Old 12-24-2008, 08:01 PM   #1
gerson408
gerson408's Avatar
gerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymore
ka24de intake manifold
hey guys just asking if any one has a write up on how to remove the intake manifold the engine i have is a ka24de.
gerson408 is offline   Reply With Quote
Old 12-24-2008, 08:06 PM   #2
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
just look at it then pull bolts off
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 12-24-2008, 08:08 PM   #3
Sileighty_85
Sileighty_85's Avatar
Yeah Nissan Made one its called an FSM
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-24-2008, 08:12 PM   #4
gerson408
gerson408's Avatar
sorry buy my question actually is does it come off as a whole or is the bottom part supported by brackets??
Old 12-24-2008, 08:39 PM   #5
yota man
yota man's Avatar
yota man is an unknown quantity at this point
Yes, you have to unbolt the brackets that are attached to the lower manifold and the block.
yota man is offline   Reply With Quote
Old 12-24-2008, 08:44 PM   #6
s13boy89
s13boy89's Avatar
it comes off as 2 pieces the bottom then the top
Old 12-24-2008, 08:54 PM   #7
projectRDM
projectRDM's Avatar
There are two lower brackets. Throw them away once removed.
You can remove it in one piece or two, your call.
FORMERLY R240NA
Old 12-25-2008, 10:12 AM   #8
gerson408
gerson408's Avatar
alright cool i just wanna remove the top piece to get to this hose thats leaking coolant.
Old 01-01-2009, 03:17 PM   #9
gerson408
gerson408's Avatar
ok
alright so guys ran into another problem i fixed the hose that was leaking and put everything back together the way it was now when i go to crank the car it wont start all it does is crank and wont start. please get back to me asap
Old 01-01-2009, 03:25 PM   #10
projectRDM
projectRDM's Avatar
Vacuum leak more than likely, or you left a plug loose.
FORMERLY R240NA
Old 01-01-2009, 03:26 PM   #11
gerson408
gerson408's Avatar
i
alright ima check all my vaccum lines and see whats going on ill be back on in 5 mins
Old 01-01-2009, 04:14 PM   #12
gerson408
gerson408's Avatar
if it was a leak the car would still start thought right??
Old 01-01-2009, 05:14 PM   #13
gerson408
gerson408's Avatar
ok
thanks to those who helped me. fixed it
Old 01-01-2009, 07:08 PM   #14
projectRDM
projectRDM's Avatar
Culprit? A large enough vacuum leak would not allow it to start, yes.
FORMERLY R240NA
Old 01-01-2009, 11:02 PM   #15
gerson408
gerson408's Avatar
it wasn't a vaccum leak its just i crossed the lines that go to the fuel filter and fuel line
