![]() when i bought the car the drivers side window would not go down however the passanger side would and the sunroof worked fine. the switch for the driver side window was loose and f'd up. Recently the passanger window and the sunroof went out at the same time. anyone know why? my guess was a fuse but i couldnt find a window fuse. ive read the amp could need to be soddered but would that wipe out all the windows? any help would be nice
#2 | |
To answer your question, not sure if the "amp" supplies power to your sunroof.. i would check relay's and then possibly check out the "amp" just to make sure the solder points look ok.. I remember hearing something about the passenger side possibly having a amp as well so.. Hope this helps! |
#4 | |
![]() 95 240sx RB20 415whp 91 Nx2000 VVL yo |
![]() Join Date: May 2011
Did you get the complete switch with auto-down feature? New, from where? Mine is pretty worn out and will need a replacement someday.
I had my driver window stop working over the weekend. It would make a "click" when I'd use the switch. I took the amp out, moved the wires, and it worked enough to get the window up. Time to take it apart and check for soldering... Thanks for the tip. |
There is a test procedure on the FSM to test if the switch is good or bad.
The sunroof gets its power from the power window relay so that's a good place to start along with the power window fuse. If the driver window does not work, check amp, motor, and the switch. "Click" usually means the switch is working. |
Hrm...correct me if im wrong, but wont the passenger window not roll down if the window amp is fried? This happened to me not to long ago. It actually came down to my window motor being fried
#8 | |
Man w/ CTSV & a Car Seat
Like already stated, most of the time, for early S14s, the problem is a bad amp box. Most folks just resolder some bad joints on the board. Mine didnt have anything that looked bad but I replaced it anyways and fixed my driver side window issue. |
#9 | |
Gotcha, thanks for the clearing that up for me. That makes perfect sense. |
![]() Join Date: Jun 2009
Since this question was answered and I'm having a window issue as well....Thread-Jack!
Problem: When I press down on the switch, the window goes up and also has auto-up. When I press up on the switch, the window goes down. Thoughts? It doesn't appear that the stock harness has been hacked on or modified at all. |
#11 | |
![]() Join Date: Jan 2007
Tags |
amp, fuse, motor, switch, window |
