Old 07-22-2004, 10:12 PM   #1
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
interior lights stopped working, need help
I was pulling my gauge cluster, and when I put it back in the interior lights aren't working. My stereo isn't working either, and the power light is blinking on and off. There is a warning light on the dash, a red one, that is blinking faintly, so faint that you can barely notice it at night. None of the fuses appear to be blown. I'm usually pretty good with electric stuff but this one has me baffled. Anyone help?
andrave is offline   Reply With Quote
Old 07-22-2004, 11:19 PM   #2
morpheus8486
morpheus8486's Avatar
morpheus8486 has a little shameless behavior in the past
Check your fuses
'91 240sx Fastback SuperHicas
My Car Domain Page
morpheus8486 is offline   Reply With Quote
Old 07-22-2004, 11:32 PM   #3
Demik
Demik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of light
Send a message via AIM to Demik
^^^^cant read
sry andrave for being useless...
Demik is offline   Reply With Quote
Old 07-23-2004, 12:07 AM   #4
andrave
andrave's Avatar
no I'm a dumbass. none of the fuses looked blown. the one that said "room light" was blown. it was blown down by the leg, so I didn't catch it. Anyway I put a new 10 amp one it. It turned out to be bad (already blown). The next 10 amp I put in blew right away (must have been a dud). The next 10 amp I put in just wouldn't work for some reason (it was older, so kind of dirty). Being out of 10 amp fuses at this point I swapped a brand new 15 amp one in and all is well in the world. And realistically, that extra 5 amps of capacity shouldn't make much of a difference.
Anyway lesson learned, double check shit before I whine about it online.
Old 07-23-2004, 02:14 AM   #5
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Go find that short before it drains your battery. =)
Maeda is offline   Reply With Quote
Old 07-23-2004, 06:54 AM   #6
PSI240SX
PSI240SX is an unknown quantity at this point
yea you might want to see if that circuit is draining your battery... this happened to me last week. Same fuse. I wound up putting a flashlight in my car, and hardwiring the radio because I can't figure out what on that circuit is draining my battery. If I leave the fuse in, 3 days without driving, my battery will be stone dead.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
