08-31-2008, 07:57 PM | #1 |
Removing aftermarket steering wheel
OK heres the scoop, i need to fix me horn and i wanna do it right. I have a steering wheel puller and it aint ganna do it, im going tommorro to get a pulley puller instead.But if that dont work does anyone have any ideas? or does anyone know what type of pulley pullers work best.? im prolly ganna end up with the 3 offset slots type.(donnu what its really called) But i have seen many types... any input would be great, only asking for help because this REALLY pisssed me off! simple right?-false.
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
08-31-2008, 08:13 PM | #2 |
just sit in your drivers seat and take the 19mm steering wheel nut off. grab the wheel at 10 and t2, push up with your knees at 5 and 7 and jiggle it till it comes off
08-31-2008, 08:24 PM | #3 |
loosen the nut but dont take it off completely, just have your hand at 3 and 9 position and rock back n forth until the wheel comes loose
but for a aftermarket wheel, u can probably just use the hex key and get the wheel off and leaving the hub on
91' 240sx Fastback LE |
08-31-2008, 08:24 PM | #4 |
^^^ That's not a bad plan. The pulley puller most likely won't work (at least I haven't seen one that works). Sucks you didn't do it right the first time... I'm guessing you have to take the hub off because you didn't connect the one wire that goes to the horn?
08-31-2008, 08:31 PM | #6 | |
08-31-2008, 09:04 PM | #7 |
OK thats not ganna do it, im a decently stong person but it wont budge. I understand leaving the nut on, if that thing did come of it would knock the shit outa me. Its still on, im just afraid the hub will be bent be the puller.
08-31-2008, 09:10 PM | #8 |
It's not so much pulling straight back (you'll never get it off), but pushing on one side, pulling the other. You're trying to "bend" it off the spline. If your hub is as shitty quality as mine is, I'd be afraid of what a pulley puller would do to it also lol.
08-31-2008, 10:14 PM | #9 |
Have you tried a 3 jaw puller?
08-31-2008, 10:51 PM | #10 |
lol.....
step 1- take off nut and leave wheel on hub step 2- take key out of ignition and lock steering step 3- forcefully turn wheel left and right while pulling back wheel should come off like nothing.... mine came off within a few seconds using that method |
09-01-2008, 12:16 AM | #11 |
I've pulled over a hundred wheels by now and never used a puller. Just do as suggested, 'rock' the wheel off the splines by shifting it side to side and up/down.
09-01-2008, 06:41 AM | #14 |
09-01-2008, 11:45 AM | #15 |
Yeah, I've removed countless wheels and hubs. Just unscrew the 19mm a little bit but not all the way and then rock the wheel as you pull with a few jolts.
What people mess up on is tightening the 19mm too much. You're only supposed to torque it down to like 20ftlbs.
09-02-2008, 11:01 AM | #18 |
For some of you that missed it, its already after market. I have pulled the stock unit a long time ago. And I got it off, i used a pulley puller, its was 12$. The 3 jaw type.Then i sodered the horn wire to the metal ring in the hub. Oh yea,I havent had power steering for a while so thats prolly why it was such a biatch, pwr steering is next to fix.Thanx for all the input, ill remember those methods next time, or if a friend has the same prob.
