Old 09-28-2011, 01:27 PM   #1
coupe92
coupe92 is an unknown quantity at this point
Broken injector?
Ok, so upon replacing my o rings, which I've never done before, I assumed it ok to use a small screwdriver to help pull the o rings over the middle section of my 370cc sr injector. Upon doing so, I heard a slight tearing sound, and promptly checked the victim area. What I saw was a slight puncture to the sort of soft area in the middle of the injector. This really worries me, I think I might have ruined the injector, but I don't know. It's just a very slight dent, maybe a verrry small crack. Am I screwed? Bad quality pic below showing the area I am talking about.
coupe92 is offline   Reply With Quote
Old 09-28-2011, 01:44 PM   #2
ILoveJDM
you need a better picture then that man..
is it just the mesh filter thats broken? or the case? or the internals?
DODOlogic.ca
Old 09-28-2011, 01:47 PM   #3
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
just send it to RC engineering and have it tested/repaired. They do great work and when it comes to injectors on a boosted engine, it's not worth the risk. Having said that, those look filthy, I would send them all in. You would be surprised how they might flow. number them according to your cylinder arrangement for problem referencing later.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 09-28-2011, 01:48 PM   #4
coupe92
In the spot where the picture indicates, there is a small rip. Is this critical to the injector functioning right?
Old 09-28-2011, 01:51 PM   #5
coupe92
Its hard to dish out money on a set of 80 dollar injectors. I'm gonna go ahead and run them, the others are ok. If I have a problem I'll know to check the injectors.
Old 09-28-2011, 02:40 PM   #6
s14unimog
s14unimog's Avatar
I'm not suggesting you purchase a new injector but I will forewarn you. IF there is a problem... you won't need to check the injector, lol.
Old 09-28-2011, 07:36 PM   #7
coupe92
Because it's so hard to read a wideband.. Anyway thanks for referring me to RC injectors, I might send them in if they indeed do flow awfully for whatever reason. I just want to know if the injector is damaged or not before I go to the trouble of snapping it in and moving onto the next thing. If anyone can tell me what function this part of the injector serves I'd appreciate it.
Old 09-29-2011, 09:40 AM   #8
s14unimog
s14unimog's Avatar
Because it's so hard to read a wideband...
oh ya... you're monitoring individual cylinder A/F's are ya? I'm trying to help you out here. That's a filter for contaminants getting into the spray orifices. If an injector clogs, the individual cylinder will lean out. Besides you wouldn't have time to notice an A/F change at WOT. Stop being a cheap ass 240 owner.
Old 09-29-2011, 02:45 PM   #9
modulation
modulation is an unknown quantity at this point
I wouldn't worry about it, it's just a filter.
You can snap that whole black part off. Take off one from your old injector and put it on your new one.
I've swapped my fuel injectors a good amount of time and never seen anything on that screen that was filtered out, whatever would get there would have to get through the fuel filter first. If you're building a $5k turbo setup I'd say make sure you replace it, but personally I'd run it without a second thought.
modulation is offline   Reply With Quote
Old 09-30-2011, 04:59 AM   #10
coupe92
I understand, but it would be nice if you could've posted this info a bit earlier instead of just saying "It won't be the injector you need to check, lol". Thanks though..
