_Sunrise
Whats the difference in the ABS and non ABS cars? Are the diff outputs longer or shorter??
-Bart
Old 07-26-2007, 12:13 PM   #13
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
ABS diff is longer - driveshaft shorter
so if you put a non-abs (longer) driveshaft and used ABS diff, shit will be too long.
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 07-26-2007, 12:14 PM   #14
Dream240
Dream240's Avatar
Actually it's the differential inputs that are different. Do you have ABS or not?
If your shaft is too long then you either got one for non-abs and you have abs, or you got one for auto and you have a manual tranny ~ IIRC.
Personally I love it when girls tell me my shaft is too long.....
Old 07-26-2007, 12:48 PM   #15
uwntsum
uwntsum has made poor choicesuwntsum has made poor choicesuwntsum has made poor choicesuwntsum has made poor choicesuwntsum has made poor choicesuwntsum has made poor choicesuwntsum has made poor choicesuwntsum has made poor choices
I kinda skipped through some of the other posts. But this sounds like a Driveshaft Shop (DSS) 1pc alum driveshaft. I had the same problem. Drive shaft was 1.5 inches too long. Which ended up destroying the rear section of the tranny along with the bearing. If you line it up with ur stock driveshaft you will notice the difference. In any case DSS didn't do anything about. I had to bring it to a local driveshaft shop where it was cut and shortened and re-balanced and i put in new U-joints since the owner was complaing how crappy the joints were. Not to mention DSS used some cheap rivets to apply weights to the driveshaft. Really bad expierence with DSS.
Another note, I told DSS that my car was a Base model S14 w/ no abs. The box and label on the box stated non-abs. My fault for not mocking up the stock one to the new one before installing. Lesson well learned. But DSS is claiming they sent the correct one.
uwntsum is offline   Reply With Quote
Old 07-26-2007, 12:53 PM   #16
aznpoopy
aznpoopy's Avatar
see the above five or six posts and next time don't skip
you bought the wrong length driveshaft
they make two different ones for s-chassis cars
Old 07-26-2007, 01:29 PM   #17
Dream240
Dream240's Avatar
Well in DDS defense, I ordered a Steel one-piece and they sent me the right one, fit perfect, works perfect.
What I don't understand was the second you saw that it didn't fit what did you do? cram, beat, curse, and generally will that thing into place? I would have pulled it out, took some pictures, and then proceeded to contact the shop. I'm sure you could have gotten it resolved peacefully through them. I hear almost nothing bad about DDS driveshafts, and my own experience supports that.
Oh and so you know, the u-joints that they used on mine were OEM. I had to wait an extra month so that they could get them in stock. And from what they said they had quite a few orders on hold until they got them in. Sounds like the "shop owner" you went to ripped you off. I've heard stories like yours a million times. $120 bucks later you think you got a good deal and you're thankful to the owner for pointing out your "poor quality" part. Gimme a break. I hate assholes like that, they really make the auto repair industry suck hairy balls.
Sorry but you just got ripped off. Far as I can tell your story is an isolated DSS incident.
Old 07-26-2007, 03:29 PM   #18
!Zar!
!Zar!'s Avatar
Not quite topic related being as how you've pretty much found your problem, but rotating the shaft can remedy vibration. It's a little trick that I've seen work.
Old 07-26-2007, 03:34 PM   #19
DJ_Sunrise
My car does not have ABS.. But I do have a J30 LSD. Is this something that might have fucked it all up?? Ughh.. this fucking blows. I was supposed to go to DSG this saturday.. If I have to call this thing off again, it'll be the 3rd time I schedule an appointment.. The shaft spins by hand, so it isn't hitting the tranny that bad.. Just when I'm coming to a stop below 5mph occasionally.. Sometimes it doesn't "hit" the tranny I guess, and doesn't make the crazy vibration. I was thinking of grinding the tranny end down a bit just enough so I can get to DSG(5 hr drive) to get my car tuned and back.. Probably not a good idea. One word sum's everything up. FUCK.
-Bart
Old 07-26-2007, 04:55 PM   #20
aznpoopy
aznpoopy's Avatar
yes... as stated earlier its the diff size affects how long the driveshaft should be . that's why dss specifies abs vs. non abs
i guess the j30 LSD is too long for the non-abs dss shaft.
Old 07-26-2007, 05:22 PM   #21
NemeGuero
No more nissan.
NemeGuero's Avatar
It is. As long as your J30 diff has the ABS sensor.. thats why it won't fit.
Old 07-26-2007, 05:36 PM   #22
DJ_Sunrise
Fuck. My fault there then, not the guys.. I got it from ujointmaster on ebay. I told him it is too long and why. He is going to cut it down a bit, and sent it back. Should be back in a week.. Until then, I'm replacing the center bearing on the old drive shaft. NOTHING is stopping me from going to DSG this weekend. ITS FUCKEN ON!!!!
Do you guys know if the center bearing presses out, or what?
-Bart
