Old 10-24-2015, 09:21 AM   #1
Loomis112
Loomis112's Avatar
Loomis112 is an unknown quantity at this point
Max power output of a gtx2554? (T25)
I found this t25 on ebay thats been rebuilt and fitted with gtx wheels on it and im wondering what the max power output would be on it?
It's from JDS turbos and they say around 300 but anyone wanna take a look and see what they think?
http://m.ebay.com/itm/JDS-2554-T25-B...234?nav=SEARCH
Loomis112 is offline   Reply With Quote
Old 10-24-2015, 01:32 PM   #2
cotbu
cotbu's Avatar
Seems like they're setting noobs up for failure, 100 balancing, and the right to deny warranty. To protect yourself you have to get the balancing, and with that 100 more you could get a gt28r.
Idk, just bored:screwy:
Sent from my Highly Tuned Note 4.5!!!
Old 10-24-2015, 03:25 PM   #3
Loomis112
Loomis112's Avatar
Hmm I see the original plan is to get a Gt28r off frsport before that sale ends. i was just wondering about that turbo, but I guess i'll stick to my original plan.
Old 10-24-2015, 03:42 PM   #4
derass
Here's a slightly better price on the S15 turbo:
http://www.nissanparts.cc/partlocato...catalogid=9759
Old 10-24-2015, 04:01 PM   #5
jedi03
Get s15 or a little more and 2871...2871 more fun alot more fun!!!
Old 10-24-2015, 04:29 PM   #6
derass
I have a GT2871R and if I were to do it again, I would have bought a GT2860R or GT2560R (S15).
I would always read about how the 2871 is a 400whp turbo, and it is. That's why I chose it. I learned however, that you need to spend a lot more money than just the turbo to get there.
I made 320whp and am happy with that. I figure it will cost another $3k to make the push for 400whp. There's just no need. With a smaller 2860 or 2560, I would have made the same power with better response.
Just food for thought.
Old 10-24-2015, 05:08 PM   #7
Loomis112
Loomis112's Avatar
Was that sr or ka? Cause im putting it on a ka. I think I wanna do a gt2560r I only plan to make 300-320.
On my old sr I had a gt2871r and it was alright but im told it spools a lot sooner on a ka.
Old 10-24-2015, 05:09 PM   #8
Loomis112
Loomis112's Avatar
Is that legit? How is that so much cheaper than everywhere else that's awesome. Thanks man
Old 10-24-2015, 05:15 PM   #9
derass
I don't know, but this thread reminded me of the good deals on that turbo I've seen on here in the past. Call or email them to see if they have stock before ordering online.
I have the 2871 on an SR. It would spool sooner on a 2.4L, but if a 2560 or 2860 is capable of enough airflow for 300 hp on a 2.4L, then those are still the better choice.
Old 10-24-2015, 05:19 PM   #10
Loomis112
Loomis112's Avatar
Are they new or used? Whats the name?
Old 10-24-2015, 05:24 PM   #11
fatduece
How the hell do you make 320whp on a 2871r? I made 300whp on a t28, at 16psi. no cams. The only mods were exhaust, and a dyno session with safcII.
Old 10-24-2015, 05:28 PM   #12
derass
What do you mean? The link I posted? I assume they're new.
Is my 320whp good or bad? I'm at 15psi, no cams either. But that's what I mean, since I'm not using the 2871 to it's full ability, I would have been better off with a smaller turbo for better response. 300whp on a T28 is impressive. That's only the second instance I've ever heard of. But that has to be the absolute maximum airflow that turbo can produce though.
I should mention, my car is track only and therefore spends most of it's time at full throttle in sometimes very hot ambient conditions ie. during the summer. Also, the engine still has stock pistons and head gasket, Knowing this, my tuner suggested that we not use more than 15 psi to maximize reliability. I'm happy that we did as the engine has held up very well over the last few years doing countless events, even if it meant sacrificing peak HP.
Old 10-24-2015, 05:32 PM   #13
Loomis112
Loomis112's Avatar
Is my 320whp good or bad? I'm at 15psi, no cams either. But that's what I mean, since I'm not using the 2871 to it's full ability, I would have been better off with a smaller turbo for better response. 300whp on a T28 is impressive. That's only the second instance I've ever heard of. That has to be the absolute maximum airflow that turbo can produce though.
Ahh my bad man. Yea I checked the link that price is awesome. Have you ever ordered with them?
Old 10-24-2015, 05:34 PM   #14
derass
No, but they're a forum sponsor, so you can trust them. I was just eyeing a Kouki tail-light set from them the other day!
Old 10-24-2015, 05:38 PM   #15
Loomis112
Loomis112's Avatar
Ahh I see well thanks for the info man that saves money
Old 10-24-2015, 05:42 PM   #16
fatduece
Well first off, was 320whp on a mustang dyno? Those do read lower. 16psi on a t28 is definitely out of its range, but it still makes power, but mostly blowing hot air. Factory Injectors were maxed out as well. Lol. That setup lasted me 4 years. By the end of the 4th year, the compressor wheel was starting to hit the housing. Still I think that kind of use out of a t28 is great, they're pretty cheap.
If you're trying to hit 300whp than the 2871r is too laggy. Go with the smaller turbos.
Old 10-24-2015, 05:49 PM   #17
derass
I was on a DynoDynamics. You can really only compare numbers from the EXACT same dyno, meaning at the same shop. There are so many settings that can effect the readings. Every tuner is different. You could even have the same tuner, on the same dyno, change his settings from one run to another. So numbers from one shop using a certain dyno could be different than another shop using the same one. This goes for all dynos: Mustang, DynoJet, DynaPack, DynoDynamics etc.
Old 10-24-2015, 06:02 PM   #18
fatduece
Yea thats true
Old 11-10-2015, 08:12 PM   #19
Izento
Izento's Avatar
Izento is an unknown quantity at this point
I've been in Nissanparts.cc actual shop. They are located at a Nissan dealership in Washington State. That's how they get mad deals on parts. Direct connection with Nissan Japan. Lowest priced S15 turbos by far.
Izento is offline   Reply With Quote
