![]() I'm working on a 4 piston CTS-V brake upgrade on my S13. I'm swapping out the master cylinder for a Z32 one. Is there any way of getting the fitting out of the old master cylinder without destroying it? Seems like a ton of delicate work.
Here's an article on getting the old fitting out http://importnut.net/the-definitive-...cylinder-swap/ FYI - I'm doing a video on the swap and I'll post it later when it's done. |
#10 | |
My plan with any luck is to get to a track day this weekend and properly test it out. There will definitely be a video! |
![]() Join Date: Sep 2012
Mine is 100% front brake bias with stock rears... which is great because my rears are almost seized (hypothetically) i would like to keep my stock rears, and some how hydraulic pressurized them so I can utilize my stock ebrake while doing a dual caliper bracket with wilwoods calipers to help bias with proportional valve....
#12 | |
Here's the second part of the video |
you installed left and right side backwords, unless you bought two left sides. other wise you wouldn't have had to swap the brake line/bleeders over.
good video though.
![]() Join Date: Oct 2006
Aren't those calipers heavy?
Not sure why people are paying top dollar for those when Wilwood 4 piston calipers are lighter, and cheaper. . . ? Is unsprung weight still not a thing? |
#16 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
#17 | |
cts-v swap can be found for close to 800 dollars, willwood is a bit over 1k, that $200 would totally be worth it if they are significantly lighter than the cts-v's... My guess is that the advantage in weight is wilwoods 2-piece rotor vs the cts-v rotors being monstrous. |
The Wilwood Superlites I run are 4 pistons and weight less than 5lbs each. They're a good deal at less than $180 per caliper. I use a bracket that allows to run a 350z brake rotor, so it's a very simple upgrade. Very cost effective, and weights virtually nothing compared to the stock caliper. According to Google, the CTS-V caliper weights 8 lbs.
I upgraded to Wilwood years ago, can't remember exact cost, but it was less than $450 in all of it. |
#19 |
![]() Join Date: Feb 2014
I'm also running a 4 piston Wilwood Superlite setup. I had thought about running a bastard CTS-V/350z setup, but the extra few bucks I spent was well worth it. Wilwoods are much lighter and have huge pads plus I got 2pc 13in rotors which are super light. My setup is from Arizona ZCar and was around $1k
#20 |
Track Proven on Facebook has the adapter brackets to put the wilwood calipers on the S and Z chassis and are very affordable! Couple that with one piece 350Z rotors and it's super cheap.
#21 |
Do you know if they offer any solutions for the rear? Really wanting to swap some 6pots up front and move my 4pots to the rear.
#26 | |
Anyway, there are several good solutions. I'm glad Wilwood works well for you. Last edited by Blue55; 05-09-2017 at 10:10 AM.. |
#29 |
For the track, those CTSV calipers like to eat/destroy the (rubber) dust seals.........like every other OEM Brembo.
The Wilwood (superlites) come with SS pistons and no dust shields/rubber boots which have to be rebuilt after a few trackdays (and the red brembos like to discolor after a few heat cycles). That and pads for the Wilwoods are 1/2 the price of a comparable Brembo. CTSV calipers are (were) stupid cheap and the cost came out close if I went either with the CTSV or Andys setup (I ran Andy's setup for a few years). Also, Wilwood has a multitude of piston sizes to really tune brake balance. You are stuck with what the CTSV provides for standard sizing But I do like the fact that the CTSV caliper is pretty and rotor coverage. Running Andy's brackets leave about .15" of rotor uncovered by the c caliper/pad. I also did a full weight comparison between the 300ZX AL and Wilwood with standard Brembo 1 piece, Andy's bracket and Wilwood superlite 1.75 and the weight was a few lbs lighther than a 300zx AL setup. So I assume even lighter yet than the comparable CTSV setup. I will have to dig up my full spreadsheet and comparison (posted elsewhere on the net with associated pictures). Standard Brembo rotor is 20.5lbs a piece. A Z1 2 piece setup is about 5-6 lbs lighter yet. Just my 0.02c......... I Last edited by RalliartRsX; 05-09-2017 at 10:14 AM.. |
#30 |
Tags |
brake upgrade, calipers, cts-v, ctsv, z32 |
