![]() ![]() ![]() Feedback Score: 1 reviews
Need info on KA24DE Rebuild
Hey guys, I was actually looking for different motors to actual swap in my s14 but all swaps cost a goo amount. Therefore, I was thinking about just doing a full rebuild and just add forged pistons, bc cams, springs, retainers, rocker arm stopper and a metal head gasket. Is there anything else, or any other way you guys may know what to do. My power range would want to be at approx. 350-400hp and it will be my daily driver. So please any kind of input would be very helpful. I would also want to know if I should machine it, or do really need to? Please help. It will be pushing boost.
#4 | |
![]() Join Date: May 2008
...what engine do you currently have? that's definitely a pretty hefty list to only make 350whp... what are you going to be doing about fuel management? how do you intend on installing new pistons WITHOUT machine work? at the least get the block and cylinders checked for roundness and taper. if your going with a metal headgasket, id expect you would definitely want to get the block and head machined as flat as possible for the best seal. there are too many variables to really go on and on with your request. you need to give some more info. what engine what fuel management what turbo / manifold setup how much PSI what kind of fuel what compression ratio ignition setup?
![]() Join Date: May 2009
KA's don't have rocker arms....
That's what he was getting at in terms of ignorance. Just make sure you do your research in terms of what actually needs to be done to a KA for a rebuild. It's been covered a million times... Just go read up some then come back and post what you think you need to have done and if you're missing anything and I'm sure everyone will be much more likely to help you. Since you posted rocker arms stoppers he's calling BS. |
Also, if it's a KA, do not go with a metal head gasket. Go with a felpro. They hold up really well so long as you've done all the work. The metal head gaskets don't do so well with the KA24de.
Well, that's what I want to know. I want to keep the price as low and possible. So I will definitely keep the felpro gasket in mind. I was just looking for a kit that is affordable but also lasts. Im scared to go thru ebay and get it that's why. Other thing is that, I don't know much about rebuild, but I just believe my motor would need one if Im gunna be running boost. So let me rephrase my question: Whats the most affordable thing to do in order to push 350hp? What would I need to get in order to run that power with probably 12psi on 91octane? Im just looking for the cheapest route in order to boost my KA24de without blowing the motor.
#8 | |
If you want to make that much power for cheap go get a engine swap. You list of mods will not get you to your power goal any cheaper then a engine swap with some supporting mods. Also cheap and boost do not go together, buck up and spend the money or just leave it stock.
![]() Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
#10 | ||
main thing I consider when building a project, is determining what it will be used for. next is the budget I have to invest into it, to achieve that goal. The ka24de is a strong engine. it is NOT a motor. motors indicate electrical, engine is mechanical. At least start by learning the correct technical nomenclature. you can invest as little or as much into the engine as possible, depending on how deep your pockets are. what is it you are going to do with it? you are going to have a 400 hp daily driver? youll dump 2500 in the engine before you know it. Priority is important. No sense in buying forged pistons and connecting rods, when you dont even balance the crankshaft, line bore and hone, deburr and clean the other parts... Ideally, it is a very bad idea to half ass anything that is mechanical, so start by taking a big breathe and be patient. The more patient you are now, the more satisfied you will be in the end, when it is all done right, and you dont throw a rod thru your hood. Start small, stick to your goal. budget should be the last concern as far as priority. if you dont have $ to invest, then dont build a toy. set aside 2500-5000 bucks to get you started, and take that amount and prioritize your upgrades. This is why car tuners work in stages... stage one, two, three, and so on. You cant put stage three parts in a stage one block and expect to have a reliable hot rod. its just unrealistic. start over, take your budget, goal, and a list of priorities, and start from there. For a DD hot rod, start with some wheels, tires, brakes, some suspension, maybe seats, shift knob, or ecu modifications with exhaust and intake upgrades. to start. keep it simple, again. Quote:
why not just slap on some nitro and get your fix as you need, and save a bit of $. last time I checked, it was a bit cheaper to add nitro compared to a turbo setup. both can be done safely to add efficiency to a car or more hp, but you target a certain hp not for the faint of heart. Your Engine will need some serious love and work. so just sit tight. trust me, if you listen to the guys on this forum and keep it cool, youll be much happier in the end, when you are driving down the strip with your friends and you dont blow your shit up... simple things: forged is better that cast, so dont buy cheap connecting rods or pistons. and find pistons with a lower level of silicon in them... Id like you to find out why that is, especially when you are considering turboing your non turbo engine. did you know that turbo engines have less compression that N/A engines? do you know why this is? do you know to what HP it is acceptable NOT to buy a standalone ecu.? what are you going to tune it with? got a laptop and nistune? do you even have a garage you can store your project in and work on it late nights for months with your friends? and youll want to run high octane in your car dude... why buy the cheap shit? its the chemical reaction from the petro that gives you the power. 12 psi is a good bit of pressure for a N/A engine as well... best read up son. there are tons of great technical sections, articles, and how toos on this site alone, let alone what you can find on google. example, today I found the entire fsm for each s chassis from 89-98 and dl'd them to my hd. do you have your fsm and have you even looked at it? things to consider is all. Dont take it personal, hope im not rude, but im honest, you gotta read up, and do your research. best of luck. im rambling cause its late and i really need to go to bed. |
![]() Join Date: Aug 2011
All I can say is you're only 22 years old.
