Old 04-26-2012, 05:42 AM   #1
Tedskiii
Tedskiii's Avatar
Tedskiii is an unknown quantity at this point
[Recirculating BOV Ideas]
Well I plan on Recirculating my BOV, but I'm curious on where I should put it.
I'm not moving my BOV to the cold side, I want to see if I can route it from where it's at now.
I've been told it should go before the MAF?
But anyways heres a shot of the motor. It's a Greddy BOV btw. If the car didn't come with a BOV I would of never put one.
Don't mind the dirty bay ! Haha
Any ideas/tips? Thanks Zilvia.
Tedskiii is offline   Reply With Quote
Old 04-26-2012, 06:56 AM   #2
Darius
Darius is on the path to ruinDarius is on the path to ruinDarius is on the path to ruin
If you recirc it, it must go after the MAF sensor. It is metered air so putting it ahead of the MAF does you no good. You might as well vent to atmosphere.
Darius is offline   Reply With Quote
Old 04-26-2012, 08:34 AM   #3
conrad_s13.5
conrad_s13.5's Avatar
^ yup
looks like you have the stock intake tube,. so you probably have the stock recirc hole plugged
if you flipped you BOV around 180, it'd probably be a straight shot any way
cONtRol FReAkS
Old 04-26-2012, 12:52 PM   #4
Tedskiii
Tedskiii's Avatar
Originally Posted by conrad_s13.5 View Post
^ yup
Alright I'll check it out today. If it dosn't have the recirc hole then what would be the best option to mount it?
Old 04-26-2012, 01:11 PM   #5
Boost_Fiend
Boost_Fiend is an unknown quantity at this point
If its the stock rubber intake it will have a port to recirc. Flip the bov around and use rubber hose.
Boost_Fiend is offline   Reply With Quote
Old 04-26-2012, 04:16 PM   #6
Tedskiii
Tedskiii's Avatar
Just checked, and it's not the stock one. :/
So would I be able to just buy one stock one and swap? Or is there another way?
Old 04-26-2012, 09:33 PM   #7
Matej
Blow-off valves are for silly nannies.
Old 04-26-2012, 10:21 PM   #8
Tedskiii
Tedskiii's Avatar
Why do I still remember that drink?! Hahaha.
But like I said .. If it never came with, if never even put one. I don't care about the sounds they make.
Old 04-26-2012, 10:38 PM   #9
Boost_Fiend
yeah buy the stock intake or you can buy one of those cheap intake hard pipes on ebay. the build quality isnt the best but it does have all the ports stock pipe has.
Old 04-26-2012, 10:47 PM   #10
Tedskiii
Tedskiii's Avatar
Alright sounds good. So the actual filter/maf will go right on yeah?
Old 04-26-2012, 11:17 PM   #11
Tedskiii
Tedskiii's Avatar
This will work yeah?
http://www.google.com/search?q=sr20+...safari#&miuv=0
Old 04-27-2012, 05:19 PM   #12
Kingtal0n
Kingtal0n's Avatar
This is on a S13 sr20det
All parts used are from home depot.
Old 04-27-2012, 08:53 PM   #13
Tedskiii
Tedskiii's Avatar
Looks good ! But how would I go about with putting a circulation tab to plug the bov to?
Old 04-27-2012, 09:25 PM   #14
cmg
cmg is an unknown quantity at this point
Just noticed that enjuku swapped the hot pipe with no bov flange from their specials to the cold pipe on their specials. That would have been perfect for $25.
Might wanna check the tube every few days. Im betting it will get hard and crack from the heat.
cmg is offline   Reply With Quote
Old 04-28-2012, 09:45 AM   #15
Kingtal0n
Kingtal0n's Avatar
What is a circulation "tab" and what do you mean plug the bov to? The Bov (bypass valve) relieves pressure from the hot-pipe, back into the air inlet (before the turbocharger) Nothing is plugged.
This particular home depot hose gets soft when exposed to heat, that is why those hose clamps are in place, to keep it from collapsing. It has been on the vehicle for over 1 year now, but it should be replaced with a solid aluminum pipe (and proper couplers) or a simple silicon hose for sure.
This was just a temporary fix so the car could drive daily... but it wound up working consistent and without falt, so its been that way ever since...
Old 04-29-2012, 12:35 PM   #16
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
blessedhellrider is offline   Reply With Quote
240sx, blacktop, bov, sr20
