Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
05-22-2012, 10:01 AM | #1 |
JIC's bouncy
Just bought some new flt a1 and currently have all 4 of them set to "5" on the dampening right in the middle of their setting. If the front end is bouncy over bumps would I want to go softer on the dampening or harder?
05-22-2012, 11:07 AM | #6 | |
wow... so much misinformation here.
1) if the JIC coils you have include an adjustable lower shock mount, set NO preload. just enough to make the spring sit evenly and flush with the camber plates. no spring compression! 2) your dampening is ALL WRONG. why you would set for 50% dampening front AND rear is beyond me. do you know how to use your own shit? maybe research before you buy shit. its simple a softer dampening setting will result in more grip in the front. the harder you go the MORE understeer you get. same for the rear. except harder settings will encounter oversteer. 3)hey bump stops. stfu 4) plain and simple. lower that shit to 1 on all 4 corners and it will fix your problem.. 5) Quote:
these are the guidelines i follow. I have RYO coilovers and they feel better than any other. mainly because they are setup right. you must fine tune your dampening to your liking but you always start at the low point and go up. not start in the middle. for reference i have mine set to 1 on all 4 corners. super grippy in the rear for traction while drift with zero understeer up front. havent even fine tuned it yet because i ran my first even like this and it felt great. |
05-22-2012, 12:40 PM | #7 | |
I did not know that, hence the reason I made this thread, I figured the middle would be a good starting point instead of completely soft or all the way hard. |
05-22-2012, 01:30 PM | #8 |
there are multiple suspension faqs and other great threads found on Google. i think people are scared to research this shit. i learned this shit thanks to Google back in high school....
