Closed Thread
Old 10-12-2005, 07:13 PM   #31
b00st2R
b00st2R is an unknown quantity at this point
So it seem like all those people who have the track series think they are pretty good, it BS when people come out bashing when they have no experience with the track coilover. im going to put mine in this sunday and let see how i think
b00st2R is offline
Old 10-12-2005, 07:23 PM   #32
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
i was in one with the track series and a few other track series coilovers. For comparsion, I am not sure if chassis or other suspension setup has any influences but It does feel a little softer than the spring rate suppose to. 12 and 10 should be much stiffer than that. Anywayz I personally have the street version on my car. It does feel a lot more roll on my s13 coupe than the silkroad on my s14. However I have to factor in the s14 chassis is stiffer and I also had ST swaybars and maybe better bushings. Overall I would get these coilovers over strut and spring combo anydays. They are worth every penny.
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline
Old 10-12-2005, 07:35 PM   #33
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
Just a question for the people who tried drifting with them...
Did you corner weight the car and set it up for more foreward weight bias, or just run them at an even and visually apealing height?
ASE Master Technician
krustindumm is offline
Old 10-12-2005, 07:40 PM   #34
unforgiven
unforgiven is an unknown quantity at this point
didn't get to try it on dry pavement but on wet pavement its really easy to control oversteer if that helps any... it's a lot less sloppy than stock, but that's expected.
unforgiven is offline
Old 10-12-2005, 09:56 PM   #35
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
my s14 was corner balanced to utilize the best center of gravity after i put the coilovers on
the car has never felt better
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline
Old 10-23-2005, 12:34 AM   #36
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
i just ordered my track coilovers off of ebay and hope to test them out ASAP i'll throw out a review when i get mine on. i rode in a friends car with the street version and it was like a walk in the park so these should be border lineish for me. hopefully it doesn't piss off the girlies though.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline
Old 10-23-2005, 12:44 AM   #37
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
I've been in a drift car with 12/10 springs. It was one of the best handling cars i've ever been in. It was also used for mountain runs. If the car doesnt feel right, it's cause the shocks suck. The ones i'm talking about were Apex coilovers and they kicked ass.
Hi
Var is offline
Old 10-23-2005, 01:21 AM   #38
SoSideways
SoSideways's Avatar
[off topic]
OMG you have an Opeth sig pic!!
I've been into them since like 1997. Morningrise got me to be their biggest fan(boy) ever.
[/off topic]
Anywho, I installed these Megan Track coilovers onto my boss's S13 coupe, which has basically stock suspension and 18" wheels, running 225/45/18 fronts and 245/40/18s in the rear.
We set the damping to 20 front and rear to make sure they wouldn't bounce too much before we put it on.
After it was on, we took it for a test drive.
Holy crap, only flex in the suspension were the tires. Toyo Proxies 4 tires. My friend weighs 190 lbs and basically jumped on the rear bumper, and the rear of the car came down maybe 2mm (the top of the tire never touched the fender, and we have it set at maybe like 2 fingers worth of gap cause rear fenders aren't rolled).
Car cornered well, but going over bumps and such you're definitely going to feel it. Driveways will make you lift the inside rear wheel, so LSD is recommended.
So here's my solution:
Since I've heard people complain about the Megan Street coilovers's damping, saying that they were too soft, and thus the coilovers were oversprung, ie. bouncy, I would get the Track coilovers and get 10k springs for front, and 8k springs for rear.
That way, damping will be sufficient for the 10/8 springs, since they were meant for 12/10, and 10/8 still wouldn't be too bad. I don't know if the valving will work for 8/6 or not, seeing that's 4 kg/mm of difference, which is quite a bit.
Let me know what you guys think...
SoSideways is offline
Old 10-23-2005, 01:37 AM   #39
nissan_logik
nissan_logik's Avatar
nissan_logik is an unknown quantity at this point
id say megan racing products suck and theres a reason that the enjuku cars never finish well but thats just my opinion. all who flame me are now pre-0wned by the first amendment.
Image exceeds forum limits. Read the Rules and Guidelines for sig sizing restrictions.
-Jeff
nissan_logik is offline
Old 10-23-2005, 02:55 AM   #40
Var
Var's Avatar
Originally Posted by SoSideways
[off topic]
[/off topic]
Dont forget the Avatar of the Still Life cover art
Most coilovers system are underdamped if anything. If the valving of these coils are adequate for the 12/10 rates (which would really surprise me) then they should do just fine with the 10/8 rates. The only way they wouldnt work is if they are overdamped(which would really really really surprise me). In that case even the softest setting would be too much damping for the 10/8 springs (which is near impossible). Running with the 10/8 should be fine if not better.
Hi
Var is offline
Old 10-23-2005, 09:56 AM   #41
SoSideways
SoSideways's Avatar
I still like My Arms, Your Hearst the best, but Still Life is badass. I think it's still hard for people to get Still Life here in the US, unless you know where to look, no?
Anyways, 10/8 would probably be on the stiff side for the street, seeing as my car is a daily driver, and I'll probably only hit a few track events a year, and a drift event of two every few months.
I'd really like to go Silkroad RM/A8 with 8/6 spring rates, and Tanabe sway bars, but I cannot ignore how cheap the Megan coilovers are, and how everyone seem to love them...
Old 10-30-2005, 10:48 PM   #42
waynehead05
just swiched to the street ones instead of the track ones. got 40 bux back i can throw at something else instead.
Old 10-31-2005, 02:49 PM   #43
RedSuns
RedSuns's Avatar
wow...keep it up buddy
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
RedSuns is offline
Old 02-12-2006, 06:36 PM   #44
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
I got a s14 and was wondering if someone could tell me what coils to get all I have done to my suspension is a greddy strut bar. I like the megan racing ones b/c they are cheap ... but are they any good? I do drift alot but i also use my car as a daily driver and i am planning on taking it to some drift events this year.me personally i would think for drifting i would want my setup as stiff as i could get. which ones are better for drift track or street and which ones are better for daily driving/ drifting.
and my passengers can deal with it
rotation3x is offline
Old 02-12-2006, 10:41 PM   #45
RB26Sileighty
RB26Sileighty's Avatar
RB26Sileighty is an unknown quantity at this point
Send a message via AIM to RB26Sileighty
i'm gettin the street set for my 240...from what i have read there the best bang for the buck...
Lswan for the win
RB26Sileighty is offline
Old 02-12-2006, 10:51 PM   #46
KA24DESOneThree
Originally Posted by SilviaDriver
well the crazy thing is, not EVERYBODY is into drifting. so just becuz they are not good for drifting i guess they sucked?
No, they mostly suck because the valving is subpar at best and the spring rates are excessive.
It's my honest opinion that there is not a single SA coilover out there that is truly tuned for track driving. They are all compromised.
KA24DESOneThree is offline
Old 02-13-2006, 04:17 AM   #47
Nan Desu Ka?!
Nan Desu Ka?!'s Avatar
Nan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to all
Send a message via AIM to Nan Desu Ka?!
HELLA OLD THREAD!!!
why on earth did you bump this shit over 4 months later. Also, that question has ben answered a BILLION TIMES!! almost twice a day for fucks sake. SEARCH!!
you sir, fail misserably.
Norcal-240sx.net
Nan Desu Ka?! is offline
Old 02-13-2006, 05:12 AM   #48
S14DB
AFC #1
S14DB's Avatar
Thanks for using your first post to bump an old thread for something off topic. Please don't do it again.
S14DB is offline
Closed Thread
