Old 11-14-2008, 12:55 PM   #1
monkz2332
Banned from the Marketplace
monkz2332 is making a name for him/her selfmonkz2332 is making a name for him/her selfmonkz2332 is making a name for him/her self
Send a message via MSN to monkz2332 Send a message via Yahoo to monkz2332
s13 Brake Lights Wont Shut Off!!!!!
i have some kind of electrical problem with my s13....when the car is completely off the brake lights stay on and i idk whats going on some one help me out.
monkz2332 is offline   Reply With Quote
Old 11-14-2008, 03:34 PM   #2
projectRDM
projectRDM's Avatar
Brake switch is damaged or the stopper is missing from the pedal. Unplug the switch, if the lights go off then check for freeplay on the pedal, stopper engagement, or a defective switch.
FORMERLY R240NA
Old 11-14-2008, 05:42 PM   #3
monkz2332
thanks a lot ill check it out
Old 11-14-2008, 05:54 PM   #4
monkz2332
where will the switch be
Old 11-14-2008, 10:18 PM   #5
mobilesuit818
mobilesuit818's Avatar
mobilesuit818 is an unknown quantity at this point
Look under your dash on the driver side, its located on a bracket thats connected to your brake pedal. There is a switch with a little button that the pedal hits.(when pressed)
Just be careful not to break the connector.
You can usually adjust it (loosen) and that should do it.
hope that helps.
mobilesuit818 is offline   Reply With Quote
Old 11-14-2008, 10:20 PM   #6
zorak
zorak's Avatar
zorak is an unknown quantity at this point
Send a message via AIM to zorak
That little rubber stopper thing has caused me a lot of grief before.
zorak is offline   Reply With Quote
Old 11-14-2008, 11:08 PM   #7
monkz2332
ok thanks alot
Old 11-15-2008, 12:13 AM   #8
projectRDM
projectRDM's Avatar
Where else would it be?
FORMERLY R240NA
Old 11-15-2008, 06:33 AM   #9
Brentbohn
Brentbohn's Avatar
Brentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choices
this is so simple, look at the brake pedal and the contact switch is bad, most likely pushed in or rusted up. this has been answered a million times.
Brentbohn is offline   Reply With Quote
Old 11-16-2008, 12:10 AM   #10
s13sd858
s13sd858 is an unknown quantity at this point
lol everybody had this problem including me, I just electrical taped a nickel inplace of that rubber stopper and it works just right now. I put pennys before but that shit drops unless you fucking epoxy that shit. This is an easy fix, look at your break pedal then look up or follow the metal shit on the brake pedal. There should be a rubber stopper there that when it contacts to the switch, it stops the brake light. If there is a circle hole, taht means your rubba stoppa is gone.
s13sd858 is offline   Reply With Quote
Old 11-16-2008, 06:40 AM   #11
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
i have af unny storry about this.
one day i was driving and i noticed some little rubber grommet thingy by my feet, and i was like what the fuck is this? where did this come from? so i picked it up and just threw it out the window....
a couple hours later at night, i was like err...why are my brake lights not turning off. a couple minutes later i was like aw shit, that's what that rubber thing was. but yeah, i just got a bolt and nut and secured it in place. brakes work. i didn't think of the nickel and tape idea thought, that's pretty interesting.
but yeah your brake light switch is the ONLY THING NEAR/TOUCHING THE BRAKE PEDAL THAT LOOKS LIKE A SWITCH. IT HAS WIRES COMING OUT OF IT AND A BUTTON.
clark is offline   Reply With Quote
Old 11-16-2008, 07:19 AM   #12
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Except for the cruise control cancel switch, if you have cruise. It cancels cruise when you hit the brakes.
g6civcx is offline   Reply With Quote
Old 11-17-2008, 11:53 AM   #13
monkz2332
ok i got cruise control it works...o yeah its automatic
Old 11-17-2008, 01:05 PM   #14
monkz2332
^^^^^ ok nvr mind i fixed it i did that the nickel thing but i dont think it will stay..any other soultions?
Old 11-17-2008, 01:18 PM   #15
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
M6 bolt and nut (AKA 10mm bolt)
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 08-06-2009, 06:55 PM   #16
miklos
miklos's Avatar
miklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choices
I can't get a bolt in that hole. The steering column is in the way and I can't push the brake far enough from the switch.
miklos is offline   Reply With Quote
Old 08-08-2009, 04:01 AM   #17
unethical3
unethical3 is an unknown quantity at this point
I just got a '91 240SX and i had the same problem..its a quick fix...it took me about 5 mins total..
Go to an Auto Zone or Pep Boys or something like that and get some push pins that are made for door panels...get the BIGGEST ones you can fine...i paid like $2.50 for 6 of various sizes...
sit on the ground on the driver side take a flash light and follow the brake pedal up to where you see it flaten out to a plate...if ur lights stay on that means the rubber plug came out...
if you have cruise control there are 2 stoppers... you can find the hole for the stopper by looking at the 2 plugs connected to the brake pedal.. 1 plug has 1 wire and the other plug has i believe 3.
if you look at the pin the plug is connected thru you will see the switch that the pedal pushes...only thing you have to do is use ur hand to push the brake down as far as you can and pop the push pins into both holes...
i was able to do it after like 4 attempts... i had to do it b4 hooking up a remote start to an older car and in the process of hooking up the brake wire i popped the rubber pin out and it broke up...lol (i worked at circuit city)
good luck!
unethical3 is offline   Reply With Quote
Old 08-08-2009, 01:06 PM   #18
JAKracing
JAKracing's Avatar
JAKracing is an unknown quantity at this point
i used RTV and a quarter....lol. i tried the tape thing, but that shit was pissing me off
JAKracing is offline   Reply With Quote
Old 08-11-2009, 08:06 AM   #19
240knockout
240knockout's Avatar
240knockout is an unknown quantity at this point
rubber stopper from dealer is like 2 bucks.
240knockout is offline   Reply With Quote
