Old 07-23-2015, 06:52 PM   #1
e1_griego
e1_griego's Avatar
Trader Rating: (24)
e1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond repute
Feedback Score: 24 reviews
Not your average misfire
I haven't done any diag yet on this, mostly just soliciting feedback from people who have been around the block.
Motor is:
SR with w/ 3k miles on rebuild
9:1 CP pistons and Manley rods
New JWT s3 cams with stock valvetrain
New oil pump, gaskets, bearings, etc
GTX2867
PowerFC tuned by Martin @ Enthalpy
740cc injectors (cleaned/tested 3 months ago by RC Engineering)
Z32 maf
Alright, so the car rips. Not hiccups, no boost leaks, no nothing. 20psi is feeling great.
However, if I tag the limiter in 2nd (it's an autocross car, it happens -- might do it in 1st but I haven't noticed it) the car loses one cylinder it sounds like. The 4th will clear up after 5-7sec.
The coilpacks are stock which means they're old. I'm guessing that's the problem, but mostly just seeing what other people think. I feel like if it was a mechanical issue I would have trashed the head by now since a sticking lifter at 7500rpm would cause bigger issues.
I'll swap out all my coilpacks before the next autox but just wanted to see what other people thought.
e1_griego is offline   Reply With Quote
Old 07-23-2015, 08:13 PM   #2
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
I'd definitely start with the tired ignition system. Swap an ignitor first and see if that changes anything. If not proceed with your plan.
My SR20VET
Old 07-23-2015, 09:33 PM   #3
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Yeah I just bought a new new set of coil packs. I'll throw in an ignitor too and go from there.
Old 07-24-2015, 12:19 AM   #4
fatduece
Hey Alex what coil packs did u buy?
Old 07-24-2015, 12:28 AM   #5
e1_griego
e1_griego's Avatar
Trader Rating: (24)
A new set of OEM.
Not really looking to do splitfire stuffs.
Old 07-24-2015, 07:01 AM   #6
cotbu
cotbu's Avatar
It sounds to me like your just hitting the hard Rev limit, might be wrong but that's my guess. Check the bin or contact your tuner, the soft Rev limit is 7500rpm the hard limit is 7600rpm. The tuner might not have changed this. You could easily over Rev an extra 100rpm.
Sent from a Highly Tuned Note 4.5!!!
Old 07-24-2015, 08:16 AM   #7
Kingtal0n
Kingtal0n's Avatar
I set my limiter in my daily to 6300rpm for ultra safety.
His car is not a daily though
Old 07-24-2015, 08:28 AM   #8
e1_griego
e1_griego's Avatar
Trader Rating: (24)
This is an autox car. I don't see the point of funneling money and time with "racecar" parts into a car and then just driving it solely on the street.
I have a pfc and a datalogit. The limiter isn't set up any differently than it has been for 5 years now. Losing a cylinder for 5-7 seconds isn't normal.
Maybe the new coilpacks will fix it and I'll dig up a spare ignitor and try that too.
Old 07-24-2015, 10:15 AM   #9
cotbu
cotbu's Avatar
I always raise mine, for safety! XD!
It is if you hit the hard cut on a powerfc, hard cut is ignition, soft cut is fuel!
If you have a powerfc log that shyyyyt!
You will definitely see ignition drop off, you might even see when and why.
Old 07-24-2015, 11:05 AM   #10
e1_griego
e1_griego's Avatar
Trader Rating: (24)
I've been autocrossing and hitting limiter for years, never had that problem.
Weird that it manifests itself now. That's why I figured something was wrong. And losing just one cylinder instead of all?
Old 07-24-2015, 01:29 PM   #11
Kingtal0n
Kingtal0n's Avatar
a single cylinder drops when
it fills with fuel, or fuel cuts completely
the spark dies, or is too weak
it loses compression
Other exotic issues include golf-balls that only block the intake port for a few seconds
https://tinyurl.com/turbo240
Old 07-24-2015, 02:13 PM   #12
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Yeah I understand what's happening.
The why is what I'm after, since this isn't a common thing.
Old 11-04-2015, 10:20 AM   #13
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Just in the interest of future searches, after replacing the coilpacks with new OEM and replacing the ignitor with a known good one that issues persists (though I went almost a whole weekend of hitting limiter and never had an issue except for one or two instances, so it's not *every* time.
Anyhow, I reached out to Martin @ RS Enthalpy who said he'd run across the issue before and that it's either the CAS or the PowerFC having a bad injector or coil driver.
I have another CAS on the way, though I'm guessing that it's going to end up being the PowerFC.
Old 11-06-2015, 05:41 PM   #14
TougeSR20Kid
TougeSR20Kid's Avatar
TougeSR20Kid has a little shameless behavior in the past
I had this same issue on my RB, cleaned the interior contact points of the coil packs and now it runs fine. I'd find it hard to believe its an issue with the injector circuitry. Does it sound like the vehicle hits an early limiter? Cus that's exactly what mine was doing
Originally Posted by mantas View Post
One more thing - i hate your prius.
Namaste mother f**ker
TougeSR20Kid is offline   Reply With Quote
Old 11-06-2015, 05:47 PM   #15
e1_griego
e1_griego's Avatar
Trader Rating: (24)
a) Car has a brand new set of OEM coilpacks
b) If you'll read, it's after I hit the limiter that I lose a cylinder
Old 11-06-2015, 06:04 PM   #16
bmxer882x
bmxer882x is an unknown quantity at this point
possibly spark knock? Checked your plug gaps?
bmxer882x is offline   Reply With Quote
Old 11-09-2015, 10:15 AM   #17
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
No, any knock retardation from the ecu will affect all cylinders.
Do you have any sort of fuel trim on the cylinder individually?
Enthalpy knows their stuff - but I'd figure a bad injector driver would should it's face more often than just after hitting a rev limiter.
Let us know what you find!
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 11-09-2015, 10:42 AM   #18
e1_griego
e1_griego's Avatar
Trader Rating: (24)
No, fuel trim is set evenly across the board. PFC does allow fuel trim per cylinder but it's even for my setup currently.
PFC doesn't have any knock control.
Injectors were cleaned and tested by RC Engineering at the beginning of the year and received a clean bill of health.
I still can't imagine it's mechanical since the car hasn't shredded the valvetrain, but when I do the CAS I'll have the valve cover off so I can at least inspect everything.
