Old 06-05-2013, 02:39 PM   #1
josheh94
josheh94 is an unknown quantity at this point
Sr20det no fuel pressure after fpr
hi guys any help would be greatly appreciated, I did my first sr20 rebuild and I am getting almost no fuel pressure after fpr, about 1 to 2 psi, I am getting above 60psi going into the fuel rail, so I think there is a problem in the between the fuel rail and the fpr. I have tried to switch to stock fpr and still the same as the nismo and have tried a different fuel rail. tried googleing for hours and am getting extermly frustrated and just want to get my car running again, so any help would be greatly aprrectiated
josheh94 is offline   Reply With Quote
Old 06-05-2013, 03:24 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
The FPR is what controls your pressure. You measure your fuel pressure before the fuel rail and fpr. You see minimal pressure on the other side of the fpr since its just the return line back to the tank.
But if you're seeing 60 psi before the rail, you need to crank that down to 40-42 psi static (meaning disconnect the vacuum line to it while you adjust it down).
CLICK HERE!!!
Old 06-05-2013, 03:37 PM   #3
nickauger
nickauger's Avatar
nickauger is an unknown quantity at this point
Are you sure you have not mismatched fuel pressure/fuel return line ... ?
nickauger is offline   Reply With Quote
Old 06-05-2013, 03:39 PM   #4
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Just as Flip said, you shouldn't have pressure after the regulator, only volume.
My SR20VET
Old 06-05-2013, 06:31 PM   #5
josheh94
thank you so much for the fast reply guys, you saved me a couple of days of bashing my head up against the wall, flip was totally right
Old 06-06-2013, 06:32 AM   #6
Mikester
Mikester's Avatar
Mikester is a well-known jackass
^^Yea he's good like that once in a while
Mikester is offline   Reply With Quote
