![]() Join Date: Dec 2006
No its not safe, Boost is not the same with different turbo's, Bigger turbos flow more CFM (More Air) You should swap back to the stock turbo and wait gather all the other parts before you do the swap.
If yo accidentally boost too much you will blow the engine. Do you even have a Metal Head Gasket?
![]() 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#3 | |
![]() Join Date: Mar 2006
Well to be fair, it depends upon what you mean by "safe to drive". If you are on a MAF sensor, the MAF WILL be able to safely detect the airflow into the engine and the injectors and ECU will behave like stock. The issue is that you will max out the MAF or injectors very quickly. Probably something like a few psi on that turbo at higher RPM and you will be flowing the same amount of air as a stock turbo at 15 psi. Moral of the story....if you just need to limp the car to a shop to get it tuned, you could be okay, but you MUST KEEP THE CAR OUT OF BOOST (like 2 or 3 psi should be okay in the lower RPM as you are giving it a bit of gas).... If you keep the car under vacuum and BABY it, you could limp it to a shop. Anything more than that is extremely unsafe.
![]() Daily driven |
Man w/ CTSV & a Car Seat
Stay off the boost, plain and simple. As long as it stays in vacuum, it should be okay.
7 psi on a T25 is not even close to 7 psi on a GT3582R. Its not the boost, but the volume of air being pushed thru thats the difference. At that boost level for both, 180 whp for the T25 and probably 280-300 on the GT3582R. |
![]() Join Date: Oct 2008
it's safe, if you disconnect your hotside on the intercooler so you cant get any boost.
My 96 S14 | 501whp SOLD |
well if he just takes the wheel out of the turbo he should be fine.
#10 | |
If you wanna be lazy/ghetto then just take off the external W/G
yes im joking...
![]() Join Date: Dec 2007
Trader Rating: (38)
to the op: why wont you just get a tuned ecu shipped to you while your installing your gt35r? makes it alot safer to drive and boost. not just that you can drive it to the shop just for a fine tune
btw, get bigger injectors and pump before you fuck up anything else. dont do half ass jobs. just my 2 cents |
#13 | |
drive like sane person, granny shift it @ 2200rpm. you should be fine... a friend of mine drove his KA-T with T3-T4 to a tune shop in long beach or murrieta.. forgot which one. and we live about an hr away from each shop.. drove fine there. |
#14 | |
![]() Join Date: Aug 2004
#16 | |
It's my daily so I needed it back on the road for work but my uncle is letting me borrow his car so that I may buy the necessary items and not rush it ![]() |
#17 | |
But in all honesty, keep the stock turbo setup until you get everything in. No point of slapping in a turbo that big and plan on driving it for a while until you get all the supporting mods. Wouldnt take much for you to accidentally boost it and have a nice rod knock on it. We thought you were asking if its safe to drive, just to drive it to your tuner instead of getting it towed to save some money. Also, I got the same setup, I'd opt up for some 850s. You'd be pushing those 740s near their max with a turbo that big at high boost, high boost in the ball park of atleast 1.5-1.8 psi. |
#18 | |
#20 |
Reason I say 850s, you'd max out 740s after 450-480whp. GT35R has more than enough air flow to push you up and over 500whp depending on the supporting mods and tune (closer to 2.0 bar).
Also, I hope youre not gonna leave it at .8 bar. These turbo's doesnt liven up till after 1 bar. And, what do you have planned for the drivetrain? Clutch and transmission upgrade should be in your sights. |
#22 | |
#24 |
i went with 1000ccs for my 35r setup.... overkill!
