Old 04-03-2002, 08:00 PM   #1
91blk240
91blk240 is an unknown quantity at this point
Call me a n00b, but will 17x7.5 inch wheels work with 215's for the tires?
RIP: 91 Black Coupe - Lost in Katrina
Current: 93 Black Coupe blown s13 blacktop
91blk240 is offline   Reply With Quote
Old 04-03-2002, 08:03 PM   #2
crazycuban
crazycuban is an unknown quantity at this point
I have 225's on my 7.5 rims.
crazycuban is offline   Reply With Quote
Old 04-03-2002, 08:30 PM   #3
91blk240
any others with thoughts on this???
Old 04-04-2002, 11:00 PM   #4
95SEowner
95SEowner is an unknown quantity at this point
215 will work fine. I have Fikse Fm/10s for my 95 that are 7.5 up front and 8.5 in the rear, and I'm going with 215/45-17 and 245/40-17 which should hopefully fit nice and flush, and also maintain the same overall diameter as the 205/55-16s that are on there now.
hope that is helpful!
Later
95SEowner is offline   Reply With Quote
Old 04-05-2002, 12:39 AM   #5
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
I suggest you get a 225/40/17 or 225/45/17.  A 7.5" wheel is very capable of supporting a tire that wide...so use that width and increase your contact patch.
LanceS13 is offline   Reply With Quote
Old 04-05-2002, 12:46 AM   #6
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (LanceS13 @ April 04 2002,02:39)</td></tr><tr><td id="QUOTE">I suggest you get a 225/40/17 or 225/45/17. A 7.5" wheel is very capable of supporting a tire that wide...so use that width and increase your contact patch.</td></tr></table><span id='postcolor'>
running a 215 in comparison to a 225 might give a small advantage of sidewall stiffness.... as the sidewall will lean "in" a bit in comparison to the 225....
AceInHole is offline   Reply With Quote
Old 04-05-2002, 01:06 AM   #7
LanceS13
AutoX Junkie
I think any difference in sidewall flex would be negligible compared to the difference in contact patch between the two tires. &nbsp;My 225's, for all practical purposes, are pretty much verticle on my 7.5's. &nbsp;A good stiff-walled performance tire will make better use of contact patch than just slightly more sidewall support.
Old 04-05-2002, 10:37 AM   #8
diabolic hippo
diabolic hippo is an unknown quantity at this point
i'm confused, i have a s13 to, i've been told i can tuck up to 17x10's on a s13, i have 18x7's right now and that looks like to would just barely tuck. can your 7.5's tuck
diabolic hippo is offline   Reply With Quote
Old 04-05-2002, 12:48 PM   #9
LanceS13
AutoX Junkie
I've never seen or heard of 10's on an S13. &nbsp; 9's are pretty much max with the right offset...and that's just for the rear. &nbsp;If by "tuck" you mean do they fit in the fenders?, then yes. &nbsp;I plan to go to 8's all around sometime in the distant future.
