05-27-2010, 10:16 AM | #1 |
small block 240sx 95 info needed
if anyone have done this swap i will be thankful for all the info that you can give me. the motor is a 406 small blck 700r4 trans 300z rear end if that helps any. i got the mount kit already. before i start i was trying too see if anyone had some tips other than not doing it lol.
05-27-2010, 11:10 AM | #2 |
406 small block Chevy I presume.
What do you want to know? Expect to save a lot of money. Set the engine and transmission in the subframe. Bolt up the diff. You'll need a custom Driveshaft Shop driveshaft to mate the gearbox up to the diff. Not a big deal since it's not expensive. Just call them. Mount your drive belt system. Run all your plumbing for fuel and air delivery, cooling, power steering, a/c, etc. Install your ignition system and wiring. Very easy if you have carb(s). |
05-27-2010, 12:46 PM | #4 | |
That's why I said mount the drivetrain first before anything else. If you can't mount then spend money or quit. |
