Old 10-08-2014, 08:05 AM   #1
TXtimS13
TXtimS13 is an unknown quantity at this point
bad battery drain
So im having a huge battery drain. With a fully charged battery it only last about 20 minutes while car is on. Idles and runs great for about 20 mins then starts bogging and dying and wont turn back on unless jump started. I got the alternator and battery tested and turned out good. Cleaned grounds. Car has no radio so couldnt be that. When key is out the battery terminal will spark so it is parastic drain but all wiring looks to be fine. Where should i look? Obd2 ka in 95 s14.
TXtimS13 is offline   Reply With Quote
Old 10-08-2014, 12:16 PM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Didnt feel like explaining it so here's a link with pictures on how to diagnose this.
http://m.wikihow.com/Find-a-Parasitic-Battery-Drain
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 10-08-2014, 05:40 PM   #3
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Pretty sure its your alternator, I had the same problem. Just rebuild it, it's probably on its way out so itll be a good insurance. It could also be your battery not being able to hold charge.
SilviaSR20DET is offline   Reply With Quote
Old 10-08-2014, 05:43 PM   #4
TXtimS13
Ok so im doing the test light thing. Clip test light to negative and touch tip to terminal. Light stays in till alternator fuse is pulled sonits within the alternator wiring. Unhooked everything from alternator and light still stays on. So im assuming the wiring could be messed up. Anything else?
battery issues, s14 240
