Old 06-28-2005, 09:22 AM   #1
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
Caliper or brake cable?
Before I set my car on fire...
I've been having issues with my ebrake forever now.
Last week I changed all the rotors and pads.
Now the god damn parking brake only locks up the passenger side tire. The drivers side will finally lock up after I give about 8-10 good long ebrake pulls. Before that its useless.
The calipers were replaced (with NEW units) about 8 months ago because the drivers side one didn't lock when the ebrake was engaged.
Anyone have ANY clue what I should look for now? Another Bad caliper? Messed up ebrake cable?
JaeTea is offline   Reply With Quote
Old 06-28-2005, 10:44 AM   #2
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
is there anyway to adjust the cable?? I have never looked at the assembly on the 240, but on my brothers integra it has an adjustment on each side in the back.
g2ic02 is offline   Reply With Quote
Old 06-28-2005, 08:01 PM   #3
JaeTea
JaeTea's Avatar
I'm waaaaaaaay past fucking around with the ebrake adjustment.
Old 06-28-2005, 11:06 PM   #4
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
^^he's probably right. Check the ebrake 'spring' in the back and make sure there is no extra slack on either side of the cable. If thats not the problem then pull one rear caliper at a time off the rotor and have a friend pull the ebrake and make sure the piston pushes out...if none of this works......proceed to the original plan of setting the car on fire........- Rob
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 06-28-2005, 11:25 PM   #5
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
can you give me your car instead of setting it on fire
Indolent is offline   Reply With Quote
