Old 07-10-2016, 07:33 PM   #1
claaasssiiiccc21
claaasssiiiccc21's Avatar
claaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura about
S14 Subframe Stud snap/torque spec
Alright guys, I'm trying to avoid the "Fuck Me" moment with snapping off one of the 4 subframe studs while tightening up my subframe after my SPL bushing install.
The FSM says 72-87 ft/lbs
SPL says 72-87 ft/lbs
Now, when you hear about all of these guys snapping these studs off with breaker bars and whatnot, are they exceeding the torque spec or are these studs cheese and should we run them looser than spec, say "good and tight"? 72-87 ft/lbs seems pretty damn tight for an M12 bolt, considering the crank pulley bolt is double the size and is only 105 ft/lbs...
Looking for input and looking to learn from someone else's mistake so I don't make it myself.
Thanks guys and gals!
LSB E46 M3. Causing my S14 to collect dust since 2009.
claaasssiiiccc21 is offline   Reply With Quote
Old 07-10-2016, 07:44 PM   #2
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
I've never heard of anyone breaking a subframe stud while tightening. I've always torqued mine to 80ft lbs without any problems. 80ft lbs isn't squat. I've seen far higher torque specs for M12 hardware.
dbeiler is offline   Reply With Quote
Old 07-10-2016, 11:03 PM   #3
claaasssiiiccc21
Awesome, thanks so much for the input!
Old 07-11-2016, 08:32 AM   #4
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
I think more people have issues with them when attempting to remove than reinstall. Make sure you clean the threads and use anti-seize compound on them.
My SR20VET
Old 07-11-2016, 12:58 PM   #5
claaasssiiiccc21
I use copaslip (copper anti-seize) on all of my fasteners, but have always heard the lubed vs un-lubed torque specs and how there is usually about a 25% difference. So given we are at ~80ft lbs, I didn't want to effectively crank her up to 100 given nissan most likely used no lube and obviously had fresh distorted nuts.
I am overthinking as usual.
Thanks!
Old 07-11-2016, 01:50 PM   #6
andisan
andisan's Avatar
Better safe by asking then getting in those "what now situation"