Live life, enjoy the car as is. Don't like the performance? It's cheaper just to buy a 350z than a track 240sx. |
#13 | ||
mo·tor ˈmōtər/Submit noun 1. a machine, esp. one powered by electricity or internal combustion, that supplies motive power for a vehicle or for some other device with moving parts. motor - definition of motor by the Free Online Dictionary, Thesaurus and Encyclopedia. mo·tor 2. A device that converts any form of energy into mechanical energy, especially an internal-combustion engine or an arrangement of coils and magnets that converts electric current into mechanical power Would you like me to go on or do you understand how much of an idiot you sound like?
You guys all made my day.. THanks!
In a strictly physics sense an engine converts energy into mechanical work.
A motor is a subset of engines that produce motion as the mechanical work. So zerodameaon is technically correct. |
lolz google?
here is something a lil more legit, imo. care to bash away. Search -- Encyclopedia Britannica vs Search -- Encyclopedia Britannica I stand my ground on that. bust still, either way, people call it motor engine, its all the same. |
#17 | |
#18 | |
![]() ![]() ![]() ![]() ahh and just to add, to the legitimacy of your post, just because its on google doenst mean its true. I mean, we all know it wasnt really aliens... but it was aliens... come on. technically, its a machine... but still both an engine and a motor. its true... |
#19 | |
Wait a moment are you by chance GarageMakS14 or just our new forum troll?
#21 |
![]() Join Date: Feb 2008
Patience and the know how are two things that you will need to tear you're car down and put it back together. Checkout ka-t.org/forums great bunch of information for many types of builds good luck.
#22 | |
Nothing more to add? I just wanted to post this up in case you actually never read it. http://www.nicoclub.com/FSM/240sx/1989/1989.pdf I swear so help me god if you fucking call it a motor one more time,.... READ the table of contents!!!! MOTOR doesn't exist, except in the certified lable, NISSAN MOTORS, as a corporation name. PHYSICS wise, referring to the device which takes THE chemical energy and makes the MECHANICAL work, NISSAN and others, call it an ENGINE...... come on, no offense and all, but you stuck your head out there. ![]() I dont hate ya.... so dont take it personally. even on your forums here, the other section to this techtalk forum, its called engine tech, not motor tech. seeing a techncial trend here? Last edited by StupidMonkeyBeSpankinIt; 12-24-2013 at 01:21 PM.. |
#23 | |
The KA is a stout motor, with some work they can put out good power for only being a I4. Happy? Nissan may call it one thing but you were not referring to only Nissan and do not try to say you were because you would be lying.
And nice try with the FSM, motor is mentioned 250, a few of those times it refers to their name.
#24 | |
Did you even click the link, nvm, ill post a screen shot so we all can see and before I do that, Ill take the time to draw a few pretty lil circles around the clues that lead me to my idiocy, as you so clearly insinuate. and yes, even though my initial response to about a ka24de, to the op, that specifically is an engine. put the hot glue gun down, and step away from the fumes... ![]() |
#25 | |
You are the one who needs to step away from whatever you are smoking. You are arguing semantics, and at this point I no longer think you are a troll but dead serious.
You sir are the one who is ![]()
#26 |
OH!
Now I get it, YOU'RE are the troll. Thanks for pointing this out. You can have whatever opinion you want. Fly safe my friend! < Seriously hopes there is a block function in this forum... or else Im forced to remember exactly who the fucking retards are. |
#27 | |
Go head block me, we need to get this thread back on the topic of rebuilding this guys motor anyways.
#28 |
perhaps instead sir, I should draw a long line and arrow pointing to the circles on the fsm? I mean, nissan made the ENGINE, and they made the MANUAL, maybe it is all a misprint, like on every single fucking fsm they ever printed. I wonder what chevy and ford, and jaguar call it too, in their fsm's, should I continue to allow you to dig yourself in a lil deeper? I would love to, but i really dont have time to waist anymore, I have proven my point.
maybe youll take wiki, which is not a valid source of factual information, but rather a knowledgeable source of information... http://en.wikipedia.org/wiki/List_of_Nissan_engines funny, theres that word again, relating to what did you call it again? a motor? |
#30 | |
You are grasping at straws, grasping at straws and nothing more.
Tags |
ka24de, ka24det, rebuild ka24de, s14, turbo |
