Old 04-03-2013, 10:21 PM   #1
Jdm bastard
Jdm bastard is an unknown quantity at this point
s13 Wondering how to properly remove a/c and p/s
Just wanted to keep it simple and ask how to remove ac lines? Remove pressure/refrigerant? And the same goes for the p/s? Do I plug the high and low pressure lines into the rack and pinion? And I still run the reservoir? Any help is appreciated
Jdm bastard is offline   Reply With Quote
Old 04-04-2013, 12:23 AM   #2
milto0n
milto0n's Avatar
milto0n is an unknown quantity at this point
Ac removal is easy (a little more difficult if you have ABS). It's mostly a matter of following the lines are removing everything. Here is a write up:
S13 A/C Removal Writeup : 240sx General Discussion
I haven't removed power steering since I can't live without it but if I am not mistaken you can potentially ruin your steering rack.
milto0n is offline   Reply With Quote
Old 04-04-2013, 02:13 AM   #3
Croustibat
Croustibat is an unknown quantity at this point
A non assisted steering rack uses some fluid to lubricate. A power assisted steering rack use the steering fluid to cool and lubricate. You cant juste remove the pump and the lines to depower it. One way to do it is to disassemble it completely, make holes in the piston, reassemble then fill with fluid and loop each side line together. This way you still have lubrication and relatively lower efforts due to the piston being drilled.
Best way would be to use a non assisted rack though.
Croustibat is offline   Reply With Quote
Old 04-05-2013, 03:44 AM   #4
pewpew
pewpew's Avatar
pewpew is an unknown quantity at this point
Send a message via MSN to pewpew Send a message via Yahoo to pewpew
p/s delete
Converting a S13 240SX steering rack from power to manual steering
I followed this guide, and have had great results.
Don't mix booze and car batteries...it gets expensive, quickly.
pewpew is offline   Reply With Quote
Old 04-08-2013, 12:11 AM   #5
90240sx07
90240sx07 is an unknown quantity at this point
how does the steering feel compared to stock
ive driven s13's with no power steering and can drive them but they dont react nearly as well while drifting and my new chassis has a leak and cant figure out where from
90240sx07 is offline   Reply With Quote
Old 04-10-2013, 08:39 PM   #6
supersmashboi
supersmashboi's Avatar
supersmashboi is an unknown quantity at this point
pm me if willing to part with ac bracket
supersmashboi is offline   Reply With Quote
air conditioning, lines, power steering pump
